Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 10-20-2010, 10:10 AM   #1
nismomans13
Senior Member
Default Air Compressor pressure drop...whats going on.
So i'm trying to figure this out. I have a 60 gallon 2 stage compressor, 16cfm @90psi. If I open my regulator to 90psi and use say my die grinder, if I hold it in for about 3 seconds i'm down to 60psi of pressure at the regulator.
The regulator is 3/8 to 1/4in reducer, and the air hose is 1/2 in. Could my problem simply be I should use a smaller air line to match the output of my regulator. I'm thinking that the 1/4in to 1/2 in is creating a bottle neck and thats where my pressure drop is coming from.
nismomans13 is offline   Reply With Quote
Old 10-20-2010, 10:13 AM   #2
KenC
Senior Member
Default Re: Air Compressor pressure drop...whats going on.
What is your tank pressure that you are regulating? With some regulators, you have to set the pressure with the air moving.
KenC is offline   Reply With Quote
Old 10-20-2010, 10:23 AM   #3
MattT
Senior Member
If the regulators 1/4" output was causing a pressure drop you wouldn't see that at the gauge which is upstream of the restriction.
If the tank pressure isn't falling off the regulator is most likely your problem. Less likely is something between the tank and regulator.
MattT is offline   Reply With Quote
Old 10-20-2010, 11:19 AM   #4
z28snksknr
Senior Member
z28snksknr's Avatar
It sounds like you need a larger regulator. Yours is not allowing sufficient flow during use to maintain the downstream pressure.
In other words, your demand on the system is greater than the regulator can flow at that setpoint, so the pressure downstream of the regulator is lower. A regulator that has a higher flow capacity should be able to hold a tighter setpoint during use.
__________________
Quote:
Originally Posted by qmt2 View Post
Can I come over and lay naked in your screwdriver drawers?
My garage renovation: http://www.garagejournal.com/forum/s...ad.php?t=43030
My '54 Ford Resto:
http://www.garagejournal.com/forum/s...ad.php?t=62416
z28snksknr is offline   Reply With Quote
Old 10-20-2010, 11:31 AM   #5
larry_g
Senior Member
Your load is simply flowing more air than your system can deliver. I would suggest that you bypass the regulator and make sure that all fittings between the tank and the tool be as large as is practical. Then if you are above the max operating pressure of the tool then back off the switch to cut out at the max pressure. If you understand that pressure is caused by the restricting of flow then you'll understand that what you are seeing is not unusual.
lg
no neat sig line
__________________
My Shop build thread
Great minds talk about ideas, average minds talk about events, small minds talk about people.
Wise people talk because they have something to say. Fools talk because they have to say something.
larry_g is offline   Reply With Quote
Old 10-20-2010, 11:32 AM   #6
nismomans13
Senior Member
Tank pressure is 165psi and this is the regulator i'm using
My old craftsman 33 gallon had the same problem, but not NEARLY as bad, I would set it to 100psi to run a tool at 90, i'm setting this to almost 130psi to get 90psi at the tool. The regulator on my old compressor was a Husky. I don't see what could be restricting air pressure before the regulator, it comes out of the compressor, makes a 90 and its a straight 3/8id pipe to the regulator.
Larry, i'm not entirely sure what you mean. Do you mean make my air compressor tank pressure what I operate my tools at? If so that sorta defeats the purpose of the compressor i bought.
What are you guys using, regulator wise, and what kind of pressure drops are you seeing?
Old 10-20-2010, 11:50 AM   #7
lametec
Senior Member
lametec's Avatar
There's only a couple things that can cause this:
1. The regulator is starving for air (i.e., compressor doesn't supply enough).
2. The regulator is starving the tool (i.e., regulator doesn't flow enough).
With that said, the words "die grinder" and "1/4" reducer" should never be used in the same sentence unless there's a "bad idea" somewhere in there too. Die grinders use a lot of air. However, with that said as well, the 1/4" reducer is not your problem, as it sits after the regulator.
Why would you put a 1/4" reducer leading into a 1/2" hose, though? At least go directly from the 3/8" output of the regulator into the 1/2" hose.
lametec is offline   Reply With Quote
Old 10-20-2010, 11:59 AM   #8
larry_g
Senior Member
[QUOTE=nismomans13;1125137]Tank pressure is 165psi and this is the regulator i'm using
QUOTE]
I suggest that you try what I said as to prove that the regulator is what is restricting your flow. Pop the top off that regulator and look at the small hole all your air has to pass through. I run my system at ~110 psi and do not use a regulator unless needed.
What was your purpose of buying a 2 stage compressor?
lg
no neat sig line
__________________
Old 10-20-2010, 12:10 PM   #9
jam0o0
Senior Member
it's how you've set the regulator. you set regulators with the air moving through them. who cares what the reg says when you're not using the tool.
jam0o0 is offline   Reply With Quote
Old 10-20-2010, 12:20 PM   #10
larry_g
Senior Member
Quote:
I care a lot what the static pressure is if there is a cylinder at the other end of the line that needs a controlled force. I also care if it a relieving or non-relieving regulator. If your regulator is big enough it will show minimal drop between static and dynamic.
lg
no neat sig line
__________________
Old 10-20-2010, 12:37 PM   #11
MattT
Senior Member
I'm running a SMC 3000 (3/8") series. Get maybe 5 psi drop between static and running my IR Thundergun which is my highest demand air tool. I've got a 5 micron filter before it so the reg might not be responsible for all of the drop.
Personally I'd go with a full size 3/8" regulator from one of the name brand pneumatics companies. Watch the max input pressure because a lot of them are only rated 150 psi.
Old 10-20-2010, 01:02 PM   #12
ZRX61
Senior Member
ZRX61's Avatar
What he said, I ALWAYS set regulators with load being applied.
__________________
Tool Afflictionardo
I'd rather have an "airplane guy" work on my keyboard than have a "keyboard guy" work on my airplane.
ZRX61 is offline   Reply With Quote
Old 10-20-2010, 02:24 PM   #13
Jeepguy
milman
Jeepguy's Avatar
this might be a dumb question, but how old is that filter regulator unit? you might just need to replace the filter element in that unit. or just to see if it is the element take the bowl off remove the element, put it back together and see if it maintains pressure.
__________________
OOPS....let me try that again.
Jeepguy is offline   Reply With Quote
Old 10-20-2010, 07:38 PM   #14
nismomans13
Senior Member
The filter/regulator is brand new. I'm going into a 1/4in fitting because well all my air tools are 1/4in and thats all i had and its all i've used from day 1. I don't understand what my reasoning for buying a 2 stage compressor has to do with anything, but I bought it because of the cfm rating and price.
I did NOT set the regulator with air moving through it so I suppose that could be my problem. I also had a couple small leaks in the piping that i've fixed but haven't fired up the compressor to verify that yet. I'll give it a try tomorrow. But I really can't imaging this compressor doesn't move enough air for a simple blow gun, even the blow gun is causing a serious pressure drop at the regulator. I expect a certian amount of pressure drop but not setting it statically to 90psi and when i run a tool the pressure drops to 65-70 that seems pretty excessive even for my highest consumption air tools.
Old 10-20-2010, 11:06 PM   #15
larry_g
Senior Member
The filter/regulator is brand new. I'm going into a 1/4in fitting because well all my air tools are 1/4in and thats all i had and its all i've used from day 1. I don't understand what my reasoning for buying a 2 stage compressor has to do with anything, but I bought it because of the cfm rating and price..
The reasoning I wanted you to explain is why you bought a compressor capable of 175psi when you probably only need 120. There are plenty of single stage compressors avaiable that will give lots of CFM's. All that electrical energy that you are using to increase the pressure above necessary operating pressure is costly.
This dropping of pressure is simply the regulator not being able to do the job you ask of it.
lg
no neat sig line
__________________
Old 10-21-2010, 12:10 AM   #16
MrMark
Senior Member
MrMark's Avatar
lg
no neat sig line
Why is that? Is the pressure vs. energy consumption a nonlinear curve?
MrMark is offline   Reply With Quote
Old 10-21-2010, 10:27 AM   #17
larry_g
Senior Member
Quote:
Think about what the first thing the compressor does after the air is compressed. It goes to the cooler to remove the heat energy. Then it goes into the secondary cylinder(s). The more the air is compressed, the hotter it gets, the more heat energy that has to be removed. So to answer your question, yes.
lg
no neat sig line
__________________
Old 10-21-2010, 11:22 AM   #18
lwlobo
Senior Member
lwlobo's Avatar
Get a bigger regulator, should take care of it. Pressure difference between static and flow condition are always different, but it should be small. The difference goes down as the quality and size of the regulator go up.
Higher pressure gives you extra storage and flow capabity, but does hurt your effeciency.
lwlobo is offline   Reply With Quote
Old 10-21-2010, 12:06 PM   #19
nismomans13
Senior Member
well i did as larry suggested. I ran my compressor tank pressure down to 100psi. However I did not bypass the regulator, I instead opened it up and allowed it to read 100psi, when I ran my die grinder the gauge on the regulator didn't move one bit.
Now does that mean the regulator is my problem? Since when the tank pressure is 165psi the regulator is dropping pressure 20-30psi while running a tool. Because there is a tank pressure gauge prior to the regulator and that gauge doesn't budge while running a tool which suggests the the pressure in the line is constant until it reaches the regulator.
Looks like a trip to grainger to pickup a 1/2 speedair regulator is in order here.
The other reason for a 2 stage compressor is the fact that it stores more air so to say, my other compressor would run ALL the time. I wouldn't even get one wheel off my truck and it kicked on.
Old 10-22-2010, 08:02 PM   #20
nismomans13
Senior Member
welp as everyone said the cheapo made in china craftsman regulator was the issue. I replaced it with a 1/2in speedaire unit today, opened it to 90psi ran my die grinder and the gauge didn't move 1 psi.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
