Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-12-2011, 04:41 PM   #1
birdman1
Default Materials for garage ceiling--Metal VS 4x8 panels
I am working up some figures for the shop ceiling. If I put up 4x8 panels (OSB. of plywood I naturally have to paint. One coat of oil base primer, and two coats of paint, is normally what it takes to look good. I have ck'ed with a roofing contractor about installing the roofing tin on the ceiling. This is 3' wide and $1.50 per L/FT. He has quoted materials and labor but he is way to high on that quote.I have family that can help me but one bay is 16 ft. high for a lift and kinda dangerous on ladders. OSB is approx. $7.00 per panel and it will take 40 sheets to cover the ceiling,then paint. The roofing materials comes painted so once it is up you are done.We may put the roofing steel up ourselves. Any ideas about this will be appreciated.
Thank you
Mike
birdman1 is offline   Reply With Quote
Old 01-12-2011, 05:03 PM   #2
JC23
Senior Member
JC23's Avatar
Default Re: Materials for garage ceiling--Metal VS 4x8 panels
Have you looked into the plasitc version of that metal? It's lighter, easier to handle and may be cheaper. Plus, the shiny finish reflects light like crazy.
I've seen it on here a number of times.
JC23 is offline   Reply With Quote
Old 01-12-2011, 05:21 PM   #3
ralfs56
Junior Member
not sure about price...would certainly be easier and faster than the OSB option http://www.zipupceiling.com/
ralfs56 is offline   Reply With Quote
Old 01-12-2011, 05:50 PM   #4
Zeke
Senior Member
Zeke's Avatar
Location: Senior Member—in more ways than one in Long Beach CA
You can rent a rolling stage for installation and painting, whichever system you decide on. Safer and faster than ladders. I think I'd choose something fire resistant.
Zeke is offline   Reply With Quote
Old 01-12-2011, 06:13 PM   #5
dcovey
Senior Member
dcovey's Avatar
I'm going to go with corrugated metal from Lowes unless someplace else has a better deal. I do get an additional 10% off with a military ID (retired).
Lowes Page
13.92 a sheet or 1.16 a linear foot.. Its cheaper than the metal on the outside, and easier to put up and finish than OSB or drywall..And I think it will look good..
Dave
__________________
David Covey
dcovey is offline   Reply With Quote
Old 01-12-2011, 06:55 PM   #6
fflintstone
Senior Member
fflintstone's Avatar
Metal roofing is about $.60 per sq ft @ menards.
When I have a spare $1,000 I will do mine.
fflintstone is offline   Reply With Quote
Old 01-12-2011, 07:07 PM   #7
Test Pilot
I used the metal on the walls and the ceiling both. No painting required,installs quick and easy and it is a good look when done >>>>.
Test Pilot is offline   Reply With Quote
Old 01-12-2011, 07:10 PM   #8
5lima30
Senior Member
5lima30's Avatar
When I was looking at corrugated metal it was almost $2 a sheet cheaper at Home Depot. Just today I was at Home Depot and bought a 5# box of nails that was almost $2.50 less than Lowes. BTW you can get the military discount at Home Depot w/ ID.
5lima30 is offline   Reply With Quote
Old 01-12-2011, 08:01 PM   #9
birdman1
Thanks to all of you, for your ideas.Test Pilot, I saw your pics in a thread today,that looks great. Just did not know how much that would cost.I just retired from Lowe's and had forgotten about us having the plastic roofing materials,mostly used for small greenhouses and patios, will have to ck. out those prices tomorrow at the store.or on line.I still get my 10% discount, retired military also. The old style 5V tin is only 2ft wide and the metal roof I priced was $1.50 per ft. and 3 ft. wide. A scaffold would be safer than a ladder, as someone said. I have even thought about painting the OSB panels on tarps or plastic, then installing them.I liked the metal idea,and it will cost approx. $800.00 to pull it off,but hey, you're done. no painting.
Thanks for the help, any more ideas, please pass those along as well
Mike
Old 01-12-2011, 08:40 PM   #10
Test Pilot
I used a sheet rock lift and two ladders to do the install and it went quick >>>>.
Old 01-12-2011, 08:45 PM   #11
Keep
Senior Member
Keep's Avatar
How noisy is your garage with the all metal walls? Has to echo in there quite a bit.
Keep is offline   Reply With Quote
Old 01-12-2011, 08:49 PM   #12
Test Pilot
Quote:
Haven't noticed. I guess I got enough junk in there to absorb the sound >>>>.
Old 01-12-2011, 08:57 PM   #13
Ohio Auto
Senior Member
Ohio Auto's Avatar
Just installed steel panels on my ceiling. Rented a scissors lift and with the help of a buddy got them all up. I checked the plastic vs. steel and the steel was cheaper. Put it up and you're forever done...no painting, no maintainance...and it is a heck of a lot lighter than OSB.
__________________
My shop/garage
http://www.garagejournal.com/forum/s...ad.php?t=85276
Ohio Auto is offline   Reply With Quote
Old 01-12-2011, 10:02 PM   #14
Fastback
Senior Member
Fastback's Avatar
I put the Durapanel on the ceiling, its the thinner gauge than the exterior metal but works & looks the same. I used a scaffolding to put it up and I did need a helper. Mt ceiling is 23' 6"' wide so I ordered it in 12' lengths and have an overlapping seam down the center.
IT was cheaper than drywall after it's all said n done. I spend right at $400 for 720 SF with the needed J channel.
Fastback is offline   Reply With Quote
Old 01-13-2011, 12:45 AM   #15
jvitez
Senior Member
jvitez's Avatar
How to you gents put up fluorescent fixtures with a metal ceiling? Just drill a hole and use toggle bolts or is the metal too flimsy, meaning each fixture must be screwed into a truss bottom?
__________________
After the reading of the rich man's last will and testament, the family was asked "How much did he leave?"
The answer: "All of it."
jvitez is offline   Reply With Quote
Old 01-13-2011, 05:44 AM   #16
halltrail
I was just going through the same thing my self...trying to decide between metal vs drywall. I ended up going with 5/8" drywall. I bought a cheap drywall lift (thought it was going to take me a couple of days so I didnt want to rent). I ended up putting up 18 sheets in two evenings on a 12 foot ceiling by my self. Of course now I gotta finish it...but no rush. I was most concerned about covering up the insulation.
halltrail is offline   Reply With Quote
Old 01-13-2011, 07:23 AM   #17
ClickClickBoom
Senior Member
I just got done covering my ceiling in Fiberglass Duct Board used for commercial air ducts:
http://www.knaufusa.com/products/bui...ith_ecose.aspx
-Fiberglass, so it's fire retardant
-Foil Faced so it reflects light
-R-Value of 6-9
-Easy install with drywall screws and washers
I think this is fairly expensive to buy retail, but I bought factory 2nds/ overstock and paid $7 a 4x10 sheet.
ClickClickBoom is offline   Reply With Quote
Old 01-13-2011, 07:45 AM   #18
PurdueSD
Senior Member
PurdueSD's Avatar
Quote:
Sheet metal screw through the fixture and ceiling metal into the bottom cord of the truss. The ribs run the opposite way of the trusses so, it works out pretty easy. Sheet metal screw every 2'...
A word of advice... go to a lighting/ electric supply house and buy a decent fixture. You'll get a better ballast. I chose t-8 8' 4 bulb fixtures. Each fixture takes (4) 4' bulbs. That way i only have to stock 1 type of bulb and dont have to mess with the p.i.a. 8 foot bulbs.
__________________
My Truck Shop Build thread... (SOLD)
http://www.garagejournal.com/forum/s...ead.php?t=9671
Help me brainstorm the new shop!
http://www.garagejournal.com/forum/s...d.php?t=338743
PurdueSD is offline   Reply With Quote
Old 01-13-2011, 08:59 AM   #19
birdman1
Thank you folks, for the information. I will install my 8 ft. 2 tube light fixtures with 2-3 inch screws, through the fixture, ceiling, and into the ceiling joist which is the bottom of the truss like Purdue SD stated he would mount fixtures.
Old 01-13-2011, 09:14 AM   #20
Test Pilot
Ok here is the look before the sheeting. I did space the lights out so they would be under a 2/4 too >>>>.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
