Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Search this Thread Display Modes
Old 01-13-2011, 04:39 PM   #1
camaross
Senior Member
Default What is fuel volume regulator
P0001 Fuel Volume Regulator Control Circuit/Open
P0002 Fuel Volume Regulator Control Circuit Range/Performance
P0003 Fuel Volume Regulator Control Circuit Low
P0004 Fuel Volume Regulator Control Circuit High
So what does fuel volume regulator do? Where is it located?
Thanks.
camaross is offline   Reply With Quote
Old 01-13-2011, 06:26 PM   #2
camaross
Senior Member
Default Re: What is fuel volume regulator
Anybody?
Old 01-13-2011, 06:53 PM   #3
tonydanzah
Senior Member
tonydanzah's Avatar
another odd one
__________________
Cheap,fast,reliable. You can chose only 2. Rip Ryan Dunn
http://www.usenglish.org/
tonydanzah is offline   Reply With Quote
Old 01-13-2011, 07:06 PM   #4
camaross
Senior Member
Yes. I googled it for a while, and never find a very good answer.
The closest thing I find is fuel pressure regulator.
Quote:
Originally Posted by tonydanzah View Post
another odd one
Old 01-13-2011, 07:07 PM   #5
adam728
Senior Member
adam728's Avatar
I feel like you are reading thru a diesel manual and asking questions as you go? Maybe?
adam728 is offline   Reply With Quote
Old 01-13-2011, 07:19 PM   #6
camaross
Senior Member
I am trying to educate myself about those trouble codes. I think it is very important to truly understand them all, if I plan to work in this field.
Old 01-13-2011, 07:27 PM   #7
aussiek2000
Senior Member
aussiek2000's Avatar
I went into my shopkey account and the codes you listed do not exist in their database.
aussiek2000 is offline   Reply With Quote
Old 01-13-2011, 07:38 PM   #8
camaross
Senior Member
Thank you for looking it up.
I found that one of the best place to search OBD codes is:
http://dtcsearch.com
Their codes are accurate and complete.
Old 01-13-2011, 08:50 PM   #9
Stick
Senior Member
Stick's Avatar
P0001-0004 are generic codes that as far as I know are a carryover from pre-OBD2 days, and I don't know of any manufacturer that uses them.
If you think about it, a fuel injector is what regulates fuel volume, and the modern equivalent is a P020x code for injectors. Most of the time you see a P0001-0004, you are using the wrong protocol to communicate with the ECM, and you have an issue with fuel delivery or control.
Stick is offline   Reply With Quote
Old 01-13-2011, 09:00 PM   #10
RLRRLRLL
Senior Member
Send a message via MSN to RLRRLRLL Send a message via Yahoo to RLRRLRLL
Well, idk if this will help. But along with fuel pressure, there needs to be enough volume for the engine to run correctly. Im not sure what a volume regulator is, but my guess would be that it helps maintain the correct volume. As even if you have proper pressure, you may not have enough volume.
RLRRLRLL is offline   Reply With Quote
Old 01-13-2011, 09:28 PM   #11
tonydanzah
Senior Member
tonydanzah's Avatar
Quote:
the only time you will see volume mentioned on a modern car is a output/volume test on a fuel pump
__________________
Old 01-13-2011, 09:32 PM   #12
RLRRLRLL
Senior Member
ah, ok, thanks for correcting me. im just a tech student myself, and my teacher pounded in our heads that volume is needed to. live and learn i guess haha.
Old 01-13-2011, 09:34 PM   #13
tonydanzah
Senior Member
tonydanzah's Avatar
volume/flow is important, but you normally only see it used in relationship to fuel pumps
__________________
Old 01-13-2011, 09:40 PM   #14
RLRRLRLL
Senior Member
but wouldn't a "fuel volume regulator" show faulty readings or throw a code if it is in conjunction with the fuel pump? i don't think ive ever heard of a fuel volume regulator...so im just trying to learn a thing or two here, like others im sure.
Old 01-13-2011, 09:46 PM   #15
tonydanzah
Senior Member
tonydanzah's Avatar
like stick said it is probably an old carry over code. Often if you suspect the fuel system you check pressure. If pressure is good then you check pump in the form of a volume/output test.
__________________
Old 01-13-2011, 10:13 PM   #16
RLRRLRLL
Senior Member
ah ok, thanks for the info!
Old 10-01-2013, 10:37 AM   #17
Zeke
Senior Member
Zeke's Avatar
Visiting an old thread. I'm getting this reading on a '96 Jaguar XJ6. Almost all Google hits say the scanner interface is not working properly. I'm guessing that P0001 is the first code on the list and it gets pulled up falsely. I've read that P0001-4 is the same deal.
I have a post on the Jag forum going so we'll see what the Cat experts have to say.
__________________
Quote:
Originally Posted by James-W View Post
I brainwashed a woman once, I stomped on her douchbag.
Zeke is offline   Reply With Quote
Old 10-01-2013, 11:26 AM   #18
Senior Member
First time I have seen this thread !
Many years ago, I was involved in some "philosophical" design discussions on EFI system fuel pressure regulation. Mechanical regulators, at the time, did the job quite well and at a low cost. The problem was, the pump capacity has to be designed for the maximum possible requirement (low fuel pressure at WOT is not good!). This meant that at low driving speed/extended idle, well over 90% of the fuel pumped to the engine was returned to the tank. All that pumping up to a hot engine compartment meant the fuel in the gas tank would get warmer and produce more vapor. This was at a time when the CARB/EPA wanted better vapor management.
Most schemes then (and I believe now) worked on providing the "exact" pressure required at the fuel rail so that no fuel had to be returned to the tank (a returnless fuel system).
An alternative design a friend and I came up with was a "minimal" fuel VOLUME return design. A "volume flow switch" (high/low or maybe high/medium/low) would be plumbed into the return line. If the return flow volume was high, a dropping resistor would be switched, via a relay, into the fuel pump power. Medium would swtch in a different value resistor and low would be no resistor, very similar to the HVAC fan speed. The only issue would be a "switch" that had a lot of hysteresis around the crossing points in order to minimize the cut in/out of the resistors (wear on the relay contacts).
Of course the people who design and manufacture electronic boxes won out because they could not make any money on such a simple design.
FYI, pulse width modulating the DC motor of a fuel pump does not result in a good closed loop control system. Anything below about 33% duty cycle results in effectively no pressure and anything above about 66% results in near maximum pressure. Not a large "control region" left !
theoldwizard1 is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
