Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-31-2011, 11:08 PM   #1
jomobco
Senior Member
jomobco's Avatar
Default Combining two air compressors
Weird question but I have a problem. My current compressor is a Home Depot husky with specs: 60 gal, Delivers 11.5 SCFM at 40 psi and 10.2 SCFM at 90 psi
135 PSI maximum pressure
It's not big enough. Can I just buy a second of the same compressor and combine the two with a pipe running between the plug on the side of the compressor? This would give me twice the CFM and 120 gallons of tank. Has anyone done this? Why wouldn't it work? I'm thinking because the pipe running between the two would be the weak link?
jomobco is offline   Reply With Quote
Old 01-31-2011, 11:10 PM   #2
alecmcmahon
Senior Member
alecmcmahon's Avatar
Default Re: Combining two air compressors
While I cannot comment on if this would work or not.
Would it not make sense to sell your current compressor and buying a better one rather then buying a second of the same compressor that is undersized for you and trying to frankenstien them together?
alecmcmahon is offline   Reply With Quote
Old 01-31-2011, 11:32 PM   #3
jomobco
Senior Member
jomobco's Avatar
It would make sense but may not necessarily be the best value if this would work. For ease of discussion the next bigger home depot husky is:
Powerful 5 HP engine provides up to 10,000 hours of extended life
175 psi maximum pressure
Delivers 12.6 SCFM at 90 PSI to provide quiet, abundant airflow to power multiple tools
Steel 80-gallon tan for $1079. Less the $200 I might get for my current unit. That increased PSI would certainly make the 80 gallon tank last a lot longer than the 60 I would imagine.
My current set-up is $439. X 2 it has better specs with the exception of overall PSI.
Old 01-31-2011, 11:33 PM   #4
CUSTOMMANCAVES.COM
Senior Member
You will not double your SCFM or PSI by combining tanks. You will only double your air supply.
CUSTOMMANCAVES.COM is offline   Reply With Quote
Old 01-31-2011, 11:41 PM   #5
isaac338
Senior Member
isaac338's Avatar
Quote:
If you have two pumps, your total CFM output will be the sum of both their outputs.
isaac338 is offline   Reply With Quote
Old 01-31-2011, 11:41 PM   #6
Nosferatu
Senior Member
Nosferatu's Avatar
And you'll double the amount of power you use to do it.
Nosferatu is offline   Reply With Quote
Old 01-31-2011, 11:54 PM   #7
Chestrockwell
Junior Member
I am in the process of doing this. I have 2 80 gal comps each has a valve at outlet, then rubber hose to a T, then off to the dryer, then off to the shop.
Not sure why OP says the pipe between would be the weak link. This shouldn't be an issue if done properly with some flexible lines.
The part I put most thought into is the wiring. First thought they should come one separately and off together but then you would have 1 compressor filling 160 gal. most of the time. So my plan is to wire them together on the same pressure switch (with proper contactors to handle the full current for each motor). Still looking for practical ideas on this part of the setup, though.
Of course 1 bigger compressor would be more efficient and simpler but when you get 2 nice units for cheap it is hard to justify the $$$ on a 10HP unit.
__________________
Subaru Jesus
Chestrockwell is offline   Reply With Quote
Old 01-31-2011, 11:56 PM   #8
Chestrockwell
Junior Member
Oh and don't forget the extra $$ for extra wiring, conduit, breakers, piping, fittings, hoses, clamps etc. add a big amount to this project.
__________________
Subaru Jesus
Old 02-01-2011, 12:28 AM   #9
CARS
Senior Member
CARS's Avatar
Quote:
Each tank inlet has a one-way valve. Air goes out, not back in. One could easily be added to a tank outlet I would think. Might be a restriction though.
Most body shops have 2 compressors (well, the big ones have a large rotary screw compressor). I have talked to compressor salesmen and they state that it is often recommended to run 2 smaller compressors v/s a one large one. The starting load of 2- 5 hp compressors, with a staged start (2 different start psi switches) is FAR less than starting a 10 hp compressor.
(i.e.... the lights wont dim every time it turns on)
CARS is offline   Reply With Quote
Old 02-01-2011, 12:31 AM   #10
jomobco
Senior Member
jomobco's Avatar
I guess if I'm running hard lines in the shop I could just t the hard line and run both compressors into the supply. Both are 110v so wiring isn't an issue. I think it would be best to have them on separate breakers in case they both kick on at the same time. Good points about shut off. My biggest issues are when I plasma and I think the double supply of air might get me close. Heck I could add a 3rd compressor for slightly more than the next bigger one at HD. The noise would suck though. I wonder how much louder it would be than a comparable single unit?
Old 02-01-2011, 12:44 AM   #11
Chestrockwell
Junior Member
There is a 100A breaker feeding my compressor shack and I can turn both compressors on at once and the lights don't dim, there is no problem with that.
Other reason I am starting and stopping the motors on the same switch is because with 2 separately switched motors it would be tough to stop them at the same time. So one compressor runs for a long time to reach it's off pressure. It's kind of stupid because when I have the plasma table running for 45 minits straight and I'm running a die grinder or whatever else at the same time; that higher 'off pressure' compressor runs all the time.
Even 2 120V compressors don't seem like enough for plasma cutting if you ever get into gouging or long cuts you will probably never be happy with them. I would strongly suggest getting a 240V unit and proper sized wire/breaker.
__________________
Subaru Jesus
Old 02-01-2011, 12:54 AM   #12
Vicegrip
Senior Member
Vicegrip's Avatar
I run staggered cycle systems at work all the time. Set one compressor to come on at a slightly higher pressure than the other. This means one will start to make up air and will be the only one to come on if you only draw a little bit off. The other one kicks in when the first cannot maintain the second starting pressure point. Every so often switch the pressure settings so the other compressor comes on first. You can also just leave it set so the same compressor always runs first. In the home setting you don't need to worry much about cycling them both equally. Do not run both on one switch as most pressure start switches also have a cylinder unloader built in.
No fancy wiring, no high load from two motors coming on together, less noise. Simple plumbing, a T fitting. There is nothing wrong with a long run time for a compressor. In fact, like cars, it is good for it as it heats the oil and gets moisture out.
__________________
A wise man knows his ignorance. A fool thinks he knows everything.
Vicegrip is offline   Reply With Quote
Old 02-01-2011, 03:04 AM   #13
keweenawbee
keweenawbee's Avatar
I used two together with a T arrangement for my air hydraulic log splitter. Made a ton of racket but got the job done. Finally bought a 60 gallon vertical oil lubricated and the noise difference is like night and day.
keweenawbee is offline   Reply With Quote
Old 02-01-2011, 06:30 AM   #14
ChristopherLutz
Senior Member
There is no reason this can't (or even shouldn't) be done. In another forum there is a whole thread on this.....I just can't seem to find at the moment.
Is your problem working time or max PSI?
As one poster said above, your PSI will not increase at all in this set up....the motors aren't strong enough to compress the air any more than 135 PSI; however, you will effectively double the working time you have at whichever setting you're working with.
Your spec above looks like an oiless version - 2 of these would be LOUD.
ChristopherLutz is offline   Reply With Quote
Old 02-01-2011, 12:31 PM   #15
scooterseats
Senior Member
scooterseats's Avatar
Industrial settings frequently use multiple compressors for factory air supply. They are always setup with a "Lead" unit and "Slave" units. The "Lead" unit is set to come on first and typically carries all the load until the load exceeds the capacity of the "Lead" compressor then the "Slave" compressors come on to help out. If you are concerned about one compressor running more than the other then just routinely alternate the "Lead" compressor with the "Slave" units to balance out the run time of the individual units. I would set the units to come on in 5# differences with the same delta P the units will also cascade with this same 5# drop on shut off pressures.
__________________
Ross Murphy
24X30 Brick Veneer with heat and AC
30X40 post construction metal clad
scooterseats is offline   Reply With Quote
Old 02-01-2011, 12:33 PM   #16
uhohjim
Senior Member
Quote:
EXACTLY...+less down time between Start ups on the compressors.........
uhohjim is offline   Reply With Quote
Old 02-01-2011, 12:41 PM   #17
TAMPAGT07
Senior Member
TAMPAGT07's Avatar
Best advice...Sell it and upgrade....
__________________
Full Patch Page 1 Member
Official Title- Liaison to the deputy director to the traveling secretary of adult entertainment and internal affairs for The Florida Garage Life Club.
This posting is copyrighted by TAMPAGT07 for the private use of our audience. Any other use of this posting or any pictures, descriptions, or accounts of the posting without TAMPAGT07's consent is prohibited. (This mesage was bought to you by TAMPAGT07''s legal team, the three Robinowitz's)
TAMPAGT07 is offline   Reply With Quote
Old 02-01-2011, 01:36 PM   #18
nehog
Senior Member
nehog's Avatar
I have my shop compressor, and a portable IR compressor. The shop one is about 8 to 10 CFM which is not enough for a few things I do. The IR portable is 4.5, which combined with the shop gives me just enough air.
I made up a short hose with two male connectors, and a ball valve in the middle. Close the valve, connect the two compressors (with the valve closed there is no leakage) then open the valve. Takes about 30 seconds to do. I use this configuration about once a year (maybe twice, not not often...)
__________________
My name is Peter, and I'm never going to grow up.
30 x 60, oops, 30 x 72 (it got larger!) with a Rotary 10K lift.
AM General H1 NA Wagon (95 For Sale)
AM General H1 Turbo Wagon (99)
Volvo S80
Mercedes Benz Sprinter RV
Saab Turbo Convertible
VW Cabriolet
nehog is offline   Reply With Quote
Old 02-01-2011, 03:23 PM   #19
jam0o0
Senior Member
if you're planning on running 2 oil-less compressors i sure feel bad for you neighbors. i can't work around those things. they are just soooo much louder than low rpm oil-bath unit.
the only benefit to getting a second cheapy compressor is that replacement cost when they die is a smaller bite. but you'll be replacing them more than twice as often.
if you figure in the cost of an enclosure to cut down on noise then i bet the better compressor is a better deal.
jam0o0 is offline   Reply With Quote
Old 02-01-2011, 04:28 PM   #20
toolsd
There's a few more issues that haven't been addressed.
To make a long story short, I see no problem with adding another compressor. However, you'd be wise in this setup to switch between the two units separately (some sort of two way valve could be easily arranged to switch one out, and the other in).
Without some sort of rather complicated schemes, you could wind up having only one unit pressurize all 120 gallons. The problem there is that units in this quality range usually DO NOT have a hundred percent duty cycle. That's what limits them to whatever size tank they are on, can't fill up a lot more than that without a lot of undue stress on the thing.
If you are using single stage units rated for 100 percent duty cycle, just go for it. Staggering the pressures a bit will be fine.
With two units, and a simple valve arrangement, you can switch between the two, and keep your volume and pressure up, AND reduce the duty cycle time on both units. A win win, and is nice that you don't have to sell a unit at some reduced price to upgrade.
I've found that in ANY high use air situation, sitting at the sand blaster, running my die grinder (it's a hog...), taking a break as often as you'll need to anyway to switch between the units supplying your shop piping wouldn't be a problem at all.
By the way, running a compressor to the point everything warms up is bad in a way. The warm air (inevitable because of compression, boyles law) eventually warms up the tank. THEN, all the moisture in the air, stays in the air and winds up in your tools, sandblaster or paint. When it first starts up and everything is cold, the moisture condenses inside the tank (not great for the tank, but it keeps it out of everything else) and you get nice dry air at the point of usage.
Keep in mind that the water separators common to most systems are really water PARTICLE separators. Water VAPOR separators use either a dessicant or a heat exchanger (usually CRAZY expensive using refrigeration).
Lastly, and I'm sure this has been hashed and hashed and hashed here at some point, is that in deriving what you really have for horsepower on top of these things, you need to figure out the 110v amperage, and divide by 15 (as a very rough rule of thumb). A 15 amp motor (running on 110v) is 1 hp. Many air compressors will list this thing as a 5hp or whatever... it's nonsense. You're not gonna get but about 4 or 5 cfm at around 90psi out of 1 hp. It's all fairly linear in the ranges we play with these things.
All generalities, but will serve better than relying on whomever's advertising department figures.
Tools
toolsd is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
