Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 10-07-2010, 02:53 PM   #1
davidh73750
davidh73750's Avatar
Default concrete guesstimate for 30X50 pole barn
What have you guys spent on 30X50 slabs or 30X40? I know I'll have to get some dirt work done, probably use that fiber mesh to prevent cracking, 4" slab.
The pole barn guys gave me an estimate on the shop and now Im trying to see what concrete will cost. guessing 5k? I know there are several factors. Around here I've seen too many that should've had done some dirt work to elevate it a little and now when it rains water comes in the bottom of the garage doors.
davidh73750 is offline   Reply With Quote
Old 10-07-2010, 03:02 PM   #2
Tscott
Senior Member
Tscott's Avatar
Default Re: concrete guesstimate for 30X50 pole barn
I have 36 x 60 and I paid right around $8000 for the slab. It figured out to around $180 per cubic yard in place. All the quotes i got were in the range between $180-$200 per yard.
Tom
Tscott is offline   Reply With Quote
Old 10-07-2010, 03:59 PM   #3
Mike in Ohio
Senior Member
Mike in Ohio's Avatar
I had a 30x48 done 2 years ago in ne ohio. plastic vapor barier 3-4 inches of gravel wire mesh reinforcement 4inches thick in 3/4 of it 6 inches thick where the lift will someday go. Cost was $4500. I did all of the dirt work, building up and compacting. All he had to form was the doorways.
__________________
I am trustworthy, loyal, and helpful. But I struggle with obedient
Mike in Ohio is offline   Reply With Quote
Old 10-07-2010, 04:25 PM   #4
Kev442
Senior Member
Kev442's Avatar
Paid 5500 for about that much. They finished leveling to their satisfaction using 2-3 yards of fill I had laying there, but 90% of the dirt work was done and compacted.
Kev442 is offline   Reply With Quote
Old 10-07-2010, 04:27 PM   #5
slice
Senior Member
I need to move North just got quoted 52x40 slab on pad. 4" thick 2x4 outside beams 2 1x1 cross beams vapor barrier etc..
my quotes ranged from
21k to 8500. avg 10 k
good luck...
texas
slice is offline   Reply With Quote
Old 10-07-2010, 05:31 PM   #6
Kevin54
Senior Member
Kevin54's Avatar
You'll probably end up closer to 5" thick by the time it is formed. At that you are looking at 23.15 yards of concrete. The last time I checked it was running right at $100/yd. + delivery. Then you have to take in consideration gravel for a base, concrete for footers or at least thicker where the footers are if a slab. I know that in my area for something that size and being worked by someone else you are looking at $6000-$9000. And maybe more as some of ones that do flatwork think that everyone else's work is bad and theirs is the best.
If you are not going to work the concrete and have someone else do it, SHOP AROUND with different contractors. It is unbelievable the difference is price between contractors. I had a 20'x20' foundation put in for the wifes building, concrete slab, sidewalk completely around the house, and save over $8000 over local contractors. I went out of town to save that kind of money.
Kevin54 is offline   Reply With Quote
Old 10-07-2010, 06:14 PM   #7
mad57
Senior Member
mad57's Avatar
my 30x80... if your talking now which was around the time i did it was getting colder hot water charge, and fiber mesh, vapor barrier, and 4500psi mix at 5 in was $9000 soup to nuts power trowel i did mostly myself as the contractor wanted to go home. just last yr this was done in nj good luck. p.s pole barn co wanted closer to 16gs so def shop around... lots of good masons out there needing work.
__________________
Work to live not live to work.
Iam also vice president of my car club: Wickedridesnj.com check it out!!!!
mad57 is offline   Reply With Quote
Old 10-07-2010, 07:34 PM   #8
Nighttrain
Senior Member
Nighttrain's Avatar
Rebar? any beams around the edges or across the span? elevation issues? All come in to the price. For a flat 4" slab with no fill dirt or metal I would say $2/$3 sf. All the above options could go up to $4/$6 sf, in my area (Texas) so your 30x50 would be anywhere from $3k to $9k.
Nighttrain is offline   Reply With Quote
Old 10-07-2010, 09:49 PM   #9
fflintstone
Senior Member
fflintstone's Avatar
I am going my 32 X 48 myself, 4” thick, comercial fiber in the concrete. 20 yards @ $110 a yard including sales tax. Plus power screed and power trowel rental. Even In Michigan with massive unemployment, the concrete people still want a minimum per sq ft. I can not hire one at a fixed rate for a “day of labor”
fflintstone is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
