Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 10-26-2010, 12:26 PM   #1
shermanator
Junior Member
Default Wiring a remote shed to run off generator
I have a remote garden shed on my property that is roughly 2000' from my house's electrical panel. The shed is used in the summer for help with the remote garden. I don't think it's practical to run conduit to the shed (not a smart expense considering I don't need power every day) and I want to power the shed using a small-ish generator.
The shed is not currently wired, I want a couple outlets and some lighting. I want to wire it (probably need no more than 2-pole and 20 amp service) to only run from the generator. Since I won't have it connected to the utility, I'm thinking I don't need a transfer switch. Is there something (adapter) I can feed right into the panel (from the generator)?
Perhaps there is no such product, because I assume hooking up a generator to something off-grid is not a big market. Any thoughts on the best way to pull this off? Thanks!
shermanator is offline   Reply With Quote
Old 10-26-2010, 05:44 PM   #2
hillbilly1
Default Re: Wiring a remote shed to run off generator
Here is an easy way to do it, you mount this box outside, wire it to a small panel, then just plug your generator into this box, safe with no exposed live parts. http://www.grainger.com/Grainger/wwg...N=0&sst=subset
hillbilly1 is offline   Reply With Quote
Old 10-26-2010, 05:56 PM   #3
shermanator
Junior Member
Quote:
Great, thank you! I saw these when I was doing my research, but something convinced me they were not what I was looking for. But looking at them again, you are right, I think this is the best way to go. Thanks!
Old 10-26-2010, 06:04 PM   #4
hillbilly1
Depot and Lowes used to carry those also, but I could not find them on their website.
Old 10-26-2010, 06:29 PM   #5
HOTFR8
HOTFR8's Avatar
Location: Castlemaine, Victoria. The Hot Rod Centre of Australia.
If I was you I would wire it like a Caravan. That way you can unhook the lead and gen set and put them away in the shed when not required.
__________________
1966 (Aussie) XP Falcon Sedan, 1923 T Roadster, 1948 F4 Truck, Home Built Teardrop Camper, 1969 International 4 X 4 truck (Classic),
84 x 30 Colorbond Shed with Showroom, Workshop, Car storage and Office.
www.streetrod.com.au
The Beast Runs>http://www.garagejournal.com/forum/s...0871&showall=1
Sheddwellers>http://www.garagejournal.com/forum/s...0063&showall=1
The International> http://www.garagejournal.com/forum/showthread.php?t=32307&showall=1
"V8's are Great, But Six inlines Just Fine" - CUMMINS Advertising.
HOTFR8 is offline   Reply With Quote
Old 10-26-2010, 07:45 PM   #6
mrb
Senior Member
mrb's Avatar
here's an affordable way to do it. Mount a weatherproof junction box, and install this http://www.amazon.com/Leviton-4937-W.../dp/B00074USHY on it. Has a male 5-15 plug under the flip cover.
mrb is offline   Reply With Quote
Old 10-27-2010, 05:10 AM   #7
HOTFR8
HOTFR8's Avatar
Quote:
Similar to what I suggested. A good looking fitting as well.
__________________
Old 10-20-2016, 11:19 AM   #8
jdwyer85
Junior Member
I have a similar question - but more power needed. I have a garage on a property with no power. It had power but I disconnected it while we demo the house. The property has a well and I'd like to be able to hook up my generator in the garage to some power source that will run the well when I want and also power some lights inside and out of the garage.
jdwyer85 is offline   Reply With Quote
Old 10-20-2016, 02:08 PM   #9
Senior Member
theoldwizard1's Avatar
Quote:
Aussie to American translation
"Caravan" = "Travel Trailer"
theoldwizard1 is offline   Reply With Quote
Old 10-20-2016, 05:09 PM   #10
HOTFR8
HOTFR8's Avatar
Thank you.
__________________
Old 10-21-2016, 08:29 AM   #11
sberry
Senior Member
sberry's Avatar
They call this piece,,,, an extension cord. Plugs in to that noisy thing.
sberry is offline   Reply With Quote
Old 10-21-2016, 08:42 AM   #12
petee_c
Senior Member
What equipment are you running out in the shed?
Would a deep cycle battery, inverter and solar panels work for occasional use?
There is a garden near by so I assume it gets decent sun.
No stabilizer to worry about etc.
Sent from my LG-D852 using Tapatalk
petee_c is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
