Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 10-19-2010, 12:47 PM   #1
Bolster
Senior Member
Bolster's Avatar
Default Clueless: How to Mount Chuck on Rotary Table?
I'm a wanna-be machinist newbie. I have a small mill (no lathe). I obtained this small 6" rotary table (a Griz product). I would like to get a small 3-jaw chuck mounted to it, but have NO CLUE as to how to choose a chuck that will be compatible with this RoTab. Am I looking for a 6" chuck? Or 4"? I can't go too "tall" or I waste all my Z axis. I don't even know how the chuck would mount to the RoTab. The hole in the center is a MT#2, would a chuck use the MT? Or attached how?
Can someone guide me to some options regarding how to get a chuck on here, where to find the components needed? I am not looking for gold-plated accuracy. (It's just an inexpensive $900 ChiCom mill with an inexpensive $250 ChiCom RoTab. Not proud of it, but I'm lucky to have it, and it works good enough.) In fact I'd love to buy a chuck used if possible and save some coin. Ideas?
More info on my intended useage of chuck-on-rotab, if you are interested: This RoTab will mount horizontal or vertical. With the RoTab in the vertical position, with its associated tailstock, I believe you can "fake" some lathe operations on a mill. I need to do some small lathe operations with it, which will entail bringing down an endmill to the work and then slowly turning the RoTab. So sort of reverse of a lathe, in this setup the bit is powered and the work is being turned slowly by hand. Yeah, I wish had a lathe but in this obanomy, you make do with what you got.
Alternately, I think I can do some vertical lathing without the RoTab. If the stock is small enough to go into the mill's chuck (5/8 max) and stout enough to hang free, some lathing can be done by clamping a lathe bit in the vise and running it up and down the work using the Z axis. For small work only.
I suppose you could also chuck a larger round piece in the rotab/chuck (with the rotab/chuck in the horizontal position, and the work sticking up vertically), and use an endmill to make bushings, and other short, squat round work, etc. by spinning the work in the rotab/chuck against the endmill.
What would be really helpful is to find a tutorial that discusses how to fake a lathe on a mill...anybody have a source? As I say a lathe is not in my immediate future. Even if I had the $ I do not have the space right now!
__________________
Delmar O'Donnell Bolster. A bona fide Soggy Bottom Boy.
There is no certainty; there are only people who are certain. --Renouvier
Casually collect Proto with pebble field & other Proto Los Angeles items.
Bolster is offline   Reply With Quote
Old 10-19-2010, 01:00 PM   #2
A_Pmech
A_Pmech's Avatar
Default Re: Clueless: How to Mount Chuck on Rotary Table?
There are a number of ways you can approach this. Here are a couple:
The first way, if you want to use a >small< chuck, is simply to buy a chuck with a #2 Morse arbor. They're commonly called "tailstock chucks".
A second method, which I prefer, is to either drill and tap the rotab table to accept extended length chuck back mounting bolts and thru-bolt the chuck to the table. OR, using the T-slots, install a sub-plate on the top of the table, true it up and mill a clearance in the center to roughly locate the chuck back. Then, thru-bolt the chuck to the sub-plate. Dial in the chuck by tapping it around with a hammer until centered.
Edit: Since a picture speaks a thousand words, here's 2,000 words:
__________________
Your Finest Hammer
Building The Paulding Racer - My Blog
My Garage Machine Shop
Quote:
Originally Posted by Sir Stanley Hooker
One stroke to produce power and three strokes to wear it out.
A_Pmech is offline   Reply With Quote
Old 10-19-2010, 01:05 PM   #3
GrantCee
Senior Member
There are several ways. VERY small screw-mount chucks can be mounted with a taper shank, IF you can find one with the proper threads.
The usual method is to obtain a backing plate (adaptor) that is the diameter of the table, then buy a chuck that is at least an inch smaller in diameter. The plate is drilled near the edge to take socket head cap screws that go into t-nuts in the table slots; the chuck is mounted to the plate, then the plate is mounted to the rotab and adjusted for concentricity.
The reason for the undersized chuck is so that you can access the cap screws to tighten them.
(Edit: someone beat me to it!)
__________________
-=[ Grant ]=-
GrantCee is offline   Reply With Quote
Old 10-19-2010, 03:15 PM   #4
Bolster
Senior Member
Bolster's Avatar
Quote:
So, that would be a drill chuck, probably maximum 5/8 capacity, yes? [EDIT: No, I've found them up to 2"] There is no 3-5" chuck with a #2 Morse arbor, I assume? yeah, I'd prefer at least 3" capacity.
Given that your preferred method scares the crap out of me, as a rookie machinist, I'll be working on your second option, the sub-plate. Now where will I go looking for this 4-5" chuck, and what kind of back should it have?
Quote:
Sounds straightforward (and like a lot of fiddling to achieve concentricity, but fiddling is what machinists do, right?). Do I have to make this backing plate, or can it be purchased? And I assume lathe chucks attach in different ways, so what type of (say 4-5") lathe chuck am I looking for?
Can I get reasonable concentricity by chucking up sharpened rods (in quill above and lathe chuck on rotab below) and aligning them? Would that get me within a couple thou?
__________________
Old 10-19-2010, 03:30 PM   #5
Shadowdog500
Senior Member
$9.99 1/2" MT2 Mini-Lathe Drill Chuck from HF
Item # 42340
If they dont have this in the store you can usually get one in the store with a full taper MT2 for the same price.
Chris
Chris
Shadowdog500 is offline   Reply With Quote
Old 10-19-2010, 03:36 PM   #6
Bolster
Senior Member
Bolster's Avatar
Stupid questions retracted...
__________________
Old 10-19-2010, 03:44 PM   #7
murph64
Senior Member
Quote:
Originally Posted by Bolster View Post
So, that would be a drill chuck, probably maximum 5/8 capacity, yes? There is no 3-5" chuck with a #2 Morse arbor, I assume? yeah, I'd prefer at least 3" capacity.
Nope...It's a lathe chuck with a MT mount -
http://www.harborfreight.com/2-inch-...hank-4486.html
Andy
murph64 is offline   Reply With Quote
Old 10-19-2010, 03:59 PM   #8
Bolster
Senior Member
Bolster's Avatar
That's interesting. A 2" capacity and I'm up and running for $30 + shipping. Also, low profile, so it's not using up my Z axis. Interesting!
Why lookie here, Griz sells one too (for more, probably the same thing):
http://www.amazon.com/Grizzly-H5934-.../dp/B0007D2BPW
For a 5" 3-jaw chuck I'm looking at $60 chuck, $35 backing plate, and probably machine shop time to put it all together (don't trust myself to do this accurate type of work, yet).
__________________
Old 10-19-2010, 05:05 PM   #9
A_Pmech
A_Pmech's Avatar
Quote:
Yup. That's a tailstock chuck!
For lathe use, a plain-back chuck requires a back plate to mount up to a lathe and different back plates will allow the chuck to be used on different machines with different mounting schemes. Here's an example of a plain-back chuck with it's back plate (D1-6):
To install a plain-back chuck on a rotab sub-plate, you don't need a lathe back plate. The sub-plate IS the back plate that adapts the chuck to the rotab.
Begin by getting ahold of a section of 3/4" to 1" aluminum. Install it on your rotab using socket head cap screws in counterbored holes deep enough to clear the face by .050" or so.
Then, face the entire top of the sub plate just enough to clean it up. Locate the chuck on-center on the sub-plate and transfer the mounting bolt locations to the sub-plate. Remove the sub-plate, drill and tap the holes and re-mount.
Now, install your chuck, tighten down the sub-plate bolts and snug up the chuck bolts. Put the rotab in neutral and swing it around with a DTI in the spindle and a 1" or so hardened pin in the chuck jaws. Tap things concentric with a small soft-faced hammer, then tighten down the chuck mounting bolts.
__________________
Your Finest Hammer
Old 10-19-2010, 06:06 PM   #10
larry_g
Senior Member
Have you found the Chaski machining site yet? There is a thread of this same question going in grneral. Also the home shop machinst site is perty good for this kind of stuff.
As far as getting a chuck on there get a 4 jaw that has a flat back and 4 through holes for mounting to the backing plate. Use T-nuts to bolt it directly to the rotab.
lg
no neat sig line
__________________
My Shop build thread
Great minds talk about ideas, average minds talk about events, small minds talk about people.
Wise people talk because they have something to say. Fools talk because they have to say something.
larry_g is offline   Reply With Quote
Old 10-20-2010, 02:00 PM   #11
Bolster
Senior Member
Bolster's Avatar
Considering mounting this 6" wood chuck (not ferret, not skunk, not groundhog...but wood chuck) to my 6" RoTab. $58. Very low profile, won't eat up my Z axis. No intermediate/sub-plate, just drill four holes in the chuck and mount through to the T-slot nuts in the RoTab.
http://www.grizzly.com/products/4-Jaw-Chuck/G1082
What do you think?
Am I missing something important, here?
Probably will lathe some sort of indexing device so I can align the centers easily.
@ larry: Thanks for the tip on the Chaski thread.
__________________
Old 10-20-2010, 02:31 PM   #12
larry_g
Senior Member
What do you think?
What your missing in the wood chuck is the T-slots the jaws move in. It looks like the jaws on the wood chuck have a bolt from the back. If it was free and you could try it, then maybe, but I would not put out money when the same money should be good for a proper jaw.
lg
no neat sig line
__________________
Old 10-20-2010, 05:52 PM   #13
cageek
Junior Member
If you want to go from MT2 -> Threaded interface (1" x 8TPI, or 1.25" x 8TPI) -> Threaded Wood Chuck, google "Hold Fast Chuck Reversing adapter". It is used for a vacuum chuck system to mount a wood chuck in an MT2 tailstock, and sold separately for about $33, but might work for your purpose as well. It might save you from drilling your chuck (and associated centering problems). I suspect it will also hold your chuck away from the table a little bit, which might be a pain. I suppose a chuck mounted might rotate on you, though I doubt it (weight down and all). Basically, you're making your own tailstock chuck.
BTW, non-self centering chucks are a serious pain on a wood lathe for most operations. But I know next to nothing about machining.
cageek is offline   Reply With Quote
Old 10-20-2010, 07:55 PM   #14
Eric Commarato
Senior Member
Here is a good website you will enjoy with lots of machinist equipment and references. I think he has some methods to anchor a chuck to a rotary table...
www.micro-machine-shop.com
Eric Commarato is offline   Reply With Quote
Old 10-20-2010, 08:27 PM   #15
Bigpigdave
Senior Member
Bigpigdave's Avatar
Why not? How can you learn if you don't mess something up every once in a while. Almost all mistakes can be fixed and the fixing is what really teaches you to be a good machinist. Take your time, visualize your cuts ahead of time and have at it. You can do it!!
Also you were asking about turning stock on a mill. You can mount your work in the mill spindle (collet is best) and mount a lathe cutting tool on your mill table and spin the work past the cutting tool. This only works for short parts, you have to have room to move past the cutter. I have done this in the past when all of the lathes in the shop were tied up.
Also get an Enco Master Catalog and take a look. The amount of tooling available for machining is incredible and Enco sells almost all of it (at good prices). Look for things that can make your projects easier and decide if you should buy one or could you make your own. There are also some really good books on machining available (check out the 3 book Machinist's Bedside Reader series).
Good luck and keep at it, every mistake is another chance to learn something new. Dave
__________________
"Smokey Yunick was the Da Vinci of the 20th century"
Last edited by Bigpigdave; 10-20-2010 at 08:34 PM. Reason: Crappy spelling, added info
Bigpigdave is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
