Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 01-23-2011, 04:38 PM   #1
jherrman
Junior Member
Default Modine heater burners won't light, but fan kicks on
I recently purchased a used, early 1990's, Modine overhead 75K btu gas heater (PAE75). When I first got it home before I hung it up I hooked it up and it took right off and blew good heat. This weekend I finally got it hung up and I so I wanted to test it out again to make sure everything was working and it took right off again, but after running about 15 minutes I noticed it was blowing cold air and after investigating the burners weren't lit any longer, but the fan was still running. Now no matter what I do the main burners won't light. The pilot light is lit and is a good strong flame, so that's not the issue. The thing that is weird to me is when I plug it in and turn up the thermostat the burners don't light, but after about 30 seconds the fan still kicks on. I thought most heaters had a sensor that made sure the burners were lit before the fan kicked on, which makes this case confuse me that much more. I don't really have any experience working on heaters, but I'm usually pretty good with anything mechanical, I just have no idea what could be wrong with this thing. I have checked all the wires and connections and everything seems solid. I have not yet vented it through my roof, as I want to make sure this thing is going to work before I do that, but that wouldn't be causing this problem would it? Does anyone have any idea what could possibly be going on with this heater? Any help or suggestions would be great.
jherrman is offline   Reply With Quote
Old 01-23-2011, 06:43 PM   #2
JoeyM
Junior Member
Default Re: Modine heater burners won't light, but fan kicks on
Well it might be your main power is crossed feeding the heater, just unplug it and switch the wires.....
Hope this helps,
JoeyM is offline   Reply With Quote
Old 01-23-2011, 07:16 PM   #3
MrBill
Junior Member
Your heater has a timed on fan start. In other words the fan starts after a predetermined time. Here is the manual for your unit. The limit switch or flue blocked switch most likely have tripped causing the main valve not to be energized. Go to page 20 and you will see there location. You may have a access door or you may have to remove the entire panel to access those limits, they may have a button to reset them. Also follow the instructions for proper flue ventilation.
http://www.modineheaters.com/Modine-PAE-Manual.pdf
Hope this helps. email me if you need further help. I have been in the business for 30+yrs
MrBill is offline   Reply With Quote
Old 02-03-2012, 02:35 PM   #4
gogopntr
Junior Member
just had mine fixed, there is a reset button on top of unit, take off cover and push it, it happens when a downdraft comes in thru the vent i guess. simple as that, ps i replaced the thermocoupler anyway hope that works. $65.00 for the repair but its 12 ft up and tight.
i figure its worth it garage wont freeze
gogopntr is offline   Reply With Quote
Old 02-03-2012, 05:24 PM   #5
dave67fd
Senior Member
dave67fd's Avatar
What is your gas source? Are you sure manifold, line pressure is correct? 75k BTU heater at 15 min is enough to drain a small source if thats what your using. Might be enough to keep pilot lit but not the burners.
__________________
Check out my Build at:
http://www.garagejournal.com/forum/s...d.php?t=102939
dave67fd is offline   Reply With Quote
Old 02-01-2014, 03:54 PM   #6
MrBillJr
Junior Member
Just wanted to say THANK YOU! This fixed my problem. Your instructions were right on. We had high winds last week when I was away, when I got back, fan was running with the gas valve locked out...No Heat. Thanks again guys.
MrBillJr is offline   Reply With Quote
Old 10-30-2015, 05:52 PM   #7
firstyearta
Junior Member
I am having a very similar issue with a Modine hanging shop heater (model PD 400AE0130). Due to some road construction in the area, the gas company shut our gas off for a while and told us we'd have to turn it back on. I forgot all about that till I went to run the heater and it would not light. The gas is on now but still will not light. My heater does not have a pilot light, just an electronic ignition. I can hear it trying to light, but it's like it still does not have gas to the unit. I looked for a reset switch (as mentioned above) but have not found anything. Any suggestions? Thanks!
Edit... Okay, I did find the reset switch after finding a diagram on line. The switch was not tripped and thus does not fix my problem.
firstyearta is offline   Reply With Quote
Old 10-30-2015, 06:27 PM   #8
Milton Shaw
Senior Member
Firstyearta, Have you checked to make sure you have the gas turned on outside at the meter. When the gas company cut gas off for road repair they went around and turned off all the gas supplies so that pilots would not be letting gas out in homes until someone came home and started the pilots correctly.
Milton Shaw is offline   Reply With Quote
Old 10-30-2015, 07:15 PM   #9
firstyearta
Junior Member
Yeah, gas is positively on because it feeds other heaters as well and they are working fine.
Old 10-30-2015, 07:20 PM   #10
zmaxmotorsports
Senior Member
zmaxmotorsports's Avatar
Id check the limit switch.
zmaxmotorsports is offline   Reply With Quote
Old 10-30-2015, 09:00 PM   #11
deckmonkey
Junior Member
You might have bled the line yet, it can take a little bit to do it. You can keep turning off the unit when it kicks out. Or you can turn off the valve at the unit and partially open the union then open the valve until you smell gas. Retighten the union, turn on valve, soap test the joints and fire the unit. It should go in one or two tries.
deckmonkey is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
