#1 |
Senior Member
Some of you might remember my homemade bomb, ahem, I mean paint booth. After a couple of days and several trips to the hardware store, here's what I came up with.
I made a fan with an out-board motor. Kind of follows the design of an axial fan in that the motor spins the blades via a belt (thanks to byrdman's idea). The fan housing was made of wood, while the blades were the plastic ones from the box fan (no sparks if they hit). The shaft was steel and turned in aluminum pillow blocks with copper liners (again, no sparks). I was able to fit a filter on either side of the fan blades for optimum cleaning affect. It all worked very well I thought. And the high speed of the fan actually worked better to exhaust the booth than when I used two box fans. Thanks to all for you inputs and keeping me safe. Here are a few pics of the fan after use and of what I was painting (race bike bodywork). cheers, bob |
#2 |
Senior Member
Looks good!
__________________
- Luke |
#3 |
Senior Member
NICE! I need to build one now. Thanks for posting your results.
#4 |
Senior Member
Wow, nice work!
#5 |
Nice job on the reworked fan!
#6 |
Senior Member
WELL EXECUTED sir!
It looks as though you are pulling air out of the booth, right? Are you filtering the input hole?
__________________
-"byrdman" |
#7 | |
Senior Member
Quote:
Yes, it is a negative pressure setup, but I'm not filtering the incoming air. I'm not too worried about the finish on the bike. I fully expect to drop the bike anyways. If I never lay it on the ground, then I'm not riding the piss out of it
#8 |
Senior Member
That is WELL thought out! Looks great!
__________________
2003 Black Ford Lightning Build Number: 3105 of 4270 - Born on: 4/10/03 |
#9 |
Post Lurker
I have a window directly in front of my paint booth. I put a furnace filter in the window and pull the incoming air through it, into the booth. Squirrel cage is in the roof of the booth.
Nice re-work on the fan... much better. |
#10 |
Good job!
I've seen pillow blocks at the parts store and I know what they do but I could never really come up with an application. I just haven't come across a need for something like that - until now. Thanks! |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| paint booth ducting | paintdaddy | General Garage Discussion | 11 | 02-20-2006 08:30 PM |
| How bad is just normal old concrete paint? | Chargin8 | Flooring | 8 | 11-14-2005 05:53 PM |
| Actual part number needed for the good epoxy floor paint | muddy | General Tool Discussion | 4 | 08-21-2005 09:01 AM |
| Poor man's paint booth | rjspitz | General Tool Discussion | 16 | 04-14-2005 12:39 PM |
| Paint Booth | 428 | General Garage Discussion | 18 | 01-31-2005 09:52 AM |
