Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 10-28-2010, 10:47 PM   #1
turbo6justin
Senior Member
turbo6justin's Avatar
Default How close for insulation around heater vent
I am closing up the ceiling in my garage and I am trying to figure how close to the exhaust for my Modine heater I should put the insulation. It is a 175k heater with a 6" vent that runs up into the attic and out the gable end. I of course used a thimble where it goes through the wall but I am leery about the insulation where it will go through the ceiling. The fiberglass won't 'burn' per say but how close is close. I will of course strip the kraft facing away for this section. The vent goes up and into a 45 deg a little above ceiling height so after that the pipe runs through the ceiling joist space where the insulation will be. Right now I have 10+ inches of clearance along the whole length of the pipe (24"). If I insulate under the pipe there will be contact between the vent and the insulation for at least part of the length. Is it okay to have contact with the insulation? I will use another thimble through the drywall, is the 2" or so that the thimble adds enough clearance for insulation? I obviousely want this to be very safe but want it insulated as well as possible. Looking for advice as I am coming up with nothing right now.
Many thanks in advance.
turbo6justin is offline   Reply With Quote
Old 10-29-2010, 08:27 AM   #2
trythis
Senior Member
Default Re: How close for insulation around heater vent
I would not touch the pipe with insulation. That spot or area will not cool like the rest and might corrode faster. I am sure there are codes against this sort of thing.
trythis is offline   Reply With Quote
Old 10-29-2010, 10:29 AM   #3
csp
Senior Member
What type of vent pipe are you using, single wall or B-vent?
csp is online now   Reply With Quote
Old 10-29-2010, 05:43 PM   #4
turbo6justin
Senior Member
Where I am concerned about the insulation it is single wall. It is b-vent through the outside wall.
I am sure there are codes as well, I just can't find one that applies. I have tried code books as well as insulation manuals but can't find any answer. The insulation information just refers to ASME codes which are hard to find with out paying for them of course.
Old 10-30-2010, 07:53 AM   #5
REDSHELBY
Junior Member
Should use all B-vent. 1 inch clearence for B-vent 6 inch for single wall.
REDSHELBY is offline   Reply With Quote
Old 10-30-2010, 08:21 PM   #6
turbo6justin
Senior Member
The single wall is heavier wall and is what was recommended by a local installer so I am not worried about that. Anyone care to second the 6" rule? I was just thinking I could also put a piece of reflective insulation on top of the drywall (in the attic) where the vent runs.
Old 10-30-2010, 08:28 PM   #7
padronanniversary
Senior Member
6" for single wall. That's why I always use b vent
padronanniversary is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
