Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
Built this cart up about 3 years ago.
For 20 years, my cylinders have been chained against the wall. Always wanted a cart so, finally got at it,and came up with this. ![]() Its made from 100% scrap steel. 1-1/2" X 16 Ga square tube from Yamaha ATV shipping crates, acquired from a local motorcycle dealership. ![]() This was also the first time I have ever gas welded anything. Some parts on the axle are stick welded. The chrome handle come from a clothing rack, that I had been saving for this project. ![]() The holes are for the strap that will hold the tanks in place. The wheels are new wheel barrow wheels with the outside hubs shortened so they don't hang out past the tires. The axle is a piece of 1-3/16 round that was laying around. ![]() After some sandblasting and painting. Don't much care for the color, but had some epoxy primer, and urethane top coat to use up. Wheels clear the floor by 1/8" when the unit is setting, to take the weight off of the tires. ![]() The strap rolls around 3/4" pipe, that sit over 1/2" pins. This setup holds the cylinders so tight to the frame, that you can grab on to them to move the cart around. ![]() The ratchet is a 2" military surplus unit. ![]() Welded a cap over the square tube. ![]() Its really well balanced and a pleasure to roll around to where ever its needed. Sure beats unhooking and moving each tank individually. ![]() ![]() Watch for more stuff, built from the scrap square tube. ![]() -John Last edited by cnc-me; 10-21-2010 at 03:37 AM. Reason: hit the wrong button |
#2 |
Senior Member
You did a really nice job on that. How does that tool box stay in place? When you tilt back the cart for transport do you have to remove it?
#3 |
Senior Member
Nice! That first pic almost looks photoshopped. You have some sweet fab skills.
__________________
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley Lots of Vise Info Vise restoration Tips The Vises of GJ! (dial-up death) Need an old USA made vise? I usually have several in stock. A_Pmech now makes my replacement jaws, ask him! |
#4 |
Senior Member
#5 |
Senior Member
Are the tool box drawers locked shut when the box is closed? or do you have some other method for keeping the drawers from flying open when tipped?
Great Job by the way... obviously some real thought went into the design! |
#6 |
Senior Member
Nice work!!! I like it.
BTW--technically, the nylon strap is not to be used for holding the tanks on..... It can be burnt thru while torching and then the tank can tip over and knock the valve off.... as explained to me by an old welding instructor... Having said that, I bet the tanks do not move when you are moving the system around... Maybe just add a metal chain to the outside.....
__________________
-- Brad -- Currently working on a new garage....foundation dug, footing poured and 4 courses of 12" block complete.... waiting for the mud to dry up... Last edited by bimmer1980; 10-21-2010 at 01:17 PM. |
#7 | |
Senior Member
Quote:
Have to remember to close the top lid, so all the drawers lock though. (ask me how I know) -John |
#8 |
Senior Member
#9 | |
Senior Member
Quote:
I looked at a lot of them, before I came up with this design. -John |
#10 | |
Senior Member
Quote:
I would never be torching that close to the tanks, and if I was the strap would be the least of my worries. ![]() Some commercial units use a strap also. -John |
#11 |
Senior Member
Very nice work. I like the strap settup and also the closed box -- I've always hated how dirty all the torch acessories get laying in the commercailly prdouced carts tray.
| Tags |
| cart, gas welding, scrap steel, square tube, torch |
| Thread Tools | |
| Display Modes | |
