Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 04-13-2007, 07:54 PM   #1
VvvJRvvV
VvvJRvvV's Avatar
Default Belt Drive vs. Chain Drive vs. Screw Drive
My wife is bugging the crap out of me to put in a garage door opener for her. I keep telling her the current model I have is much cheaper (her arms).
From everyone I have talked to, I think I want to go with either a belt or chain drive. The noise either way will not bother me, this is a seperate garage / pole building.
Looking for anyone elses thoughts on this.
Thanks
VvvJRvvV is offline   Reply With Quote
Old 04-13-2007, 08:03 PM   #2
bmwpower
bmwpower's Avatar
Send a message via AIM to bmwpower Send a message via Yahoo to bmwpower
Default Re: Belt Drive vs. Chain Drive vs. Screw Drive
Get a belt. A little more than a chain/screw, but worth it in quietness.
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4
my garage build | my wanted list
bmwpower is offline   Reply With Quote
Old 04-13-2007, 08:17 PM   #3
wythors
Red Foreman is my idol.
wythors's Avatar
I have an older Craftsman chain drive on one side and a two-year old Craftsman shaft drive on the other. This is in a basement garage and neither is significantly louder or quieter than the other, and both are very reasonably quiet to my ear. They both go up and down at the same speed, but I will eventually replace the older one with another shaft drive model when the time comes. The shaft drive just seems a lot more "precise" for lack of a better term.
__________________
The bitterness of poor quality remains long after the sweetness of low cost is forgotten.
Click here for pictures of my garage!
Original GarageJunkies.net member #329
wythors is offline   Reply With Quote
Old 04-14-2007, 01:16 AM   #4
ovilla
Senior Member
ovilla's Avatar
I have a screw drive and it is noisy but will never break and fall on the roof of my car. The belt units will someday stretch the belt and need to be replaced while the chain drive will somday break (only if not lubricated) and will fall on the roof of your car and give you a greasy scratch (happened twice to me). Also, if you tighten the chain too much in an attempt to take up the slack you will prematurely wear out the trolley assembly too. I-drive units are quiet and really fast but a pain to set up (I have a WD i-drive too). Finally, any shaft drive unit will easily cost more than two belt units and is only needed if you need the headroom for a lift. Really, the best of all evils is a quiet belt drive with a battery backup unit. Just look for a Sears Craftsman Days sale and you can get one for a decent price. Good luck!
ovilla is offline   Reply With Quote
Old 04-14-2007, 06:22 AM   #5
Rickster
Senior Member
Rickster's Avatar
I have the screw drive unit, hate it, my next one will be a belt drive. I find the screw drive to be very loud. I have to lube it to quiet it down but it only last a short time and drops a gob of grease on the floor which I have tracked into the house twice now.
__________________
Rickster
Everything is for sale!
My eBay Sales
Rickster is offline   Reply With Quote
Old 04-14-2007, 09:31 AM   #6
nova65ss
Senior Member
nova65ss's Avatar
We have used the beltdrive units for 10 years or so and have never had one break. Liftmaster has a Lifetime warranty on the belt as well. It is made of kevlar and reinforced with steel belts similar to a car. The beltdrive requires zero maintenance will not stretch and never need tightening.
I personally do not like screwdrives as said before they require lubrication and often times in the winter they stall and will not go up or down until the force settings are adjusted.
Jimmy
__________________
www.garagedoorspecialist.net
nova65ss is offline   Reply With Quote
Old 04-14-2007, 01:20 PM   #7
VvvJRvvV
VvvJRvvV's Avatar
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
I was looking at this one from Sears. They have one with a battery backup for a bit less, but, I was told it was a discontinued item. Item number on this one is 53914.
Thanks,
JR
Old 04-14-2007, 02:15 PM   #8
Junkman
Senior Member
Junkman's Avatar
It looks like a Liftmaster unit to me based on the controls. Liftmaster is the brand that I have and I like it very much. I have never had any problems with the brand, so that alone makes it a good unit in my opinion. Mine are all chain drive units. Not the quietest, but overall, the noise upon opening or closing isn't that great that it is a annoyance.
__________________
Philosopher Emeritus Of Garage Journal
Men wake up as good-looking as they went to bed.
Women somehow deteriorate during the night.
Never argue with an idiot. He'll drag you down to his level, then beat you with experience.
Junkman is offline   Reply With Quote
Old 04-14-2007, 04:52 PM   #9
DARK AGE 53
Senior Member
DARK AGE 53's Avatar
Before it broke I had a chain drive, I never cared for it and will replace it with a screw drive opener.
DARK AGE 53 is offline   Reply With Quote
Old 04-14-2007, 06:30 PM   #10
Glen
At my previous house, I had a Sears belt drive, which I believe was manufactured by Chamberlain. In the 5 years I had it, it worked perfectly. Belt drives are generally smoother and quieter then chains or screws.
Btw, now I have a WD iDrive and it's the best system I've ever had.
Glen is online now   Reply With Quote
Old 04-14-2007, 08:19 PM   #11
rodnok1
Senior Member
rodnok1's Avatar
I like the screw drives, had one on a 16' door for ever worked great. It was a little slow when it got real cold outside. I never cared for the chains hanging down myself.
rodnok1 is offline   Reply With Quote
Old 04-15-2007, 02:56 PM   #12
pwm72
I have two LiftMaster garage door openers. A belt drive and their Model 3800 Jackshaft opener. While the belt drive model is super quiet...the jackshaft opener is unbelievably quiet. I know it is not that much of a concern in your instance since you garage is detached, but in my case, my master bedroom is right over my garage...I can hardly hear the openers now.
pwm72 is offline   Reply With Quote
Old 04-15-2007, 11:26 PM   #13
Major Ramifications
Senior Member
Major Ramifications's Avatar
While we are on the subject, is there any advantage to chain drives? Cost?
I have a screw drive (was here when we moved in). It is super-reliable, just kind of noisy and won't win any races.
Major Ramifications is offline   Reply With Quote
Old 04-19-2007, 03:47 PM   #14
LiftMaster3265
Junior Member
Get a LiftMaster they have been known for there quiet whisper drive openers.
LiftMaster3265 is offline   Reply With Quote
Old 04-19-2007, 09:28 PM   #15
WTB
Junior Member
I have a extremely noisy opener made by Linear. I can't say the chain is the problem but the opener. I have never heard a motor this loud!
All of my neighbors have the same one and I can when they use them!
WTB is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
