Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-13-2010, 11:13 PM   #1
HandBanana
Junior Member
Default For those with pin stripes and lines in their garage walls
Just a quick question for ya'll. So for those of you who painted your garage walls with pin stripes, red and black ones mostly. Did you use a gloss or flat paint? Currently working on a Gray Black White stripes and red stripe theme but I'm thinking that a gloss might look better on the red and black.
Let me know what you think.
HandBanana is offline   Reply With Quote
Old 11-13-2010, 11:26 PM   #2
rwhite692
Senior Member
rwhite692's Avatar
Default Re: For those with pin stripes and lines in their garage walls
I used eggshell finish on all of the colors I used.
__________________
My 24x36 detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=16310
rwhite692 is offline   Reply With Quote
Old 11-13-2010, 11:32 PM   #3
gmhill33
Senior Member
gmhill33's Avatar
Quote:
That looks great, how do you get the lines so straight and crisp?
Thanks,
Gary
gmhill33 is offline   Reply With Quote
Old 11-13-2010, 11:52 PM   #4
HandBanana
Junior Member
Whoa thanks rw, that looks awesome and the lines are so crisp.
Old 11-14-2010, 12:15 AM   #5
JC23
Senior Member
JC23's Avatar
Frog tape is supposed to be good for that.
JC23 is offline   Reply With Quote
Old 11-14-2010, 02:05 PM   #6
lpigg
Senior Member
lpigg's Avatar
When I did mine, I used blue tape and then painted the inside edge with the color on the backside of the tape to seal it so that I wouldnt have any bleed through and then I painted the black line. It worked awesome.
I also used eggshell
lpigg is offline   Reply With Quote
Old 11-14-2010, 04:49 PM   #7
HandBanana
Junior Member
@lpigg you guys did awesome jobs. I'm lovin the black stripe on gray. I am also convinced that egg shell will be the way to go.
Now the small detail is that the white will be flat and the grey will be flat as well. Hope the stripes won't look funny being the only color with the egg shell finish. I am absolutely not spending on the white that came with the house and I rather not repaint the grey that is already on there (besides I already re-painted once because the light gray ended up looking lavander purple). Glad the quarts of flat finish paint are only like 6 bucks. I do understand that the egg shell finish will be a couple bucks more.
Guess I jumped the gun too quickly and didn't really know much about finishes. Live and learn. Egg shell might also work better against water splashes on the wall. But the occassional splash and mark could just be touched up.
Thanks for your input and I welcome more. So its off to HD again.
Old 11-14-2010, 05:06 PM   #8
Stephenw
Senior Member
Stephenw's Avatar
I used semi-gloss...
http://shopngarage.com/2010/11/painting-stripes/
Stephenw is offline   Reply With Quote
Old 11-14-2010, 05:51 PM   #9
stevelh
IMO, I would not use flat paint. That is what I have now and is the reason I want to repaint. The slightest little scuffs show and I can forget about cleaning it, the paint will come right off on the rag. I am going with either semi gloss or satin this time.
stevelh is offline   Reply With Quote
Old 11-14-2010, 11:54 PM   #10
Wanna Ride
Senior Member
Here's mine:
Wanna Ride is offline   Reply With Quote
Old 11-15-2010, 03:18 AM   #11
HandBanana
Junior Member
Great looking stripes everyone!
@stevelh
I can see that flat wouldn't be ideal. But for me its not that big of a deal since all I am going to do in the garage is park the car, do a little work on the work bench and hang out.
So I ended up getting BEHR Bijou Red in an Eggshell finish. Its noticeably glossier which is what I wanted. I'm leaving the gray in flat since that's fine for my use.
Thanks again for the input everyone!
Old 11-15-2010, 08:04 AM   #12
mad57
Senior Member
mad57's Avatar
I had put semi on bottom and flat on top worked for me with todays paint it will touch up almost perfect no worries.
__________________
Work to live not live to work.
Iam also vice president of my car club: Wickedridesnj.com check it out!!!!
mad57 is offline   Reply With Quote
Old 11-15-2010, 10:53 AM   #13
Leeboy20
Senior Member
All those stripes look good! Are you guys pulling the tape of wet as soon as the last coat is applied, or are you letting it dry for a few days. I've done lots of striped residential contracts, and i always found to pull teh tape off right away, or the tape ends up peeling the paint off what it is stuck to. Maybe there is new/better tape out?
Leeboy20 is offline   Reply With Quote
Old 11-15-2010, 11:01 AM   #14
lpigg
Senior Member
lpigg's Avatar
I waited for mine to dry. I had a little pullup but not a lot. I also painted the inside edge of mine with the color underneath the tap and let it dry and then painted the stripe. I felt this allowed the tape to seal, so I wouldnt get any bleed throuh.
Old 11-15-2010, 11:18 AM   #15
gabeancounter
Senior Member
gabeancounter's Avatar
Wall and floor! lol
Semi-gloss for red- epoxy on floor.
gabeancounter is offline   Reply With Quote
Old 11-15-2010, 11:23 AM   #16
lpigg
Senior Member
lpigg's Avatar
Awesome Floor. What brand did you use? I like the floor not having the flakes. Is it harder to keep clean?
Old 11-15-2010, 12:06 PM   #17
rwhite692
Senior Member
rwhite692's Avatar
Sorry for the delay in answering...
I used the Frogtape. I was skeptical of this stuff, but damn, it works great, especially on textured surfaces. There is no comparison whatsoever, vs. using standard blue painter's tape. Worth every last bit of the 5 or 6 bucks a roll. Available at Lowe's.
As an extra measure of "insurance", I also did the old painters trick of painting over the tape edge with the same color as what is already on the wall (so that any paint that does manage to bleed under will be that same color, and therefore invisible)...
Let that dry for 15 mins or so then paint in the stripe color. I pulled my tape after the paint had set up pretty good (say around 20 minutes or so) and got really clean lines.
I would not leave the paint to dry for any more than about an hour or so, before pulling the tape.
When the paint gets that "completely" dry it would be likely to have problems cleanly separating, at the tape edge.
__________________
Old 11-15-2010, 12:25 PM   #18
gabeancounter
Senior Member
EpoxySuperstore.com I actually used the cheap waterbased stuff and I was impressed with it. Two coats with a roller and it turned out great.
Yep. All these floors really show dirt easy. Thanks
Old 11-15-2010, 01:45 PM   #19
m.james
Senior Member
Gloss might look better but what about on the wall that the window is on. It doesn't pop as much. Just one factor to think about.
m.james is offline   Reply With Quote
Old 11-15-2010, 02:01 PM   #20
gmhill33
Senior Member
gmhill33's Avatar
Quote:
Originally Posted by Wanna Ride View Post
Here's mine:
Look great.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
