Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 02-05-2011, 06:54 AM   #1
billcole
Senior Member
Default garage door frozen shut
I would like to know what you guys have done to keep the garage doors from freezing shut. I only heat my garage when I work in it and usually water forms at the bottom then overnight it freezes. I would like to stay away from salt because I don't want to hurt the floor, any suggestions.
billcole is offline   Reply With Quote
Old 02-05-2011, 07:13 AM   #2
poppop
Default Re: garage door frozen shut
Leave the door up a little higher.
poppop is offline   Reply With Quote
Old 02-05-2011, 07:20 AM   #3
nate379
Leave it open a little bit.
nate379 is offline   Reply With Quote
Old 02-05-2011, 07:23 AM   #4
JeremyManning
Senior Member
JeremyManning's Avatar
I plug in a trouble light close to the door, also spray the weather stipping with pam helps to not let it stick to the ice
__________________
My Wanted Items
http://garagejournal.com/forum/showt...66#post2337266
License Plate Needed for My Collection
US States- DE, SC & WV
Canadian Provinces - Nova Scotia, Yukon & Nunavut
JeremyManning is offline   Reply With Quote
Old 02-05-2011, 07:25 AM   #5
lilredex
Senior Member
At a place I had, there was the same problem. It was an overhead type door, so I put extra holes in the track a couple of inches above the original ones. That way it could be off the ground and still be locked. It worked out OK...........no racoons (or squirrels) around there.
lilredex is online now   Reply With Quote
Old 02-05-2011, 09:09 AM   #6
nehog
Senior Member
nehog's Avatar
Spray the rubbers seal with silicone spray? Or any other rubber safe non-stick spray?
Me, I give the door a bit of a kick to break it loose if it is frozen down. Seems to always work.
__________________
My name is Peter, and I'm never going to grow up.
30 x 60, oops, 30 x 72 (it got larger!) with a Rotary 10K lift.
AM General H1 NA Wagon (95 For Sale)
AM General H1 Turbo Wagon (99)
Volvo S80
Mercedes Benz Sprinter RV
Saab Turbo Convertible
VW Cabriolet
nehog is offline   Reply With Quote
Old 02-05-2011, 09:28 AM   #7
darkk
Senior Member
Lay a piece of plastic ( or plastic paint tarp ) under the door before you close it...
darkk is offline   Reply With Quote
Old 02-05-2011, 09:56 AM   #8
rquackenbush
Senior Member
rquackenbush's Avatar
I like the "spray the seal with teflon" plan. That way you're still closing the door all the way.
rquackenbush is offline   Reply With Quote
Old 02-05-2011, 10:15 AM   #9
Buckgnarly
Senior Member
Buckgnarly's Avatar
Vaseline on mine. no problems since.
Buckgnarly is offline   Reply With Quote
Old 02-05-2011, 05:07 PM   #10
rodm1
Senior Member
Silicon and Armor all works OK to.
rodm1 is offline   Reply With Quote
Old 02-05-2011, 06:33 PM   #11
s_ontario
Senior Member
s_ontario's Avatar
rub with wax toilet ring...... yes it works
s_ontario is offline   Reply With Quote
Old 02-05-2011, 06:50 PM   #12
nehog
Senior Member
nehog's Avatar
Quote:
Only problem with Armor all is that it is too water soluble and needs respraying more often.
__________________
Volvo S80
VW Cabriolet
Old 02-21-2013, 07:35 AM   #13
Big-Foot
Senior Member
Big-Foot's Avatar
Okay - I just had this problem yesterday. Thank God the opener stalled and stopped. I will be looking into some other alternatives to the WD40 I sprayed on the floor and the seal to keep them from sticking together for a day or so. Not a fan of leaving it open a little as it's a great way to bring mice in from the cold. Not a fan of using a vegetable oil spray like PAM because it might attract the little buggers (mice) also.. Plastic on the floor idea would work until the car drove across it..
Any other creative or proven ideas out there?
__________________
Regards - Randy
http://www.GT-Forty.com
Big-Foot is offline   Reply With Quote
Old 02-21-2013, 08:34 AM   #14
dirttracker18
Senior Member
dirttracker18's Avatar
Funny you should post this because whenever a thread regarding drains pops up and we mention freezing, someone always argues that it never happens or they have never heard/seen such a thing.
Mine freezes only slightly as I have heated floors to keep it from freezing solid.
Silicon spray seems to work well but needs to be applied to a warm seal. A hair drier helps to warm things up before application.
__________________
"Success is when you reach a point in your life when you don't feel the need to go back and change things."
Johnny S.
www.LauraMyersPhotography.com
dirttracker18 is offline   Reply With Quote
Old 02-21-2013, 08:39 AM   #15
djjsr
Senior Member
djjsr's Avatar
I spray it with de-icer. The stuff you spray on windshields.
djjsr is offline   Reply With Quote
Old 02-21-2013, 08:45 AM   #16
crf731
Senior Member
Depends on how much water is pooling under your door.
If it is just a little bit, cut a sheet of plywood into 1' wide strips and lay them under the door so the door closes on top of the plywood.
You could put a heat tape in the bottom of your door to keep it warm so it doesn't freeze, but pluging it in all the time would be a pain.
I've seen a weather seal somewhere that is about an 1" high that you glue down to the concrete and the door closes on top of that, kind of like the plywood idea. Can't remember exactly where I saw it but I think it was in the skymall magazine on an airplane.
crf731 is online now   Reply With Quote
Old 02-21-2013, 08:47 AM   #17
roblouvasz
Senior Member
roblouvasz's Avatar
Location: Somewhere between the end of the line and the middle of nowhere
What about addding a threshold? I've others on GJ do it.
roblouvasz is offline   Reply With Quote
Old 02-21-2013, 09:56 AM   #18
Stuart in MN
Senior Member
Stuart in MN's Avatar
I just kick the bottom of the door a couple times to break it loose before I open it. If it's stuck down hard, I can slip the edge of my snow shovel under it and pry it loose.
It only happens to my door a couple times a year so I haven't put much thought into solutions.
Stuart in MN is offline   Reply With Quote
Old 02-21-2013, 01:30 PM   #19
Big-Foot
Senior Member
Big-Foot's Avatar
thanks guys.. I think I will try the silicone... Drying to get the wife to kick the door is going to result in
A) Damaged Door
B) Damaged Foot
C) All the above and I get a Damaged set of pills...
It was a bugger to pry up when I used my crow bar... frozen for a good 5'
__________________
Regards - Randy
Old 02-21-2013, 04:24 PM   #20
yuk
Senior Member
DONT DO THIS!!!, i once did and then my toilet leaked afterwards.
yuk is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
