Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 10-05-2010, 01:29 AM   #1
rvr6000
Senior Member
rvr6000's Avatar
Default When is it too cold to run air compressor?
Anyone know what the lowest temperature (ball park) is that one can run their air compressor without causing any damage to the pump?
I have a 5hp - 60 gallon CH but have not been able to find anything in the manual regarding safe operating temperatures.
Thanks.
rvr6000 is offline   Reply With Quote
Old 10-05-2010, 02:09 AM   #2
jwillis
Default Re: When is it too cold to run air compressor?
I don't know if it makes that much difference as long as it is inside a garage. The ones at the gas stations run all winter and some of them are outside.
jwillis is offline   Reply With Quote
Old 10-05-2010, 05:41 AM   #3
Kevin54
Senior Member
Kevin54's Avatar
Just make sure you have it drained out before the temps start dropping down below freezing. By that, I mean the tank itself and any water traps you may have. Other than that, I wouldn't worry about running it while it is cold.
Kevin54 is offline   Reply With Quote
Old 10-05-2010, 06:06 AM   #4
35mastr
Senior Member
35mastr's Avatar
A compressor will warm up pretty fast in any temps.
__________________
If I could only remember what I have already forgotton.
Mac tools For Sale Here
George
35mastr is offline   Reply With Quote
Old 10-05-2010, 07:37 AM   #5
z28snksknr
Senior Member
z28snksknr's Avatar
It's actually more efficient at low temps because the air density is higher
__________________
Quote:
Originally Posted by qmt2 View Post
Can I come over and lay naked in your screwdriver drawers?
My garage renovation: http://www.garagejournal.com/forum/s...ad.php?t=43030
My '54 Ford Resto:
http://www.garagejournal.com/forum/s...ad.php?t=62416
z28snksknr is offline   Reply With Quote
Old 10-05-2010, 12:08 PM   #6
m.james
Senior Member
I don't believe it matters what the temperature is and plus at lower temperatures the air is more dense so it won't have to work as hard.
m.james is offline   Reply With Quote
Old 10-05-2010, 12:14 PM   #7
lametec
Senior Member
lametec's Avatar
As long as the oil in the pump is still liquid you're good to go.
lametec is offline   Reply With Quote
Old 10-05-2010, 12:15 PM   #8
nate379
Won't cause damage, but if it's fairly cold... -10, -20, -30, etc just keep an eye on it when it first starts up as it may slip the belt.
Synthetic oil would be a good idea.
nate379 is offline   Reply With Quote
Old 10-05-2010, 01:02 PM   #9
tatra
Senior Member
tatra's Avatar
i would drain it after use so next start up in the cold it doesn't have any load on it .............mine would trip the breaker ..........after the first cycle it was usually warm enough to overcome any resistance to pumping.........had an old interior car warmer set up at one ...........found it easier and cheaper to just drain it when finished..........
tatra is offline   Reply With Quote
Old 10-05-2010, 03:11 PM   #10
Gary S
Senior Member
The owner's manual for my compressor calls for different weight oil for different temperatures, and synthetic oils flow better at low temps than mineral oils.
From my manual
3-32 degrees F SAE10
34-79 degrees F SAE20
Above 80 degrees F SAE30
Gary S is offline   Reply With Quote
Old 10-05-2010, 03:35 PM   #11
A_Pmech
A_Pmech's Avatar
When it won't start it's too cold.
That said, using the proper oil for the temperature will reduce wear and make starting easier, as others have said.
__________________
Your Finest Hammer
Building The Paulding Racer - My Blog
My Garage Machine Shop
Quote:
Originally Posted by Sir Stanley Hooker
One stroke to produce power and three strokes to wear it out.
A_Pmech is online now   Reply With Quote
Old 10-05-2010, 04:36 PM   #12
StingRay
Senior Member
I've run mine in -40. I just bump the on switch for an instant to get everything moving a couple of times and then turn it on to pump up.
StingRay is offline   Reply With Quote
Old 10-05-2010, 09:43 PM   #13
strelnik
Senior Member
Quote:
Kevin is DEFINITELY right, draining is super important!
Rule of thumb I have heard:
1. if it's a diaphragm compressor, NEVER below 40 degrees.
2. If it's a piston compressor or a swash plate compressor, be sure about oil level, run a few short bursts if the temp is 5 degrees or below, maybe 5-10 times, then run normally, keeping it running as long as possible to enable heat build-up to get rid of any moisture in the oil
strelnik is offline   Reply With Quote
Old 10-05-2010, 09:56 PM   #14
kams1973
Senior Member
kams1973's Avatar
Using the proper oil is definately the determining factor. Also methanol in system to prevent any condensation from freezing.
kams1973 is offline   Reply With Quote
Old 10-05-2010, 10:14 PM   #15
Jefflitzy
Check the pour points on synthetic oils I have found in some applications semi-synthetic oil will pour at a colder temp -41 syn vs -45 for semi-syn.
Jefflitzy is offline   Reply With Quote
Old 10-05-2010, 10:38 PM   #16
Identaltech
Senior Member
Identaltech's Avatar
When you spit on the floor and it freezes before it hits the ground, It's to cold to be out there.
Turn up the heat!
I did have a dental office with the compressor in a unheated space and we just installed electric plate heaters on the motors and it would keep the oil warm enough to keep it from tripping the breaker
Identaltech is offline   Reply With Quote
Old 10-05-2010, 10:55 PM   #17
ebfabman
I've always used an old hair dryer on the pump to warm it up in the mornings when its cold. It seems to work real good.
ebfabman is offline   Reply With Quote
Old 10-05-2010, 11:58 PM   #18
e-tek
Senior Member
e-tek's Avatar
Quote:
HMMMM.....NOW THAT I'D LIKE TO SEE!!!!!!
e-tek is offline   Reply With Quote
Old 10-06-2010, 12:17 AM   #19
StingRay
Senior Member
LOL when it's -40 you can hold a tiger torch on a piece of metal that heavy and it'll take quite a while for it to actually warm up. The air coming out of a hair dryer when it's really cold here is still probably below freezing.
Old 10-06-2010, 08:35 AM   #20
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Quote:
This is a real bad plan. Now you have compressed air between the tank check valve and the head of the compressor, the next start the compressor is starting on a load or the very least, a partial load, and having to work harder. This is assuming you have a pressure switch operated head pressure relief valve, which most compressors do.
Quote:
It sounds like you have problems with your compressor. If there is pressure sitting on the head after shutdown, the head pressure relief is not doing its job. And if the pressure builds up on the head while it is sitting, the tank check valve is leaking. There is absolutely no good reason to completely de-pressurize a compressor tank while it is sitting. The pipe from the tank check valve to the head should be automatically depressurized by the head pressure relief valve, either on the pressure switch or on more expensive commercial models, a centrifugal or oil pressure operated valve dumps the pressure.
Charles
Charles (in GA) is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
