Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 11-23-2010, 08:54 AM   #1
haugy
Senior Member
haugy's Avatar
Default What to use to vent my pole barn attic after ceiling installed?
I've hit a wall with plans or ideas. I'm going to be putting in a ceiling and insulation in my pole barn.
I have no real soffit vents other than the small ridges in the steel to allow air in. But I have no real way for the air to vent out. There is a small gap at the top of the barn, but it has to be sealed up as it lets rain in if it's windy.
So my choices are:
-Gable vent with a small square ceiling vent
-Gable vent with fan to force air out, and to pull in from the little "soffits"
-Turbine vent
-Cupola, which I don't want to do.
My main problem is putting someting into the roof with those ridges in the steel. I can't get a good flush mount, and am worried about it sealing up properly.
Please help. I know I need to vent some air in there, but I can't think of the best way to do it.
haugy is offline   Reply With Quote
Old 11-23-2010, 09:47 AM   #2
rodnok1
Senior Member
rodnok1's Avatar
Default Re: What to use to vent my pole barn attic after ceiling installed?
Do you have overhangs? If you don't want to deal with putting holes in the roof use a gable vent at each end, power one if you want. As for the cap on the roof I have a mesh material that lets air out and no water in, it would be easy enough to install it. They do make specific flashings for metal roofs and seal fine if install correctly. I'm going to install two copulas in the next year myself and put at least one fan in. I like the copula look and can be built fairly cheaply compared to store bought units.
__________________
Some people are like Slinkies... They're really good for nothing.
...But they still bring a smile to your face when you push them down a flight of stairs!
rodnok1 is offline   Reply With Quote
Old 11-24-2010, 07:10 AM   #3
Rick98Z
Senior Member
I have also been wondering on what to do with my pole barn. I do have vented soffit all the way around the building with my 1' overhang. Just not sure if it is going to be enough. I had thought about adding non powered gable vents. Haugy you do have the foam pieces that go over the ribs in the metal underneath the ridge cap to seal from water entering in right?
Rick98Z is offline   Reply With Quote
Old 11-24-2010, 07:41 AM   #4
rodnok1
Senior Member
rodnok1's Avatar
Rick98Z you're in the same boat I am, vented soffits all the way around and ridge venting. I checked the temp with IR thermometer this year and it was 25-40 degrees hotter usually so it definitely needs more air flow. I could feel the heat damming up and working it's way down. I found if I kept the big doors closed it actually stayed cooler until late in the day. I'm hoping two big opening with create a large draw and get rid of the heat.
__________________
Old 11-24-2010, 08:40 AM   #5
haugy
Senior Member
haugy's Avatar
Quote:
As I have no idea what you are talking about. I will go with "no". But I'm foaming up that ridge cap.
One side of my barn faces the wind all the time, so I can't put any vents over there otherwise rain will blow in.
So I'm thinking about putting a gable vent on the opposite side, and box shaped roof vent at the higest point on the other side (windward side).
I hope that works.
Old 11-24-2010, 10:26 AM   #6
gabedad
Senior Member
gabedad's Avatar
I am going to have a geobarn built. They use cupolas for venting
www.geobarns.com
gabedad is offline   Reply With Quote
Old 11-24-2010, 10:37 AM   #7
ishiboo
Senior Member
I have a metal roof and it has a ridge vent running about 80% of the top.
In the summer, I stick a box fan in the attic access opening and it blows the heat into the attic (and out the vent) and keeps things a lot cooler, especially when working higher up
ishiboo is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
