Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 10-05-2010, 07:35 PM   #1
fergie_1977
fergie_1977's Avatar
Question How did you "hide" your breaker panel? Post your pics here.
If you closed in (hide) your breaker panel...post a pic here.
As usual, I'm coming to u fine folks for valuable input.
I'm looking at replacing the old subpanel in my 24x24 garage.
I'm closing in the walls with OSB (chipboard). I will mount the new panel where the old one is and clean up a lot of terrible terminations.
I want to close in the panel and have it out of sight.
Of course it has to be easily accessible.
Should I just build a 2x4 box frame around it and slap some doors on?
Post your pics here so we can discuss.
Thanks everybody!
Fergie
__________________
Fergie in Canada
fergie_1977 is offline   Reply With Quote
Old 10-05-2010, 08:11 PM   #2
Ford12508
Senior Member
Default Re: How did you "hide" your breaker panel? Post your pics here.
Make something so it matches the near by cabinets or your tool box. I dont have any pictures and am too lazy to take any, but in my basement, the box is covered with a wood that matches a shelf and the pool table. The door is 1" of molding that has stained glass on the inside. It really looks good, but it costed a decent amount also for the stained glass.
Ford12508 is offline   Reply With Quote
Old 10-05-2010, 08:38 PM   #3
trbomax
Senior Member
trbomax's Avatar
Code says you cannot do that. The panel must have (I believe) 3 feet of clear and open space in front of it.
trbomax is offline   Reply With Quote
Old 10-05-2010, 09:20 PM   #4
tfi racing
Senior Member
tfi racing's Avatar
Quote:
Really?As long as the decorative door swings open 90 degrees and does not impede the removal of the panel cover in any way,it is permissable,at least on this side of the border.
tfi racing is offline   Reply With Quote
Old 10-05-2010, 10:38 PM   #5
79firebird
Senior Member
Most people i know just put a poster on the panel if it has a cover for it
79firebird is offline   Reply With Quote
Old 10-05-2010, 11:43 PM   #6
Norcal
Senior Member
Please note that the OP is in Canada, the CEC has many rules that differ from the NEC, 1 difference is that under the NEC a horizontally mounted panel is prohibited, in Canada it is quite common to do so because of another rule......
Norcal is offline   Reply With Quote
Old 10-06-2010, 12:28 AM   #7
Aceman
Senior Member
Thanks everybody!
Fergie
I can understand trying to hide a panel in a home, but in a shop?? Are doors really going to look any better than just painting the panel cover to match??
Aceman is offline   Reply With Quote
Old 10-06-2010, 08:03 AM   #8
thdewey
Senior Member
thdewey's Avatar
Hide.....Really.
Yesterday, I found something proped over the panel and I thought "What the hell was I thinking... Remember that your panel box is a piece of SAFETY EQUIPMENT. DO NOT HIDE IT!!!! If you are getting shocked, someone (who might not be familiar with your shop) will need to find it quick.
Now saying that, you can coordinate the color/design to better blend in in a pleasing way. You could make another outer door that matches as described above but make it oversized and make sure it won't impeed access to the breakers.
Good luck and please post a picture of your finished product.
__________________
Work safe my friends!
Jeep Garage progress http://www.garagejournal.com/forum/s...0792&showall=1
thdewey is offline   Reply With Quote
Old 10-06-2010, 11:15 AM   #9
sberry
Senior Member
sberry's Avatar
I have a dry erase board covering the one in my office, wall space is at a premium.
sberry is offline   Reply With Quote
Old 10-06-2010, 05:17 PM   #10
reinhardt
Senior Member
being in a shop, i would recommend painting it w/ chalkboard paint. it's metal so u can stick magnets to it, and w/ the chalkboard paint you can write notes on it. best of all, it isn't hidden so it's easily accessible.
that's what i would do anyways.
reinhardt is offline   Reply With Quote
Old 10-06-2010, 05:32 PM   #11
haugy
Senior Member
haugy's Avatar
How do you "hide" your breaker panel?
Turn off the lights.
haugy is offline   Reply With Quote
Old 10-06-2010, 05:58 PM   #12
652plus2
Junior Member
I did this with mine...
The other one too...
652plus2 is offline   Reply With Quote
Old 10-06-2010, 07:50 PM   #13
frank_c
Senior Member
that sounds like an OSHA thing. i know all the panels at work are marked with the three-foot clearance warning.
frank_c is offline   Reply With Quote
Old 10-06-2010, 08:06 PM   #14
haugy
Senior Member
haugy's Avatar
Permission to steal idea?
Old 10-06-2010, 08:12 PM   #15
Norcal
Senior Member
Quote:
It's a NEC thing...
Old 10-06-2010, 08:13 PM   #16
trbomax
Senior Member
trbomax's Avatar
Maybe its just a michigan thing. I just looked thru all my building stuff and couldnt find it,But I remember a conversation about it with the inspecterguy.He said I couldnt put a bench in front of it either and very adimant about the "clear space" thing.
Old 10-06-2010, 09:36 PM   #17
sselander
Senior Member
Here in CT, we wanted to put the panel in the laundry room on the 2nd floor for our new home
We were told the code would not allow it (due to clearances), so it is now in the hallway
sselander is offline   Reply With Quote
Old 10-06-2010, 09:42 PM   #18
monstergarage87
Senior Member
monstergarage87's Avatar
Heres mine... built a little box around it out of bead board to hide the wires and painted it the same color. Blends right in but very easy to access everything since the panel cover holds everything on. Cover pops off and the panel slides off.
monstergarage87 is offline   Reply With Quote
Old 10-06-2010, 10:10 PM   #19
Stuart in MN
Senior Member
Stuart in MN's Avatar
Yes, you need clear working space in front of the panel, but something like a door or a picture or a mirror on hinges that will open up fully against the wall should be okay as it won't obstruct that working space. It's possible that some inspectors won't allow it, and it's also a reasonable argument that the panel shouldn't be hard to find in the event someone needs to find it right away.
If it were me I'd leave it as is, or maybe just paint the front cover of the panel to suit the decor of the room.
Stuart in MN is offline   Reply With Quote
Old 10-06-2010, 10:34 PM   #20
652plus2
Junior Member
Quote:
Permission granted. Krylon spray bombs and stickers from ebay...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
