Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-08-2010, 03:22 PM   #1
mrb
Senior Member
mrb's Avatar
Default where to get straight 2x2 lumber?
is it even possible to get straight 2x2 lumber anymore? going to build some stuff that requires straight 2x2s, last time i went wood shopping lowes had the best and even there I had to go through 1 and a half lifts just to get 20 or so good boards. where do i get good wood? is there a particular species or grade i can order that is going to come straight?
mrb is offline   Reply With Quote
Old 09-08-2010, 03:27 PM   #2
bill9860
Senior Member
Default Re: where to get straight 2x2 lumber?
good luck. and let us know if you find them. Just had similar experience w 2 x 6's. It is maddening.
bill9860 is offline   Reply With Quote
Old 09-08-2010, 03:30 PM   #3
kartracer23
Senior Member
kartracer23's Avatar
Don't look in the lumber racks - look in the trim area. Where the wood is standing up straight (be it HD, Lowe's, etc.). It's more finish trim type of wood (tends to be poplar) and is usually higher quality than the construction lumber that's in the racks.
kartracer23 is offline   Reply With Quote
Old 09-08-2010, 03:31 PM   #4
trbomax
Senior Member
trbomax's Avatar
whats even worse is that if you dont use the straight ones right away,they twist and warp in a week or so too.It all comes down to the drying process being to short at the mills.It would be interesting to take a moisture meter to loes,or hd and see what it shows.
trbomax is offline   Reply With Quote
Old 09-08-2010, 03:32 PM   #5
Professur
Senior Member
Professur's Avatar
I gave up long ago. I just get fairly straight large lumber and rip it on the table saw to what I want. Far more economical that way too.
Professur is offline   Reply With Quote
Old 09-08-2010, 03:42 PM   #6
DuluthMN
Senior Member
Quote:
I agree. This is the only way to get straight lumber.
__________________
It started out simple enough. I would start one project and upon completion I would start another. But somewhere, somehow something went terribly wrong. I have lots of projects in the garage started, but none near completion. Damn You DIY Network!
DuluthMN is offline   Reply With Quote
Old 09-08-2010, 03:48 PM   #7
PurdueSD
Senior Member
PurdueSD's Avatar
Quote:
I agree with his agree!
__________________
My Truck Shop Build thread... (SOLD)
http://www.garagejournal.com/forum/s...ead.php?t=9671
Help me brainstorm the new shop!
http://www.garagejournal.com/forum/s...d.php?t=338743
PurdueSD is offline   Reply With Quote
Old 09-08-2010, 03:59 PM   #8
Jeff
Senior Member
Jeff's Avatar
I rip what I need on the table saw. I don't like looking through stacks of wood for straight pieces.
Jeff is offline   Reply With Quote
Old 09-08-2010, 04:02 PM   #9
csp
Senior Member
Stop shopping for wood at Home Depot, Lowes, etc and go to a real lumberyard.
You'll probably find better prices along with better lumber.
csp is offline   Reply With Quote
Old 09-08-2010, 04:22 PM   #10
StingRay
Senior Member
Good luck. I have a tough time finding anything 2x4, 2x6, 2x8 and even 2x10 that is straight. Home depot lumber often has some straight stuff but like said use it right away or it'll warp and twist. As for real lumber yards they are no better or even worse. They all store the lumber outside in the rain.
StingRay is offline   Reply With Quote
Old 09-08-2010, 04:28 PM   #11
ADaughen
Senior Member
Do you guys have local lumber stores? Carter or 84 Lumber? They have a better selection and the last time I went I didn't have to dig through a pile of 2x4s for some straight ones.
I haven't had much good luck at Lowes with raw wood. Sad part is, they are really close so it makes it convenient to stop in and grab a board or two to finish a project.
ADaughen is offline   Reply With Quote
Old 09-08-2010, 05:19 PM   #12
Keep
Senior Member
Keep's Avatar
Buy long 2x12's like 2x12x16 this will usually be FIR (small knots) and less prone to warp. Let it sit for a couple days to acclimatize. Then rip it to size.
Keep is offline   Reply With Quote
Old 09-08-2010, 06:36 PM   #13
ddawg16
Senior Member
ddawg16's Avatar
Ditto....and do like Keep said....grade 1 lumber will have a lot less knots....and is kiln dried which means that if it isn't warped...it's most likely not going to.
If you really need it to stay straight...then stop looking at pine and consider some of the hardwoods like poplar.
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 09-08-2010, 07:18 PM   #14
ephotrod
Senior Member
ephotrod's Avatar
Does anyone have a fairly thorough list of the types of wood available and what their natural properties are.
Josh
ephotrod is offline   Reply With Quote
Old 09-08-2010, 08:16 PM   #15
Stuart in MN
Senior Member
Stuart in MN's Avatar
This is the right answer.
Stuart in MN is offline   Reply With Quote
Old 09-08-2010, 08:22 PM   #16
1969
Senior Member
1969's Avatar
If you are not using the lumber for a load bearing wall, use steel. You can also buy 2x lumber that is engineered, even 2x4. What are you using the lumber for ?
1969 is offline   Reply With Quote
Old 09-08-2010, 08:34 PM   #17
mmhouse
Senior Member
mmhouse's Avatar
Quote:
Josh
This looks like a good one for hardwoods...
http://www.hardwoodinfo.com/species_guide/index.php
mmhouse is offline   Reply With Quote
Old 09-08-2010, 08:45 PM   #18
Rockey
Senior Member
You dont have to go with hardwood species. Western Red Cedar is very dimensionally stable. If your going to use it for lumber it wont be very cost effective though. Any species will get more dimensionally stable the clearer (stright grain - no knots) it gets. Air dried lumber that has not sat out in the sun is going to minimize the warping, twisting, cupping, checking etc.
Rockey is offline   Reply With Quote
Old 09-08-2010, 09:34 PM   #19
trbomax
Senior Member
trbomax's Avatar
This is true.Problem is,in kalkaska ,antrim, and otsego countys the box stores have run all the real lumber yards out.Used to be 2 in the village of kalkaska,3 in gaylord (now there is one),only one left in antrim county.Real lumber yards are hard to find in northern michigan.
Old 09-27-2010, 09:23 PM   #20
MN4x4
Senior Member
Do you have a 'Pro Build' near you? I had this same problem firring out my daughter's basement last weekend, and ended up finding nice PREMIUM 2x2's there. They were bundled 2 x 4 for 8 pieces in a bundle, and were mostly dead straight. Price wasn't bad either - about $2.12 each if I recall.
MN4x4 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
