Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 12-02-2010, 02:17 PM   #1
Sloper0204
Alliance Member
Default Epoxy for good wood to metal bond?
Was wondering if anyone could suggest an epoxy for a good wood to metal bond. Am in need of inserting a small section of pipe into some wood and want it to stay in place without need of keeping it bolted in.
Sloper0204 is offline   Reply With Quote
Old 12-02-2010, 03:22 PM   #2
gabedad
Senior Member
gabedad's Avatar
Default Re: Epoxy for good wood to metal bond?
That billy mays stuff works great. Mighty putty
gabedad is offline   Reply With Quote
Old 12-02-2010, 03:25 PM   #3
archirelic
Senior Member
archirelic's Avatar
Just this past summer i used Gorilla Glue to attach reclaimed barn siding to some steel u-channel for an art installation I designed in class.
I've also used Loctite Multi-purpose epoxy before.
Both have worked great, attaching wood objects to metal.
archirelic is offline   Reply With Quote
Old 12-02-2010, 03:46 PM   #4
ishiboo
Senior Member
Quote:
Sure. Like any adhesive, the grip will be much better if you rough it up, or even if the end of the pipe is threaded.
A simple two-part from the hardware store will work fine. Make the pipe as rough as you can get it where the epoxy will go. If you want a very reliable bond, I'd go with some quality epoxy like West's Six10, in a convenient and rather ingenious caulk tube with mixing tip
http://westsystem.com/ss/six10-thick...poxy-adhesive/
ishiboo is online now   Reply With Quote
Old 12-02-2010, 05:24 PM   #5
1969
Senior Member
1969's Avatar
Polyurethane adhesive in a caulking tube, Lowes..... about $5.00. Just used some, works great.
1969 is offline   Reply With Quote
Old 12-02-2010, 09:55 PM   #6
senlow
Senior Member
senlow's Avatar
X2 for the West System epoxy.
senlow is offline   Reply With Quote
Old 12-03-2010, 06:38 AM   #7
sdowney717
Senior Member
Polyurethane adhesive like PL premium will work wonderfully for this.
It is great cheap easy to use.
sdowney717 is offline   Reply With Quote
Old 12-03-2010, 10:31 AM   #8
EdT
Senior Member
The suitability of adhesives for this application depends a lot on what the pipe is doing, how big everything is and what limitations exist that preclude using mechanical fasteners or mechanical interference to keep things together. For example, if the pipe is just a pass-thru for some wires and is, basically, not undr any load, almost any kind of adhesive will work. If, on the other hand, this will support significant loads and the adhesive is the only thing supporting the load, it might not be a satifactory solution no matter what kind of glue you use. You may be familiar with all the roof panels falling down on the big tunnel in Boston. The fasteners were glued into holes in the concrete and the glue was mis applied. The best you're going to do is probably some kind of epoxy and all the suggestions above apply if you go that way.
EdT is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
