Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 01-29-2011, 11:55 AM   #1
nato
Senior Member
nato's Avatar
Default BEST Metal cutting reciprocating saw blades???
I've blew through 4 lately and need some advice. I have a Craftsman 6 amp saw that came w/ it's 'own' wood and bi-metal blades. Yeah, those blades...anyhow, I picked up a DeWalt bi-metal, a Ridgid bi-metal and a Diablo demo/b-metal from Home Depot. Ridgid was also junk after a couple uses. The heat KILLED it!!!! The DeWalt is good, but it seems to take forever to cut through exhaust piping. It hasn't worn as fast even for having a lesser TPI like the Ridgid. The Diablo was sweet at first, then all of a sudden, it still cuts, takes a really long time and the blades feel sharp and worn at the same time. It's a very odd feeling to run your fingers across the Diablo teeth.
Any recommendations?????? I use these primarily for exhaust piping and other thinner metals.
nato is offline   Reply With Quote
Old 01-29-2011, 12:16 PM   #2
reptilezs
Senior Member
Default Re: BEST Metal cutting reciprocating saw blades???
http://www.garagejournal.com/forum/s...ighlight=lenox
reptilezs is offline   Reply With Quote
Old 01-29-2011, 12:32 PM   #3
Oggy
Senior Member
Oggy's Avatar
I used to work for a power tool company, and as much as they wanted me to push our blades, I did too, I got a bonus for hitting my sales goals, I knew the Lenox blades were/are a far superior product. The best I've ever used, I always sold them with my reciprocating saw. My blades I'd typically throw in as a bonus, they weren't bad just the Lenox were THAT much better.
Oggy is offline   Reply With Quote
Old 01-29-2011, 12:42 PM   #4
Roman G
Senior Member
Roman G's Avatar
Yup Lenox all the way. I used to work for fastenal and could sell the shit out of Lenox and Norseman 182 degree split point bits. There is none better.
As a side note I just picked up a 5 pack of lenox bimetal blades at goodwill for 2.99.
Roman
Roman G is offline   Reply With Quote
Old 01-29-2011, 12:52 PM   #5
jayrush13
Senior Member
jayrush13's Avatar
Lennox all the way the dewalt ones Suck big time even there wood blades get dull fast
jayrush13 is offline   Reply With Quote
Old 01-29-2011, 12:53 PM   #6
scott37300
Senior Member
Lenox and they offer a free one right now. I have been using them for years, they are expensive but when you need 2-3 other manufacturer blades to cut what one lenox blade can do the price is worth it.
It also makes a difference on TPI when cutting metal. The demo blades I have seen are pretty low TPI and you would want something with higher TPI. I have cut lots of exhaust with a recip saw, just have to use the right blade. If the exhaust is off the car I cut it with my portaband or dry cut saw, if it's on the car it gets cut with a recip or cut off wheel.
scott37300 is offline   Reply With Quote
Old 01-29-2011, 01:33 PM   #7
bart1
Senior Member
bart1's Avatar
I used the Lenox and Milwaukee Torch which were okay, but honestly a 4.5" angle grinder was almost always better to me.
bart1 is offline   Reply With Quote
Old 01-29-2011, 01:49 PM   #8
gReves
Senior Member
gReves's Avatar
Milwaukee Torch blades
__________________
"If I had all the money back that I've spent building trucks, Id spend it all on trucks." -gReves
gReves is offline   Reply With Quote
Old 01-29-2011, 02:05 PM   #9
wilb1976
Senior Member
Another vote for Lennox, hands down.
wilb1976 is offline   Reply With Quote
Old 01-29-2011, 02:07 PM   #10
Bull
Bull's Avatar
Well crap, I need to be a pro contractor to get a free blade from that Lenox deal?
__________________
EUDAIMONIA
"It Pays to Stay in the USA!"
Bull is offline   Reply With Quote
Old 01-29-2011, 02:13 PM   #11
Addrock
Senior Member
Addrock's Avatar
Bosch demolition is my favorite.
Addrock is offline   Reply With Quote
Old 01-29-2011, 02:37 PM   #12
nato
Senior Member
nato's Avatar
Well, that was easy. The Gold's or the Lazer's...is there any huge difference other than the fact the Gold's are designed to handle different materials better than just the metal-rated Lazer's?
Old 01-29-2011, 03:57 PM   #13
larry_g
Senior Member
If heat is killing your blades then slow down the saw. Most recip saws go way to fast for metal work. A bit of cutting oil will help also. If you have a choice of straight line or orbital motion of the blade choose the orbital. The thinner the work then the higher tooth count blade are called for. The rule of at least 3 teeth in the cut still applies.
lg
no neat sig line
__________________
My Shop build thread
Great minds talk about ideas, average minds talk about events, small minds talk about people.
Wise people talk because they have something to say. Fools talk because they have to say something.
larry_g is offline   Reply With Quote
Old 01-29-2011, 04:08 PM   #14
Amitygravel
Senior Member
Amitygravel's Avatar
Milwaulkee Torch. Little bit thicker , Lennox are good too slightly thinner which has its advantages. Whatever brand, slow your speed down , and use any kind of oil for coolant. It makes a big difference.
Amitygravel is offline   Reply With Quote
Old 01-29-2011, 04:39 PM   #15
chewy7
Senior Member
chewy7's Avatar
Milwaukee torch blades. They cut good and are really tough.havent bent one, or broken one yet cutting all kinds of thick steel
__________________
Being able to reach into your roll away tool chest and finding the right tool for any given situation/repair; is the ultimate power trip!
The best warranty is one you never have to use.
chewy7 is offline   Reply With Quote
Old 01-29-2011, 06:24 PM   #16
Bull
Bull's Avatar
Some of you might remember my "Monster Under the Stairs" thread. That thing is still there; haven't made any progress since whenever I made that thread. I had no idea you were supposed to lower RPMs to cut heavy steel. I will try it next time. I probably blew through 3-5 of either the Milwaukee Torch or the Lennox Lazers and I didn't even cut the first third of the thing apart.
__________________
EUDAIMONIA
Old 01-30-2011, 08:30 PM   #17
Kev442
Senior Member
Kev442's Avatar
I like Lenox and I also bought a Morse Demolition blade last year. So thick I had to sand the paint off it to get it in the saw. It was nice to hack a car apart without bending the blade on hidden stuff. The blade just bounced off them.
Kev442 is offline   Reply With Quote
Old 01-31-2011, 03:46 PM   #18
RTrac1
Junior Member
RTrac1's Avatar
I like the Torch better than the Lennox blades because theyre a little tougher and harder to bend.
RTrac1 is offline   Reply With Quote
Old 01-31-2011, 07:31 PM   #19
Amitygravel
Senior Member
Welcome to the GJ RTrac1 !
Old 01-31-2011, 07:51 PM   #20
american lockpicker
Craftsman(I strongly suspect its made by the same comapny thats makes Bosch blades in Switzerland.)
american lockpicker is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
