Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 02-08-2011, 05:54 PM   #1
OIIIIIIIO
Senior Member
Default truss spacing...?
Hi,
I'm pretty sure I know what the answer will be from the guys on this board...I did search a little bit, but just want to confirm...
What are your thoughts on having trusses set 24" on center with 7/16" OSB sheathing an H-clips vs 16" OC...one side of the garage with have nearly 7/12 pitch (scissors trusses)...the other will be 4/12 (storage/spreadweb trusses)...I'm in south central Wisconsin...
My father-in-law (licensed contractor in IL) and I (no construction knowledge of any kind) am concerned about a potential wavy-roof with the extra span of 24 OC (sagging of the sheathing between the trusses)...but everyone else (truss designers, local building inpsector, etc...) seems to think it shouldn't be a problem with good sheathing....both say 90-95% of houses going up are going up 24" OC...but those same people say it's tough to find quality building supplies...things like sheets of OSB with not enough glue that they fall and flake apart and stuff...
Thoughts?
Thanks!
Patrick
OIIIIIIIO is offline   Reply With Quote
Old 02-08-2011, 06:03 PM   #2
flat350
Senior Member
flat350's Avatar
Default Re: truss spacing...?
I'm no expert,but you do see a lot of homes with the wavy roof syndrome with the trusses on 24" centers,new and old ones.
__________________
40 year res/comm licensed foreman/ journeyman plumber
flat350 is offline   Reply With Quote
Old 02-08-2011, 06:08 PM   #3
FRANKIEWHIPIT
FRANKIEWHIPIT's Avatar
When I built my Garage, the engineer spec'd 24" oc, for the extra $104.00 I went for the 2 extra trusses I needed to put them 16" oc i makes for a much nicer finished job!
FRANKIEWHIPIT is offline   Reply With Quote
Old 02-08-2011, 06:12 PM   #4
Addrock
Senior Member
Addrock's Avatar
I just built mine with a 10/12 roof 24 OC in southern WI. A steep pitch cures a lot of ills. It has had no more than 6" of snow all winter. The other thing taller pitch gives you is a room upstairs. When I ran the numbers it cost nearly nothing for the extra room. Because I built it myself I payed $17.33 per square ft. Good luck.
Addrock is offline   Reply With Quote
Old 02-08-2011, 06:12 PM   #5
Zeke
Senior Member
Zeke's Avatar
Location: Senior Member—in more ways than one in Long Beach CA
Quote:
Put that way, I would too. But, 7/16ths or what ever you call it, is not enough for 24 OC. So, if the 5/8ths you need is more than the extra trusses, you found your answer.
Zeke is offline   Reply With Quote
Old 02-08-2011, 07:16 PM   #6
OIIIIIIIO
Senior Member
According to my calculations for my garage (one run is 36'...the other is 20')...24 OC vs 16 OC results in 28 trusses vs 42...
Old 02-08-2011, 07:26 PM   #7
framer
Junior Member
2ft. centers is standard with 7/16 osd. Have seen allot of roofs with asphalt roofing look wavy when frost is on top. Most of time problem is caused by lack
of good roof and soffit ventilation. Condensation on underside of osb causes
swelling of panels. Framer
framer is offline   Reply With Quote
Old 02-08-2011, 08:05 PM   #8
Doug B
Senior Member
Doug B's Avatar
If it is an option,you should upgrade to 5/8 sheathing with clips , or better yet, 5/8 t&g sheathing.
Doug B is offline   Reply With Quote
Old 02-08-2011, 08:11 PM   #9
aar0s
Senior Member
aar0s's Avatar
Most homes around here (southern Illinois) put trusses on 24's with 5/8 osb roof deck, if you have your heart set on using 7/16 then plan on buying a few extra trusses and put them on 16's dead over the studs. If your worried about snow load or any extra weight on the roof system 16 inch centers is a good idea anyway.
That said i have seen some use 3/4 plywood and trusses on 16's before, talk about a solid roof!
__________________
Our lives are determined by opportunities, even the ones we miss.
Quote:
Originally Posted by 432bullet View Post
I have never seen a Brinks truck following a hearse yet. Just a thought.:)
aar0s is offline   Reply With Quote
Old 02-08-2011, 08:12 PM   #10
327-365hp
I used 1/2" ZIP Roof which doesn't require clips at 24" OC. That stuff is heavy, it's OSB with a laminate on top. It's weatherproof for 30 days.
327-365hp is offline   Reply With Quote
Old 02-08-2011, 08:17 PM   #11
Wanna Ride
Senior Member
I too, live in Illinois. Back about 13 years ago, I personally built my garage. It's a 40' x 30' with 6-12 pitch trusses on 24" centers, with 7/16"OSB and H-clips. Mine shows no signs of dipping between trusses.
__________________
The internet... where it's more commonplace to have a keyboard, than a clue.
Wanna Ride is offline   Reply With Quote
Old 02-08-2011, 08:45 PM   #12
NUTTSGT
NUTTSGT's Avatar
I used 1/2" OSB with clips on mine, along with 4/12 pitch.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 02-08-2011, 09:19 PM   #13
rwhite692
Senior Member
rwhite692's Avatar
My 24x36 is built with scissor trusses on 24" centers...The trusses were engineered for a tile roof, as well.
__________________
My 24x36 detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=16310
rwhite692 is offline   Reply With Quote
Old 02-08-2011, 09:41 PM   #14
kb2tha
Senior Member
kb2tha's Avatar
Quote:
I agree. I will use 5/8" ply with h-clips when using 24" centers. With 16" oc spacing I will use 1/2" CDX. If you do use the OSB for sheathing, just be sure you put the rough side up, or you may be looking at your roof on your back, from the ground.
Ken
kb2tha is offline   Reply With Quote
Old 02-09-2011, 01:54 AM   #15
Skyking1992
Senior Member
I have mine on 24" spacing with 7/12 pitch. Used 1/2" plywood with clips. No waviness yet. Located in Northern Illinois.
Skyking
Skyking1992 is offline   Reply With Quote
Old 02-09-2011, 02:50 AM   #16
Mr.N
Senior Member
Quote:
I take it you don't live in heavy snow country...
In MN many cities require 1/2 plywood as a minimum for code for snow.
Mr.N is offline   Reply With Quote
Old 02-09-2011, 03:06 AM   #17
Vethead
1/2" CDX 24" O.C. with a 5/12 pitch. No real snow load worries to speak of.
Vethead is offline   Reply With Quote
Old 02-09-2011, 08:17 AM   #18
little d
Senior Member
O, 36'(12")= 432" divided by 24"= 18+1=19. 20'(12")=240" divided by 24"=10+1=11.
36'(12")= 432" divided by 16"= 27+1=28. 20'(12")=240" divided by 16"=15+1=16.
So, at 24" on center you will use 30 and with 16" centers you will use 44.
My figures are not including any extra truses if needed.
Ok, now let me explain how i learned constrution. My Dad tought me, we tore down houses for the materal to fix up other houses. In doing so, I learned what worked and what didn't (time tested). The one thing that always stood out was carring the "load" from the peak to the foundation. This is something that I try to pass on to everyone that I can.
Can you set them on 24's, ya. Would I, for 14 extra trusses, no. I tend to over build but, I can walk away from a job knowing it is there to stay and not having to worry about comming back to fix something. This is just MHO, so take it or leave it, your shop, not mine.
I hope i gave ya something to think about, little d.
little d is offline   Reply With Quote
Old 02-09-2011, 10:26 AM   #19
5lima30
Senior Member
5lima30's Avatar
Another consideration is what type roofing material (metal or shingles) are you using? If shingles I would go with 16" OC. If metal I would be fine with 24" OC IMHO.
5lima30 is offline   Reply With Quote
Old 02-09-2011, 10:52 AM   #20
MP&C
Senior Member
MP&C's Avatar
When we installed the metal roof on our house and my shop, the metal roofing manufacturer specified 5/8 plywood on 2' centers. These used hidden clips to hold the standing seam roofing, held in by screws. I'm quite sure the plywood thickness was to increase the screw engagement and thus wind removal resistance. I'm also quite sure the Dewalt drills we used to screw in the clips would have stripped out holes in OSB. As usual, I went with overkill, the 5/8 plywood on 16" centers. Never have been a fan of OSB on a roof, or 2' centers.
__________________
Robert
MP&C Shop Projects-Metalshaping Tutorials
Super Street/Super Gas 65 Fairlane build
Instagram @ mccartney_paint_and_custom
MP&C is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
