Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
Built this parts washer in 1988, just updated it with a new backsplash and
four 50-watt track lights. Its made with recycled steel from a cement block plant. The backsplash is a backplate from an electrical enclosure. Originally this thing had a gear pump,that was housed in the "wart", on the side of the washer, but after a few years it quit working. It now has a Little Giant submersible pump. It holds around 18 Gallons of fluid and is 18 X 26 in size. (the size of the old cement block plates did not cut them.) ![]() Legs are made from 3x3 square tube. Casters are all steel, so they won't get flat spots from sitting in one place. ![]() Shot of the newly completed backsplash. ![]() Would you believe that the backsplash is painted with the same gallon of paint I used in 1988. It was all "crusted" over, on top, but was fine underneath. ![]() ![]() Control panel was updated with two new toggle switches. Used to have an Allen-Bradley lighted push-pull switch, in the center, now has aluminum over the old 1-7/32" hole. ![]() A shot with the doors closed. Never have to worry about a fire burning through this washer as the doors are 5/16" thick. The combination, door stops/handles work well. ![]() Here is the backside. ![]() Fluid is kerosene. ![]() All for now, ![]() -John |
#2 |
Senior Member
Pretty cool, I dig the doors very much.
TheGrooveking |
#3 |
Senior Member
#4 |
Senior Member
I bet that washer won't blow away in a windstorm! Nice work!
__________________
Looking to buy Par-X tools, please IM me if you have any FS. |
#5 |
Senior Member
Nicely done.
#6 |
Senior Member
Well done!
I recognize those plates, my dad ran a "Besser" plant back when. |
#7 |
Senior Member
Dude that thang is as old as i am :P That is a very sweet parts washer and obviously way more heavy duty than most great design!
__________________
How many ratchets will be enough? |
#8 |
Senior Member
You're a talented fabricator John. I like the fact that you have a ton of light too.
__________________
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley Lots of Vise Info Vise restoration Tips The Vises of GJ! (dial-up death) Need an old USA made vise? I usually have several in stock. A_Pmech now makes my replacement jaws, ask him! |
#9 |
Senior Member
__________________
#10 | |
Senior Member
Quote:
metal halides over an 18' door, has always been the proverbial black hole under that door. Can't remember when exactly I built this washer I think could have been in '86, not sure so I'll say '88. |
#11 | |
Senior Member
Quote:
the bottom folding up and dropping my parts into the fluid below. |
#12 |
Senior Member
#13 |
Senior Member
#14 |
Senior Member
| Tags |
| home made, kerosene, parts cleaner, track lights |
| Thread Tools | |
| Display Modes | |
