Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 11-28-2010, 10:09 PM   #1
Chris Mallett
Default Waste oil transfer pump?
For those that are heating with used oil, what are you using for a transfer pump? I had a hand pupm I used for summer, but that is impossible now. 12V or 110v, I can adapt for an easier solution. Needs to pull 5-6 feet height and sometimes my oil can be 50w, but I can mix it partially. Thanks in advance.
Chris Mallett is offline   Reply With Quote
Old 11-30-2010, 06:06 PM   #2
Chris Mallett
Default Re: Waste oil transfer pump?
Anybody????
Old 11-30-2010, 06:15 PM   #3
s_ontario
Senior Member
s_ontario's Avatar
any rotary gear pump and electric motor will work
mine will pump 85w140 with no problem
s_ontario is offline   Reply With Quote
Old 11-30-2010, 06:15 PM   #4
LEVE
Senior Member
I'm wondering the same thing. HF has clear water pumps on sale for cheap and I was going to try one of those. I'm trying to reclaim waste engine oil and clarify it for fun... by running it through a toilet paper filter assembly.
LEVE is offline   Reply With Quote
Old 11-30-2010, 06:32 PM   #5
Chris Mallett
Have a spare? That is what I wanted to see.
Old 11-30-2010, 06:46 PM   #6
walrus
Senior Member
walrus's Avatar
Quote:
My buddy used to use an oil pump out a ford 289
I use a simer paddle pump for 2oil and gas but it will pump oil also
http://www.jmesales.com/category/262...ump-Parts.aspx
need 3/4 hp motor to run it though
walrus is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
