Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
I'm going to be digging a trench for low-voltage cabling (coax, security, ethernet) soon. While I have a trencher I am thinking about some other improvements....
My long range plan is to install a bathroom in the garage, but it is currently not stubbed for any plumbing. This leads me to a couple questions.... 1) Should I go ahead and run another trench for some pex, and lay that down to the garage? 2) If so, what is considered "Code" for running a water line to an outbuilding? How do I properly tie into my existing water system? Do I have to connect a Y fitting at the street, or can I commandeer an unused water spigot under my deck?
__________________
My build: 32 x 24 with upper level |
#2 |
Senior Member
As far as I know you can source water anywhere you can get it, needs to have sufficient pipe size, usually 3/4 for small garage and buried deep enough frost isn't an issue where you live.
__________________
www.urkafarms.com |
| Thread Tools | |
| Display Modes | |
