Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-15-2010, 01:21 PM   #1
jake26
Senior Member
Default How to join LVL beams?
A while ago, I posted a question about a beam construction I did for a Garage Makeover I was working on. The thread is here:
http://www.garagejournal.com/forum/s...ad.php?t=70073
Long story short, the beam I built was not strong enough for the necessary span so I disassemled the 12" beam to install a new LVL constructed beam from 3 25' long 14" LVL beams.
The question I have is; what is the best way to connect the beams. I used construction adhesive on the 12" beam but was amazed on how easy it was to disassemble the glued wood. What distance should the bolts be? Should the be top and bottom in equal lengths, in stagged lengths, ect ...?
Thanks again for the help. If it were not for GJ, I may have had a serious issue on my hands.
jake26 is offline   Reply With Quote
Old 09-15-2010, 01:29 PM   #2
Cryptic1911
Senior Member
Default Re: How to join LVL beams?
mine is drilled and bolted in a staggered formation. I don't know the exact distance, but maybe like 16-24" apart? I looked to see if I had a picture, but I only have them from before they bolted them together
Cryptic1911 is offline   Reply With Quote
Old 09-15-2010, 01:30 PM   #3
twostory
Senior Member
Your LVL manufacturer should have very specific instructions on how to joins the 3 beams. One method it to glue & screw, another method it bolts placed at specific locations (as specified by the LVL company)
Georgia Pacific has this info available online, as do some other manufacturers.
Who made your LVLs ?
twostory is offline   Reply With Quote
Old 09-15-2010, 01:44 PM   #4
cabriolet
Another option would be to substitute a steel beam for the 3 LVL's you are about to install.
cabriolet is offline   Reply With Quote
Old 09-15-2010, 03:46 PM   #5
bimmer1980
Senior Member
bimmer1980's Avatar
I just fastened some lvl's together for my garage. I checked one of the LVL spec sheets, and they showed a nail every 8" with three rows of nails. 2" from the edges and one in the middle....
It adds up to a lot of nails in a hurry.
I used the nail gun and put them in about every 6". I had to hammer them the last 1/4" because the LVl is so dense.
__________________
-- Brad --
Currently working on a new garage....Exterior is finally done...working on electrical, etc inside.
28x44 with attached workshop area of 16x28. 1600 sq total.
bimmer1980 is offline   Reply With Quote
Old 09-16-2010, 08:36 PM   #6
tcianci
Senior Member
tcianci's Avatar
Send a message via AIM to tcianci
Get the fastening schedule from the web site of the manufacturer. I Like to use Fastenmaster screws, they have screws specifically for joining engineered lumber. Also If you had the beam speced at a lumber dealer, there should be a calculation sheet showing the required end purchase for the supporting jacks and a fastening schedule as well.
__________________
People are doing either what they THINK is right or what they KNOW is wrong.
tcianci is offline   Reply With Quote
Old 09-16-2010, 09:47 PM   #7
6768rogues
Senior Member
I would also like to mention that you should follow the manufacturer's directions for bracing the beam. If it rotates, you are out of luck.
__________________
Why a cool garage? Chicks dig 'em. Alcohol may intensify the effect. As John Belushi said in Animal House, "I suggest you drink and drink heavily."
6768rogues is offline   Reply With Quote
Old 09-17-2010, 12:10 AM   #8
mjozefow
Senior Member
mjozefow's Avatar
We used nails on the ones I have installed. It does add up to a lot of nails in a hurry.
__________________
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
Lots of Vise Info
Vise restoration Tips
The Vises of GJ! (dial-up death)
A_Pmech makes replacement jaws, ask him!
My Website:
www.mitchscustomcarpentry.com
mjozefow is offline   Reply With Quote
Old 09-17-2010, 12:22 AM   #9
Torque1st
Senior Member
Torque1st's Avatar
So PVC cement and duct tape are not good enough? How about Gorilla glue or JB-Weld and some C-clamps from Harbor Freight?
Now if you had to connect the beams end to end then Crazy Glue does the trick!!!
Sorry, I just can't help myself....
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 09-17-2010, 01:12 PM   #10
jake26
Senior Member
I have not ordered them yet but when I do, I will ask for the installation information. Thanks for the advice!!
Old 09-17-2010, 05:46 PM   #11
KELLHAMMER
Senior Member
KELLHAMMER's Avatar
Typical nailing would be (3) 16d nails rows 12" o.c. Gluing in addition of the nailing is also suggested
KELLHAMMER is offline   Reply With Quote
Old 09-17-2010, 11:19 PM   #12
Jakkle5
http://www.gp.com/build/product.aspx?pid=1392
Click on residential floor and roof. I typically use the red rafter lock screws that are available at most lumber yards. If not drill and carriage bolt them together. Glue is next to useless as they're coated in a wax type coating.
Jakkle5 is offline   Reply With Quote
Old 09-18-2010, 07:56 AM   #13
BlindViper
Senior Member
These work great
http://www.mcfeelys.com/search/lvl+screws
BlindViper is offline   Reply With Quote
Old 09-23-2010, 10:07 AM   #14
jake26
Senior Member
Hey Gang!
The LVLs arrived today. Basically, the instructions say to either join the beams with ” bolts 2 rows 24” on center or 16d nails 3 rows 12” on center. I plan to do the bolts with a row of nails between each row of bolts.
Now comes the task of raising the 26' beams into my attic space. Yea!!
Old 09-23-2010, 01:30 PM   #15
blkhonda1991
Senior Member
Quote:
Originally Posted by jake26 View Post
Hey Gang!
The LVLs arrived today. Basically, the instructions say to either join the beams with bolts 2 rows 24 on center or 16d nails 3 rows 12 on center. I plan to do the bolts with a row of nails between each row of bolts.
why even bother with the nails?
__________________
8-29-09 - Finally done renting and will finally have a garage!
blkhonda1991 is offline   Reply With Quote
Old 09-23-2010, 03:26 PM   #16
jake26
Senior Member
Quote:
I planed on using nails until the entire beam is together because I am rasing them inplace one at a time. Not that I did this before or know what I am doing, just taking more caution.
Old 11-27-2010, 01:53 PM   #17
tnerb40
Junior Member
How did it go jake26? Any pictures?
tnerb40 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
