Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-24-2010, 01:35 PM   #1
denap
Junior Member
Default Sealing a sliding barn door...
Hey all,
I've got a barn/wood-workshop build underway and am trying to solve a door problem maybe someone can help with.
The look of the barn is sort of carriage house and I want a traditional sliding door on the front. Since the barn will be heated and insulated (75kw hot dawg and flash-n-batt) I want to come up with some way to seal the sliding door. The current thinking is to put a patio style door inside the sliding barn door, inswing, so I can seal it and still have decent access and a good view when the barn slider is open.
The issue here is the size. I want an 8' sliding door and am having a hard time finding an 8' patio door that won't breaking the bank. Anyone have any good ideas for sealing a sliding barn door or a source for a reasonable 8' non sliding patio door?
thanks!
-Tom
denap is offline   Reply With Quote
Old 11-24-2010, 02:20 PM   #2
Tman
Senior Member
Default Re: Sealing a sliding barn door...
I use a rubber seal meant for the bottom of garage doors around the perimeter as a rubber "sweep" style seal. Works great.
Tman is offline   Reply With Quote
Old 11-24-2010, 06:15 PM   #3
trbomax
Senior Member
trbomax's Avatar
how about a pic of this?
trbomax is offline   Reply With Quote
Old 11-24-2010, 06:28 PM   #4
Scout Driver
Senior Member
Scout Driver's Avatar
Quote:
This idea combined with a simple jamb should work. Use a couple hook-style latches inside, the kind that "over-center" and pull the door towards the jamb. Stay warm!
Scott
__________________
WTB: International Harvester tools. (the automotive mechanic's style tools made by Wright) Also looking for other IH items of interest.
Scout Driver is offline   Reply With Quote
Old 11-24-2010, 06:44 PM   #5
CreekRat
Senior Member
If you have an alternate way into the shop can you build a removable panel(s) that fit inside opening of the sliding door.
You could insulate these panels and if made the right way they could be broken down for storage in the spring or removed temporarily in the winter for access through the sliding door.
CreekRat is offline   Reply With Quote
Old 11-24-2010, 06:50 PM   #6
Chaz
Senior Member
Chaz's Avatar
I realize this may not suit your fancy at all, but it's an option.
This is an overhead garage door that suits the barn style pretty well. Its insulated and seals beautifully. With non functional sliding door tracks it may give you enough of the look you want without the air leakage.
__________________
Strange Days Garage - Satisfaction Considered
Chaz is offline   Reply With Quote
Old 11-24-2010, 08:20 PM   #7
semi75
Junior Member
I like the looks of that door Chaz, I don't think I would like the price though.
I made a big mistake when I built my pole barn when I put in two sliding doors that met in the middle, they just were not made for a great seal. I've had ok luck with the sliders in my larger barn but it is unheated. That barn has 4 single door sliders. I finally ordered a sectional overhead door and said the heck with it for my shop/smaller pole barn. Too bad I'm too cheap for a nice looking overhead carriage style door.
semi75 is offline   Reply With Quote
Old 11-24-2010, 08:38 PM   #8
steviec
Junior Member
I'm not sure what they call them, but in Florida (and probably other similar climate areas) some houses have "cascading" sliding glass doors. Not just the typical one fixed and one sliding section, but several sliding sections. Obviously the track is wider to accept the multiple sliding sections.
I have now idea where you would buy them or what the cost is but I would guess a Google search would eventually find them.
Hope this helps.
steviec is offline   Reply With Quote
Old 11-24-2010, 09:11 PM   #9
randydupree
Senior Member
Memtech is your friend.
randydupree is offline   Reply With Quote
Old 11-25-2010, 09:21 AM   #10
denap
Junior Member
Thanks for the input guys.
CreekRat, that's an option we've considered as it seems none of the solutions to try and seal the sliding door itself seem terrific. The idea of a door behind the door is how we got to looking for a glass patio door to span the space. It just doesn't appear feasible $$ wise.
We may have to just build something and use lexan or something for some panels to provide visibility when they're in place.
Old 11-25-2010, 12:14 PM   #11
s_ontario
Senior Member
s_ontario's Avatar
use belting i was in a tsc store and they had a pallet of new belting baler belting and i offered them $50.00 for the flat and they took it 2 100' rolls of 10" and 2 100' rolls of 6" and 2 rolls of 4"
my sliding door is from warm side of shop to cold side of shop
used baler belting would work just as well
s_ontario is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
