Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 01-22-2011, 09:53 PM   #1
azlo
Junior Member
Default Finally, Cabin sandblaster fix.
As some of you know I have the Harbor Freight sandblaster. Everybody has had problems with the cabin sandblasters. But after messing with it all day, i figured it out!! Let me explain.... this is the type of gun I have.
and black Diamond for media from Northern Tool. I was blasting with the gun upside down to see if it would make a diffrence when I realise that the media wouldnt get sucked. I took the hose off and the media would just sit here (see pic) when the trigger aT FULL blast (and gun upside down).
Media was stuck. Of course this very course media, but I also used fine glass beads and it was doing the same. So i took the end of the gun apart.
Took the ceramic end out.
Inside the gun is this insert.
This insert is part of the air feed passage and it meets with the suction passage where vacuum is created. U see where the allen wrench hits the insert in the gun...
Well the media would get clogged there. For some reason course or fine media would get stuck here. So,,, I took the insert & grinded it to give more passage without loosing vacuum.
azlo is offline   Reply With Quote
Old 01-22-2011, 09:54 PM   #2
azlo
Junior Member
Default Re: Finally, Cabin sandblaster fix.
This is what the insert looks like after grinding it.
Installed the insert back in,,, and now u see the extra space. (allen wrench pointing at the insert.)
Put everything back together. What a diffrence!! I even lowered the psi to 80. And I even took all restrictions from the media feed hose, ( in other forums it is suggested to plug or restrict the media feed hose so you can prevent clogging or the surging effect.). SO now at full throttle I get a constant stream of media!! This is beautiful man!
This would usually take 40mins. It took 15 at most. I am one happy camper. I might even see if i can improove on this but it works just fine.
Old 01-22-2011, 10:09 PM   #3
bchee
Senior Member
bchee's Avatar
sweet thanks for sharing that.
Sometimes guys will mention stuff like that in their reviews on the HF site.
Of course there won't be detailed picts like yours
bchee is offline   Reply With Quote
Old 01-22-2011, 10:13 PM   #4
Kirbot
Senior Member
Kirbot's Avatar
Man oh man, how I wan't a blasting cabinet!
Thanks for the post!
Kirbot is offline   Reply With Quote
Old 01-22-2011, 11:17 PM   #5
spongerich
Senior Member
spongerich's Avatar
That's awesome. I have several buckets of walnut shells that I've been unable to use due to clogging. I might give that modification a try. Have you tried it with glass since grinding it?
__________________
Tool Junkie
Check out my YouTube Channel for machine shop videos.
See my eBay listings here.
spongerich is offline   Reply With Quote
Old 01-23-2011, 01:03 AM   #6
Toolhorder
Senior Member
Toolhorder's Avatar
That's awesome!
My cabinet sits unused after a couple problems I had with it.
1. The light broke inside it. I have power to it but the light won't come on. New bulb doesn't help. Can't figure out how to fix this yet..
2. Suction hose comes off the pipe that runs to the bottom of the cabinet that sucks the media. I hose clamped it and it's still an issue.
3. Barely works when the light and suction hose wasn't a problem.
Guess I'll try this and see about fixing the other problems so I can use it again!
Toolhorder is offline   Reply With Quote
Old 01-23-2011, 08:40 AM   #7
Goobzilla
Senior Member
I've only ever used aluminum oxide in mine with very few issues. Only problem I've had with mine was having to use a whole tube of silicone to seal all the leaks, been pretty good since then. I hear it's not as big of an issue with the new design though.
Goobzilla is offline   Reply With Quote
Old 01-23-2011, 11:29 AM   #8
azlo
Junior Member
As soon as I get some windows covers from Autozone im gonna stick a vacuum gauge to the gun & see if im loosing any vacuum or can improove it. Love my week ends.
Old 02-05-2011, 10:23 PM   #9
azlo
Junior Member
Quote:
Switched over to glass and it works beautiful.
also tried it on brass
Gonna clear coat it..
Old 02-06-2011, 02:17 AM   #10
muibubbles
Senior Member
muibubbles's Avatar
awesomeee gotta try this! thanks for sharing!
__________________
Quote:
Originally Posted by A_Pmech View Post
A_Pmech's machine tool buying 101:
1) Buy the biggest forklift you can get your hands on.
Starting a PINK movement, just like Victoria's Secret
Bubble Build
muibubbles is offline   Reply With Quote
Old 02-06-2011, 06:20 AM   #11
TAMPAGT07
Senior Member
TAMPAGT07's Avatar
Good write up..I'm going to get one down the road, and I'll probably use this thread..
__________________
Full Patch Page 1 Member
Official Title- Liaison to the deputy director to the traveling secretary of adult entertainment and internal affairs for The Florida Garage Life Club.
This posting is copyrighted by TAMPAGT07 for the private use of our audience. Any other use of this posting or any pictures, descriptions, or accounts of the posting without TAMPAGT07's consent is prohibited. (This mesage was bought to you by TAMPAGT07''s legal team, the three Robinowitz's)
TAMPAGT07 is offline   Reply With Quote
Old 02-06-2011, 01:17 PM   #12
Kool Coe
Quote:
Have any links to these other forums? I need to "mod" my HF cabinet, its just not performing like it used to. Im sure i need to start with the mod you did, but would love to know what or how to plug the media feed.
Kool Coe is offline   Reply With Quote
Old 02-06-2011, 02:00 PM   #13
T56 Impala
Senior Member
T56 Impala's Avatar
Send a message via AIM to T56 Impala
Right on time with this post. I have never had the problem you are speaking of, using the same media you have. Glad you found a fix in case I do run in to it at some point.
My biggest problem is with the siphon tube. I can seem to get it to stay in the media. It always floats or is pulled up to the top and I just suck air. Maybe I need a longer tube or I need to attach it to the bottom of the cabinet. Any ideas?
__________________
UPDATED October 2013!!!
WTB/WTT: Plomb WF :WF-132, line wrenches WF-105 - 110 and all 3/4" drive.
R.I.P. Bradley
April 18, 2006 - November 27, 2012
T56 Impala is offline   Reply With Quote
Old 02-06-2011, 08:02 PM   #14
azlo
Junior Member
For the some of u thats asking if this sandblast mod works, well heres a vid.
U tell me if it works.
Love the mods.
This is glass beads by the way.
Old 02-06-2011, 08:03 PM   #15
azlo
Junior Member
Quote:
I use a boat plug from HF. Heres a link.
http://www.harborfreight.com/1-inch-...lug-98114.html
Old 02-07-2011, 11:20 AM   #16
ramtuff
Senior Member
ramtuff's Avatar
Excellent! I received a blast cabinet from Homier Tools as a gift a while back (probably the same thing as the HF one). I used it a few times and wasn't very impressed with it. I'll have to pull it apart this week and check it out.
ramtuff is offline   Reply With Quote
Old 04-19-2011, 10:37 AM   #17
TopFuel
Senior Member
Azlo, I can't thank you enough!!!!
I got a similar cabinet a while ago but never was able to get it to do much. I'm using walnut shell media to clean up aluminum parts and only one blast would go through. It was pathetic and I was about to junk it. I had taken apart the gun to play with it and even gave the orifice some thought. But your post with the GREAT photos was the trick. I fired up the bench grinder to modify the orifice then gave the blasting cabinet a try. Perfect!
I got the work I needed to do done and now I know that the cabinet is a viable tool for similar work in the future.
Know that you helped someone today.
TopFuel is offline   Reply With Quote
Old 04-19-2011, 11:05 AM   #18
blueflame6
Senior Member
blueflame6's Avatar
Azlo thanks, I've had all the same problems for years with my cabinet unit. Clogging,pulsating,weak blasting, always a PITA. Gonna try your remedy, sounds like a good fix to me!!.............thanks again.........
blueflame6 is offline   Reply With Quote
Old 04-19-2011, 12:55 PM   #19
Beaumont67
Senior Member
Beaumont67's Avatar
azlo - thanks for your great tip mod. / when blasting, anything to avoid clogs is a "life saver".
Below, is a few links I wanted to share - great BLASTING resources:
Media blasting
http://www.crankshaftcoalition.com/wiki/Media_blasting
Blasting
http://www.hotrodders.com/forum/blasting-190793.html
Soda blasting
http://www.crankshaftcoalition.com/wiki/Soda_blasting
Beaumont { :>)) www.petperfectexpress.com
1965 Malibu S/S, 1966 Beaumont Custom original paint, 1967 Beaumont Custom, 1967 Beaumont Custom original paint, 1967 Beaumont 396-350HP Sport Deluxe M21-411's - SOLD 1970 Judge
Beaumont67 is offline   Reply With Quote
Old 04-19-2011, 12:58 PM   #20
padronanniversary
Senior Member
Maybe I'm expecting too much out of my Grizzly 0707 gun. I ordered the TP gun kit to see how that helps. Maybe its just media. Anyone have this gun ?
padronanniversary is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
