Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 09-18-2010, 10:40 PM   #1
juicegoose
Default Whats the average amp draw from a small welder?
Guys I was going to run some wire to two 220v circuits tomorrow and for right now I'm just going to run double pole 20A duplex receptacles at each one for use with my woodworking machinery. I do want to kind of future proof myself to some extent not possible needs for a small mig welder. Would 10-3 on a 30amp breaker be enough for a good sized mig welder or not? Also a medium sized plasma cutter. I've got one that I can use at any time.
juicegoose is offline   Reply With Quote
Old 09-18-2010, 10:46 PM   #2
terabyte
Senior Member
terabyte's Avatar
Default Re: Whats the average amp draw from a small welder?
my 185 amp tig and 175 amp mig both only need 30 amp each.
i believe 10-3 is good enough as long as its a reasonable run and copper
terabyte is offline   Reply With Quote
Old 09-18-2010, 11:06 PM   #3
Norcal
Senior Member
Why spend the dough for a extra wire? It's a 240V load & welders do not require a neutral.
Norcal is offline   Reply With Quote
Old 09-18-2010, 11:08 PM   #4
terabyte
Senior Member
terabyte's Avatar
Quote:
you need a white a black and the neutral\ground don't you?
Old 09-18-2010, 11:15 PM   #5
Norcal
Senior Member
Ground & a neutral are two different things. A 2 conductor w/ ground NM cable is fine, just have to reidentify the white conductor as a hot...
Old 09-18-2010, 11:18 PM   #6
terabyte
Senior Member
terabyte's Avatar
i really need to fully learn this stuff.
thank you for the heads up.
sorry to the OP for steering you wrong
Old 09-18-2010, 11:19 PM   #7
terabyte
Senior Member
terabyte's Avatar
just for the record. for a 240 welder you do need a 3 conductor wire ?
and the 3rd conductor can be slightly smaller than the other two?
Old 09-19-2010, 01:02 AM   #8
AMCguy
Senior Member
AMCguy's Avatar
You do not need a three conductor wire. You need a two conductor wire. The ground which is included with either, is not a conductor.
A 10-2 will have the two conductors you need and a ground. In the breaker box and in the outlet, they must be identified as black and red regardless of what color they are actually.
For very little extra. about what you would have paid for 10-3, you could upgrade to 8-2 and then you are set for a 40 amp breaker.
AMCguy is offline   Reply With Quote
Old 09-19-2010, 01:45 AM   #9
Norcal
Senior Member
There no code requirement that one has to identify a white being used as a "hot" red, it just cannot be white or green.
Oversizing a wire kicks in another code requirement in 250.122( B ) NEC 2008 edition.
(B) Increased in Size. Where ungrounded conductors are
increased in size, equipment grounding conductors, where
installed, shall be increased in size proportionately according
to the circular mil area of the ungrounded conductors.
The 10 AWG grounding conductor in a 8/2 NM cable will not comply with that code section.
Old 09-19-2010, 10:01 AM   #10
Boyd Who
Senior Member
Boyd Who's Avatar
My electrician wired up my 3 welder plugs with 10-2 wire on individual 30A breakers.
Boyd Who is offline   Reply With Quote
Old 09-19-2010, 10:41 AM   #11
george4
Senior Member
My Hobart 187 mig runs fine on 30 amps. But when I picked up 225 stick I had to upgrade to 50 amps. As long as you are starting fresh, you may want to consider 50 amps. I think most welders in this range use the same plug. 6-50?
george4 is offline   Reply With Quote
Old 09-19-2010, 11:53 PM   #12
fflintstone
Senior Member
fflintstone's Avatar
Most welders and plasma cutter, use a 50A plug. Just go with 6-2 cable and the 50A plug NOW, and you are ready for any potential upgrades
fflintstone is offline   Reply With Quote
Old 09-21-2010, 12:32 PM   #13
alecmcmahon
Senior Member
alecmcmahon's Avatar
Just thought I throw this in the mix, I emailed Hobart about what they recommend for running their Hobart 210 Welder and they replied.
Quote:
The recommended circuit size is a 40 amp breaker with #8 wire for an Ironman 210 or the Handler 210.
Regards,
Keith McQuown
Manager, Technical Support
Hobart Welding Products An ITW Company
600 W. Main St.
Troy, OH 45373 USA
1-800-332-3281 Office
1-937-332-4804 Fax
keith.mcquown@hobartwelders.com
www.hobartwelders.com
Please consider the environment before printing this email.
-----Original Message-----
Sent: Monday, September 20, 2010 5:12 PM
To: INFO-Hobartwelders
Subject:
What size breaker and wire is required off a garage sub panel to safely run the Hobart 210 Welder?
alecmcmahon is offline   Reply With Quote
Old 09-22-2010, 01:13 PM   #14
mefarri
I checked my Lincoln 180MIG and Miller Econotig and the lincoln calls for a 40amp and the Miller for an 80.
mefarri is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
