Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-10-2010, 03:59 PM   #1
jocephus
Junior Member
Default 30x40 shop stick vs pole
i am building a new shop it is going to be 30x40 i allready have concrete poured i was going to build a pole building but my sub really does not like pole barns so im going to build a stick building i am wondering if anybody has any different ideas on stick buildings other than 2bys on 16" centers a budy of mine had a smaller building built in 10ft sections with laminated posts. any body heard of something like that. oh yea building needs to be 12 ft high.
jocephus is offline   Reply With Quote
Old 11-10-2010, 04:04 PM   #2
Abbott
Senior Member
Abbott's Avatar
Default Re: 30x40 shop stick vs pole
I like 2x6s for studs if your budget can handle it. 30x40 will be a great size, man you going to be having some fun! Welcome to the forums.
__________________
Quote:
Originally Posted by Bull View Post
[In voice of Gronk, the caveman] "Uh, tool come from across Big Water. Tool bad. Man bad."
Abbott is offline   Reply With Quote
Old 11-10-2010, 04:07 PM   #3
larry_g
Senior Member
So does this concrete have any footers around the edge to hold the building up? Where in the world are you? It might make a difference. Give us a bit of history on the slab and was it designed/engineered for a building floor? Need input....
lg
no neat sig line
__________________
My Shop build thread
Great minds talk about ideas, average minds talk about events, small minds talk about people.
Wise people talk because they have something to say. Fools talk because they have to say something.
larry_g is offline   Reply With Quote
Old 11-10-2010, 04:12 PM   #4
Abbott
Senior Member
Abbott's Avatar
Yep, you gotta have footings for a stick built. You can dig them out and pour them after the slab is down if needed.
__________________
Old 11-10-2010, 04:22 PM   #5
38Chevy454
Senior Member
38Chevy454's Avatar
There will be building code requirements for your area. You might be able to get by with 24 inch centers for your wall studs. It all depends on what your local requirements are, you need to make sure you build in compliance with the codes or your life can become very difficult..
__________________
If one has problems with their neighbors..........they did not buy enough land
My detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=66932
USA made high quality bear claw style latches - cheap:
http://www.hotrodlatches.com
38Chevy454 is offline   Reply With Quote
Old 11-10-2010, 05:01 PM   #6
Grumpy365
Senior Member
Studs are used, because they are relatively cheap they are easy to work with and THEY WORK.
I looked at metal studs, and was going to use them when i built my house, but they don't make sense. They act like a heat sink, so you have a 2" strip of material that is radiating heat or cold every 16" and when you finally are done looking at all the cost, it is HARD to justify.
I guess there are some laminate materials out there, but the cost I have seen on those is ridiculous as well.
A Building project is going to suck up every dime and every ounce of patience you have, you really need to think hard before taking on something your contractors and your inspector hasn't seen before. You don't want them to be learning on your time.
Good Luck
__________________
I like whiskey. I always did, and that is why I never drink it.
Robert E. Lee
Grumpy365 is offline   Reply With Quote
Old 11-10-2010, 05:18 PM   #7
dcovey
Senior Member
dcovey's Avatar
Just something to think about. When I had my pole barn built, I found out they can build it on top of the slab like a stick built. They use an L bracket bolted to the concrete and post.
Why does your sub division not like pole barns (Home owners association?)?
Like has been said, make sure you check on codes and permits. Believe me I learned the hard and expensive way!!
Dave
__________________
David Covey
dcovey is offline   Reply With Quote
Old 11-11-2010, 12:45 PM   #8
SPDMETL
Senior Member
SPDMETL's Avatar
Quote:
Dave
Ha ! Hahahahahaha ! Snort ! Home Owners Associations exist to make sure you can't do ANYTHING you want to. Who thought these stupid things up,anyway ?
__________________
THE POWER OF STUBBORN !
SPDMETL is offline   Reply With Quote
Old 11-11-2010, 03:05 PM   #9
Zengineer
Senior Member
Zengineer's Avatar
Outside the box... try using SIP's? Depends if you need the insulation in your climate however.
__________________
Sanctum Mechanicus
Zengineer is offline   Reply With Quote
Old 11-11-2010, 03:10 PM   #10
Steevo
Senior Member
Steevo's Avatar
I went 2x6 studs on 16" centers for my 24x40x12h shop. The 2x6 walls allow R21 insulation batts.
See the build pics here:
http://sdwike.smugmug.com/Other/Stev...03569048_BvqP9
Steevo is offline   Reply With Quote
Old 11-11-2010, 03:58 PM   #11
kb2tha
Senior Member
kb2tha's Avatar
A method that I have seen used involves using a top and bottom 2 x 6 plate. Use 2 x 4 studs placed 24" oc staggered on the inside edge and the outside edge of the plates. This allows for no thermal loss through the studs, R19 if you are using fiberglass and requires no holes for electrical wiring. Make sure whatever method that you use a treated late against the concrete.
Ken
kb2tha is offline   Reply With Quote
Old 11-11-2010, 06:29 PM   #12
ishiboo
Senior Member
Steve,
Don't mean to threadjack but I see you used the "stab" couplings on your yellow pe... was the plumber okay with them and did you have any issues working with them?
ishiboo is offline   Reply With Quote
Old 11-11-2010, 06:32 PM   #13
243
Quote:
If you are not limited by Code or HOA BS, I would kick the subcontractor off the project. It is not what he wants to build, it is what you a paying him to build.
243 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
