Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 10-08-2010, 10:29 PM   #1
stricht8
Senior Member
Default Garage door window covering
What can I cover my garage door windows with so as to get light in but keep prying eyes out? I was thinking about spraying some of that frosted glass stuff on the windows. Does that hold up against moisture and condensation?
stricht8 is offline   Reply With Quote
Old 10-08-2010, 10:32 PM   #2
7echo
Senior Member
Default Re: Garage door window covering
I cut some frosted plexi to set in the window. Works great and is easy to do, as well as being easy to remove when needed.
7echo is offline   Reply With Quote
Old 10-08-2010, 10:35 PM   #3
stricht8
Senior Member
Quote:
How did you affix it to the window so it doesn't fall out when the overhead door opens.
Old 10-08-2010, 10:51 PM   #4
Matt M, PA
Senior Member
Matt M, PA's Avatar
How about mirrored window tint?
Matt M, PA is offline   Reply With Quote
Old 10-08-2010, 11:00 PM   #5
stricht8
Senior Member
Quote:
Yes but if they put their face to the glass then they can see inside.
Old 10-08-2010, 11:07 PM   #6
stricht8
Senior Member
Actually, I could screw it to the wooden part of the door. I'm starting to like that idea.
Old 10-08-2010, 11:18 PM   #7
urgti
Junior Member
urgti's Avatar
They make frosted glass film you apply like window tint. I put this in my bathroom on the lower portion of my double hung window.
urgti is offline   Reply With Quote
Old 10-08-2010, 11:20 PM   #8
WiBad
Window film does a good job --> (click here)
WiBad is offline   Reply With Quote
Old 10-08-2010, 11:57 PM   #9
Greatbear
Senior Member
Greatbear's Avatar
I use the prismatic diffuser plexi used for drop-in fluorescent lighting. It's easy to cut and pretty cheap. It can be held in place with small velcro pads on the corners that will allow you to remove the pieces for cleaning. It does not block light from coming in, and actually helps scatter it around the shop. It also totally obscures the contents of the building.
Greatbear is offline   Reply With Quote
Old 10-09-2010, 01:05 AM   #10
PCO6
Senior Member
PCO6's Avatar
This isn't perfect but it works well for me. I cover my garage door windows from the inside with four 1/4" masonite panels that are white on the inside and black on the outside. They are up at all times when I am not in the garage. They are down when I want natural light during the day and up at night when I am working in the garage. From the outside, you can not see that the garage lights are on when I am working inside at night. The panels fit into a plastic lattice slot along the top edge and are fastened with velcro along the bottom edge. It takes about 30 seconds to remove or install all 4 panels - no tools involved.
PCO6 is offline   Reply With Quote
Old 10-09-2010, 01:16 AM   #11
PCO6
Senior Member
PCO6's Avatar
^^^ Here are the materials I used. The total cost was about $25 so it was a pretty inexpensive solution.
Old 10-10-2010, 09:06 AM   #12
johnny
I had this made up, you can see in if you put your face up to the window, you can see out with no issues.
johnny is offline   Reply With Quote
Old 10-10-2010, 08:32 PM   #13
Munich77
Senior Member
Quote:
That stuff works great, is cheap and easy to apply. I used it years ago at my parent's place to cover up a glass window.
Munich77 is offline   Reply With Quote
Old 10-10-2010, 08:43 PM   #14
Brew62
Senior Member
Brew62's Avatar
Quote:
That looks really cool, any pictures of the rest of your garage?
Brew62 is offline   Reply With Quote
Old 10-10-2010, 09:26 PM   #15
DIC
Senior Member
DIC's Avatar
I used the frosted film .....Holds up good ...Its been there about 25 years
__________________
Shoot Low Sheriff they're riding Shetlands !
DIC is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
