Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-09-2010, 10:25 PM   #1
dtjordan
Junior Member
Default Portable Paint Booth
I'd like to see if anyone else has created a portable paint booth. I paint from time to time, not frequent enough to have a dedicated paint booth so I've had to make due with using poly on many of my paint jobs. I've found that with today's finishes it's not that big of a deal since most of the jobs are cut and buffed anyway. The booth does help keep the dust down both in the booth and probably more importantly out of the shop. So here goes now there will be no doubt in anyone's mind at how a real hillbilly paints cars in his garage.
dtjordan is offline   Reply With Quote
Old 11-09-2010, 10:27 PM   #2
dtjordan
Junior Member
Default Re: Portable Paint Booth
Here are a few more of the pic's.
Old 11-09-2010, 10:30 PM   #3
Wanna Ride
Senior Member
Absolutely frigging ingenious. That will definitely get the job done!
Wanna Ride is offline   Reply With Quote
Old 11-09-2010, 10:35 PM   #4
Shadowdog500
Senior Member
I like it!!
What did you use for the hoops. Greenhouse hoops?
Thanks,
Chris
Shadowdog500 is offline   Reply With Quote
Old 11-09-2010, 10:36 PM   #5
1969
Senior Member
1969's Avatar
Do you have any problem with static ? What about the fan setup ?
1969 is offline   Reply With Quote
Old 11-09-2010, 10:37 PM   #6
tool whore
You clearly dont need our help. That is awesome and I plan on plagarizing your idea very soon. Post some pics once you start up the sprayer please. We are going to need some detailed specs from you. How did you make the clips to fit and what type of conduit are you using? Lengths, sizes, etc.
tool whore is offline   Reply With Quote
Old 11-09-2010, 10:41 PM   #7
dtjordan
Junior Member
I found that the cheapest method was to use pvc conduit. If you go that route then you get a free coupler on each end of the pipe. I used two 10' sections with one 5' section in the middle. It's a little flimsy so you will see that I ran a 1x down the center and attached it to the wall of the shop. I also added 4-2" stripes of plywood to the corners to help stiffen up the end walls. It takes about 2 hrs to set up.
Old 11-09-2010, 10:45 PM   #8
dtjordan
Junior Member
The clips are just made by taking another piece of pvc and cutting it about 4" long. Then cut out one side and here is the trick to making it work without tearing the plastic, sand the outside corner so they are rounded. It doesn't take much clamping force to hold the poly in place so don't make it so tight that it tears the plastic when you snap them in place.
I also found the zipper at home depot for about $10, and it makes all the difference for getting in and out of the booth.
Old 11-09-2010, 10:56 PM   #9
dtjordan
Junior Member
I haven't found the static to be a problem, in fact it more that likley helps keep the booth a little cleaner because the dust does tend to stick to the poly. I didn't have the fan installed in these photo's and the booth is down now. I haven't painted in this one yet but I plan to add a fan by making a 2x2 frame that will be attached to the wood cross arms. It will house a box fan that will be ducted out the main door. On the other end of the booth I will tape a couple of furnace filters to keep the walls from being sucked in when the fan is running.
Old 11-09-2010, 11:37 PM   #10
akdiesel
Senior Member
akdiesel's Avatar
Great job. I am doing the same thing but out of unistrut for support to hang items as well.
I just purchesed one of those mini blowers that has the heater on it as well so it should help with cureing.
It is amazing how much they wont for those paint booths and they can't be torn down for the most part.
akdiesel is offline   Reply With Quote
Old 11-10-2010, 01:03 AM   #11
PECVD2
Senior Member
PECVD2's Avatar
dtjordan, I stole that idea from someone (maybe you) over at HAMB. works great. I use poly over my festival canopy frame.
PECVD2 is offline   Reply With Quote
Old 11-10-2010, 01:32 AM   #12
evintho
Senior Member
evintho's Avatar
I like it! Very ingenius! Here's one I thought was way cool. I don't remember but I might've got it off of GJ.
evintho is offline   Reply With Quote
Old 11-10-2010, 02:17 PM   #13
AussieDan
Senior Member
That is super slick!
AussieDan is offline   Reply With Quote
Old 11-10-2010, 02:23 PM   #14
strelnik
Senior Member
Quote:
hillbilly, shmill billy, it's ingenious, its cheap, it works!
TERRIFIC!
Now I have to figure out how to plan mine!
strelnik is offline   Reply With Quote
Old 11-10-2010, 03:57 PM   #15
wornoutoldman
Senior Member
wornoutoldman's Avatar
Thank you both! That's some great stuff there!
__________________
Donor Heart Recipient 3.28.10
Eat less. Walk more. 2016
Wanna keep track of all your vehicles maintenance? Click here!
wornoutoldman is offline   Reply With Quote
Old 11-10-2010, 04:24 PM   #16
JCQuick
Senior Member
JCQuick's Avatar
yeah that 2nd one is cool very good idea
JCQuick is online now   Reply With Quote
Old 11-10-2010, 05:16 PM   #17
gordsgarage
gordsgarage's Avatar
All are awesome ideas, wish I knew about the 2nd design before I built my garage.
Gord
gordsgarage is offline   Reply With Quote
Old 11-10-2010, 06:06 PM   #18
GTO
Senior Member
GTO's Avatar
I really don't know much about painting or paint booths but,wouldn't be easier to use a HVLP unit for painting cars in a garage ?
GTO is offline   Reply With Quote
Old 11-10-2010, 08:19 PM   #19
bb1970
Senior Member
bb1970's Avatar
Quote:
You still have overspray with HVLP guns. And the more contaminants you can avoid the better.
I think both these set-ups are great. Good job.
__________________
The new Harbor Freight slogan: "Harbor Freight; Cheap and almost good enough".
bb1970 is offline   Reply With Quote
Old 11-10-2010, 09:19 PM   #20
moopa
moopa's Avatar
Not used for a paint booth yet...it's my sandblasting tent(Costco Portable Garage) But once I clean it out, I plan on some painting in there...maybe not a whole car, but some bigger parts at least.
__________________
28x30x16 shop. In-floor Rotary hoist,200 amp service,Heated with natural gas house furnace. Need mezzanine ideas to use wasted overhead space.
2015 Challenger HELLCAT. 2013 Challenger SRT 6 spd
2013 Challenger R/T
2 project 1972 Plymouth Satellites. 1 on the rotisserie
moopa is offline   Reply With Quote
Old 11-11-2010, 12:30 AM   #21
Harley Monster
Evin Tho,
I think your paint booth design is great! I would like to know what you use for lighting as I don't see any lights in the booth area.
Also how are you ventilating it? I see the vent on the back wall and the one on the sliding wall...is the one on the back wall a fan and the other filtered air?
Thanks.
To the others interest in building a booth:
I hope all you guys making your own booths ALSO invest in a good supplied air system to protect their health.
The isocyanates in the catalyzed paints can sensitize you then once sensitized the next exposure can kill you...nothing to mess around with. The problem is you don't know how long it will take to become sensitized to the Isocyanates, there is no warning. It can occur after a few exposures or after a few years of exposure, there is no predictor.
I spray my own stuff, but invested in a SAS supplied air system. Yes, expensive, but I can't paint or do anything else if I am dead.
If you don't know what I am talking about start researching "Isocyanates" and how they can ruin your health...they are tasteless and odorless and they are also absorbed through the eyes and skin. You should have no exposed skin and wear nitrile gloves, latex offers little or no protection because the molecules are so small they go right through latex and through your skin.
If you spray this stuff you must protect yourself.
Sorry to be a Debbie Downer, but I don't want anyone hurt or killed. This is serious #@$&!
Harley Monster is offline   Reply With Quote
Old 11-11-2010, 02:22 AM   #22
evintho
Senior Member
evintho's Avatar
Quote:
Originally Posted by Harley Monster View Post
Evin Tho,
Thanks.
Thanks but it's not my design. I only wish my garage was that big! I found the post on the internet. I thought it was on this forum. It was such an awesome idea, I saved all the pictures.
Old 11-11-2010, 04:34 AM   #23
Harley Monster
EVIN THO...Well, I guess we will just have to figure out how to put lights in it.
I was thinking on the moveable wall when it is framed boxes could be framed in for two rows of 8' flourescent lights which would end up being flush, same on the hinged wall. That would take care of half the lighting. On the fixed wall, most framed garages have a stem wall so the moveable wall woud not be able to go completely against the outer wall allowing two rows of 8' flourescent lights could go there without holding the moveable wall off too far, the end fixed wall two 8' removeable flourescent lights could be taken down before the wall is moved then put back up after it is moved and the room created. If you are building new garage the end wall lights could be framed into the wall too. I think if the top row of lights were high enough there would be no need for lights in the ceiling or perhaps a flush skylight could be used.
For ventilation one or more filter boxes could be framed high into the moveable wall and/or end wall for intakes then a sparkless fan could be framed low into one of the exterior walls to get the desired downdraft effect.
I also thought compressed air water separator, filter and drier could be mounted on the garage side of the moveable wall with a through-fitting and quick disconnects so once the booth was formed you just connect your air hose on the outside and the line to your spray gun on the inside. Quick disconnects for your supplied air respirator could be done the same way.
This design is brilliant, if anyone knows the source of this booth please post it, I would like to know more about it.
Or if anyone has any ideas on how to improve upon it please post your ideas.
Old 11-11-2010, 12:12 PM   #24
meissen
Senior Member
meissen's Avatar
Send a message via AIM to meissen
I love it! That's a lot better but I did a very similar thing at my parent's house. I was painting interior pieces to dye them black instead of gray and the only place I had to use was the basement. It didn't stop the odor of the paint but it kept all the over spray and dust contained.
I took 6 4x6 clear plastic tarps that I found at the local ACE Hardware store and made a ceiling, walls, and floor and had it all taped together except for a little flap. Made a big paint cube in the basement.
__________________
1994 Chevrolet Camaro "Red Alert" - v6 to v8 Gallery - Bored, cammed, stalled, driven :D
My Garage Progress Thread - Michigan Mania Member
Michigan FBody Association
Owner, Administrator
meissen is offline   Reply With Quote
Old 11-11-2010, 02:10 PM   #25
sberry
Senior Member
sberry's Avatar
Mine rolls up and out of the way, takes about 5 minutes. http://dodconf.swri.org/2003Papers/Thelen.pdf
sberry is offline   Reply With Quote
Old 04-04-2011, 03:37 PM   #26
e-tek
Senior Member
e-tek's Avatar
I use plastic drop sheet curtains and will just say that the hard-wall idea is probably the better of the 2. As soon as you put a decent fan in the plastic booth, you get trouble. Plus the pastic is good for one, MAYBE 2 uses, before it's too dusty, wrecked or contaminated to use again. That walled booth is brilliant.
e-tek is offline   Reply With Quote
Old 04-04-2011, 04:26 PM   #27
MP&C
Senior Member
MP&C's Avatar
Make sure your exhaust fan provides adequate air flow. In addition to removing the cloud of paint overspray, it also serves to pass air across the painted surface to aid in outgassing the solvents. Not enough air flow and you will be affecting your flash times, or worst case, risking solvent pop.
A possible fan to use that is also approved for hazardous location is a smoke ejector that they use on fire trucks. They do show up for sale on the used market every so often.
__________________
Robert
MP&C Shop Projects-Metalshaping Tutorials
Super Street/Super Gas 65 Fairlane build
Instagram @ mccartney_paint_and_custom
MP&C is online now   Reply With Quote
Old 04-04-2011, 04:28 PM   #28
billcole
Senior Member
I have had these plans for awhile, but have not used them. Maybe someone else could use them.
http://duplicolortv.com/wp-content/u...aint_booth.pdf
billcole is offline   Reply With Quote
Old 06-11-2011, 10:27 PM   #29
CHIBA280
Junior Member
Thumbs up Re: Portable Paint Booth
Quote:
THAT IS ONE SMART,SLICK,AWSOME,IDEA FOR A PAINTBOOTH. I SURE WILL GIVE THAT A TRY, WOOHOO! FINALLY!!! PEACE!!
CHIBA280 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
