Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 02-21-2011, 05:23 PM   #1
ChristopherLutz
Senior Member
Default Best Shower Head?
Ok...a bit off topic; however, I WAS in my garage over the weekend pulling apart a new shower head to remove the flow restrictor in a moderately successful attempt to get a good shower.
Any brands, suggestions, tips or "hot rod" ideas for shower heads? My water pressure seems "ok" - but, I can't seem to find a shower head that delivers a good shower.
the Mrs. complains she can't rinse her hair, etc. etc.
Ideas wanted - thanks.
ChristopherLutz is offline   Reply With Quote
Old 02-21-2011, 05:30 PM   #2
kartracer23
Senior Member
kartracer23's Avatar
Default Re: Best Shower Head?
Well there was this girl that I met one night in a bar, went back to my place, decided to take a shower and...
oh. wait. nevermind.
kartracer23 is offline   Reply With Quote
Old 02-21-2011, 05:31 PM   #3
Regnar
Senior Member
Mine use to complain about not getting the soap out of her hair. Now she complains there is not hot water after 8 minutes.
Regnar is offline   Reply With Quote
Old 02-21-2011, 05:37 PM   #4
SgtRauksauff
Senior Member
I really like this kind:
I first used them in the dorms in college, then have them in the house now. My concern with the big "fancy" shower heads, is that unless you have a LOT of pressure, you wont' get a strong stream, because the huge head allows the water to pool, rather than continuing to stream.
With the head above (you can even get 'em at wal-mart, I believe), there isn't really a collector on the end of it. I've never done any measuring, but I really believe that with this shower head, I actually use less water per given time of showering, because I don't have to crank up the pressure so much to get a good solid stream. a few times in the past, when I've become chilled from working outside too long in the cold, I've been able to take 1.5hr showers, and had wonderfully hot water the whole time. Whenever I'd try that before, I'd always end up getting about 25 minutes before the water would noticeably become cooler.
That's my opinion anyways.
--sareg
SgtRauksauff is offline   Reply With Quote
Old 02-21-2011, 05:40 PM   #5
rickairmedic
Senior Member
rickairmedic's Avatar
1 tankless water heater
2 rainshower overhead
3 firehose looking showerhead on main wall
4 2 showerheads on backwall both with multiple spray patterns
These make for a possible never ending shower and plenty of water to get squeeky clean ( or really dirty ) depending on the shower .
Rick
rickairmedic is offline   Reply With Quote
Old 02-21-2011, 05:42 PM   #6
JerseyJim
Senior Member
JerseyJim's Avatar
There's a Seinfeld episode on shower heads. I had tried a lot of different shower heads over the years and had been disappointed in some way or another with all of them. Went on Amazon and started reading reviews. Came up with one called the Alsons Fluidics Water Saving Shower Head. The model that I bought was the 656 rated at 1.85 GPM.
This is a standard shower head. It is not hand held. No adjustments. Nothing fancy. What I liked about this one is that the spray consists of large droplets. The volume of water seems much higher as a result.
It looks like Delta is now selling the same type of shower head. They call it H2OKINETIC.
Check both out on Amazon.
JerseyJim is offline   Reply With Quote
Old 02-21-2011, 06:07 PM   #7
metal1313
Senior Member
metal1313's Avatar
i tend to use mine on a "mist" mode, but it seems much stronger this way, and is supposed to use less water. one thing that made a major difference for me was to have the shower head mounted higher. im 6'3'' and they wanted to mount the shower head right at 6ft. i hate bending to shower so i had them mount it higher, and now its perfect.
metal1313 is offline   Reply With Quote
Old 02-21-2011, 06:33 PM   #8
Berserker
I had a bad shower valve, cut open the wall with a sawzall and put in a T with two ball valves, with the handles bent out. Best damn shower.
Berserker is offline   Reply With Quote
Old 02-21-2011, 06:38 PM   #9
54FordPanel
Senior Member
54FordPanel's Avatar
54FordPanel is offline   Reply With Quote
Old 02-21-2011, 07:19 PM   #10
Trainman
Senior Member
My vote is for a Sirolflex. Cheap white plastic, just one mode, but a really good shower especially if you take out the water saver parts. You can get them on feebay for less than $10.
Trainman is offline   Reply With Quote
Old 02-21-2011, 07:25 PM   #11
Frank The Plumber
Senior Member
Frank The Plumber's Avatar
Hansgrohe, pull the o ring out of it, Chicago faucet sells a commercial style head for public showers etc. Fully clean able, solid brass, costs a few bucks but you will never need another.
__________________
Visit My angelfish room at
http://www.facebook.com/pages/Indian...64072983609849
Frank The Plumber is offline   Reply With Quote
Old 02-21-2011, 07:30 PM   #12
ChristopherLutz
Senior Member
Quote:
Can you explain this a bit more? Did you create two shower heads?
Old 02-21-2011, 07:30 PM   #13
Torque1st
Senior Member
Torque1st's Avatar
SgtRauksauff, has it right. The same Peerless shower head is available at Alson's, Walmart, Lowe's, and Mills Fleet and Farm. All around $8-10.
The following link is for one version. I think the packaging differs slightly at different retailers:
http://www.peerlessfaucet.com/produc...duct.sku=76150
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 02-21-2011, 07:31 PM   #14
PassnThru
Senior Member
PassnThru's Avatar
Understand that you may not be getting enough water through the pipe to begin with to ever be happy with any showerhead. Do you have an older home with old pipe? It might be getting clogged up. Of course, if it's copper that probably isn't a problem. Maybe someone ran an undersize pipe to the bathroom to begin with? I would first try a little redneck measuring without a shower head into a 5 gallon bucket and figure out the flow rate just to make sure.
__________________
*** Looking to quote you here - preferably a quote you would rather we all just forgot. I'm watching......
(Excluding TampaGT - no shock value left there)
PassnThru is online now   Reply With Quote
Old 02-21-2011, 07:32 PM   #15
Torque1st
Senior Member
Torque1st's Avatar
Quote:
Think about it for a moment. Surely you can figure it out.
__________________
The FairTax
Old 02-21-2011, 07:35 PM   #16
Frank The Plumber
Senior Member
Take your shower head off and do a gpm flow test with just the arm into a 5 gallon bucket, mark a 2 gallon mark in it, time the fill to the 2 gallon mark, adjust to a minute. Most new shower heads deliver 2.5 gpm out of the box.
__________________
Old 02-21-2011, 08:17 PM   #17
volvo
Senior Member
volvo's Avatar
Love my Holiday Inn/Suites shower heads, had to buy two, one for each bath. Always get complements from those who use them.
KOHLER K-10284-CP Forte Multifunction Showerhead,
http://www.amazon.com/gp/product/B00...SIN=B000MVTMMO
volvo is offline   Reply With Quote
Old 02-21-2011, 08:34 PM   #18
Homoudont
Senior Member
Homoudont's Avatar
I'm not a plumber but I'll try and explain what was told to me by a plumber regarding water pressure. The further away your from the main line the less pressure you have, the closer you are the more pressure you have. If your too close to the main line then you run the risk of blowing out your plumbing fittings so they outfit regulators to houses to decrease the pressure. He showed me a diaphragm looking thing connected to the main line coming into the house. I believe he had me turn it counter clockwise a quarter turn at a time to increase the house pressure. He said you wanted to do it in small increments over a period of time so your not blowing out fittings in your house. Anyway a small turn was suffice enough to increase our water pressure to acceptable levels.
Maybe a plumber can chime in and give a more detailed or correct explanation of this.
Homoudont is offline   Reply With Quote
Old 02-21-2011, 08:41 PM   #19
OccupantRJ
Senior Member
OccupantRJ's Avatar
I buy a cheap one and drill out the restrictor plate instead of removing it altogether. You can keep drilling in increments until it suits you. When I have moved in the past, I took the shower heads with me and replaced the ones in the house I was selling.
__________________
RJ
It's always easier to find a reason NOT to do something.....
The sum of all your choices, good and bad, become your life.....
OccupantRJ is offline   Reply With Quote
Old 02-21-2011, 08:48 PM   #20
MP&C
Senior Member
MP&C's Avatar
The Commando 450:
__________________
Robert
MP&C Shop Projects-Metalshaping Tutorials
Super Street/Super Gas 65 Fairlane build
Instagram @ mccartney_paint_and_custom
MP&C is offline   Reply With Quote
Old 02-21-2011, 08:58 PM   #21
ishiboo
Senior Member
This Old House installed a model on the Auburndale house that had 3 flow settings, somewhere near 2.5/2.0/1.5 or something similar. Could be nice to get the GPM when you need it, and conserve water when you don't
It's pretty trick... it's held by water pressure, so the moment you turn off the water, it kicks back to the 1.5 setting.
ishiboo is offline   Reply With Quote
Old 02-21-2011, 09:58 PM   #22
59 wagon man
Senior Member
59 wagon man's Avatar
american standard has come out with a new low flow showerhead which is pretty good and uses about 1.5 gpm. barnett also has a good 1.6 gal showerhead
59 wagon man is offline   Reply With Quote
Old 02-21-2011, 10:32 PM   #23
56nash
Senior Member
I love my Danze handheld, only after yanking the restrictor. It was simply by removing and O-ring around a plastic part on the input of the handheld head. I have loved it for the past 5 years.
__________________
1956 Nash Metropolitan 90% restored
1950 Plymouth Suburban 2 door wagon, almost a roller
1962 Jeep FC-170 it ain't pretty, but it drives
1965 Dodge Dart project with the kids
56nash is offline   Reply With Quote
Old 02-21-2011, 10:49 PM   #24
SloppyDogDrool
Junior Member
http://www.walmart.com/ip/LDR-Nature...1300C/15821943
Drill out the hole in the plastic swivel ball. You might run into one problem. I used them for YEARS. Then they changed them. As I recall they started coming with a washer that had a smaller hole. I think if I recall correctly I swapped out the washers with one that had a larger hole in it. I would think you could also cut the washer carefully but it would be a whole lot easier to just swap the washer with one that has a larger center hole.
I've lived in a lot of houses with low pressure and low flow. I've used them in rentals with very happy tenants. I've modified them for relatives and family members and people raved about them. I lived in a small town with really old homes. The pressure either sucked or the flow rate was low. This was the best I could come up with that gives you decent pressure, flow and enjoyable shower.
Good Luck!
SloppyDogDrool is offline   Reply With Quote
Old 02-22-2011, 06:53 AM   #25
TN_GARAGE
Senior Member
Speakman Shower Heads are advertised as being used in some of the finest hotels in the world.
http://www.speakmancompany.com/products/list/Shower
TN_GARAGE is offline   Reply With Quote
Old 02-22-2011, 07:32 AM   #26
Frank The Plumber
Senior Member
Speakman is one of the best, Barnett is another hotel model, For a 5 year toss it head the barnett is the best, If you clean them and appreciate quality do the speakman or chicago.
__________________
Old 02-22-2011, 07:38 AM   #27
bluesman2a
Senior Member
I've always been a fan of the Speakman design. We've always had them in our house, as a kid, and now as an adult. Solid brass and you can drill them a bit for better flow yet.
While looking for a new showerhead on Amazon this morning for my shop-shower, I came accross this:
http://www.amazon.com/Giessdorf-Jet-...U/ref=lh_ni_t_
Looks like the same design, and less than half the price of the 8-jet Speakman. Favorable reviews, I think I'll try it for my main shower-head in the shop, just ordered one this morning.
bluesman2a is offline   Reply With Quote
Old 02-22-2011, 07:51 AM   #28
General Lee
Senior Member
I got to have a detachable shower head. Shower head on a hose, gotta be able to rinse the crack.
General Lee is offline   Reply With Quote
Old 02-22-2011, 08:26 AM   #29
cablebandit
Junior Member
http://www.highpressureshowerheads.c...head-home.html
I have the Supreme model. The only problem now is running out of hot water.
cablebandit is offline   Reply With Quote
Old 02-22-2011, 11:12 AM   #30
burleymike
Senior Member
When I put in the master bathroom I bought a cheap hand held head. The flow sucked so I pulled the restrictor out. We got sick of running out of hot water after 8 minuets so I put a valve between the head and the holder. Now when I am shaving I can turn the flow down to near nothing and when my wife is washing her hair she can open it up.
burleymike is offline   Reply With Quote
Old 02-22-2011, 01:47 PM   #31
darkk
Senior Member
the wife...
darkk is offline   Reply With Quote
Old 02-22-2011, 05:19 PM   #32
drmoonshine
Senior Member
Quote:
Originally Posted by MP&C View Post
The Commando 450:
Gotta have that pressure.
drmoonshine is offline   Reply With Quote
Old 02-22-2011, 05:35 PM   #33
mcdtommy23
Senior Member
Quote:
The cheap $1.99 home depot specials. Bought 10 of them a 5/16 drill and they are perfect.
mcdtommy23 is offline   Reply With Quote
Old 02-22-2011, 05:35 PM   #34
mrhorspower
Junior Member
Here is the newest and coolest. Flipside by Kohler. (4)different Experiences.
mrhorspower is offline   Reply With Quote
Old 02-22-2011, 07:41 PM   #35
jbs
Senior Member
We have a Speakman 6 jet in one shower and the High Pressure Shower Heads Supreme in the other. Both are very good, but the Speakman needs more pressure than we have. It was excellent at our other house, but not as good now. They are both very good though.
If you have the pressure, I recommend the Speakman. We have had ours for 15 years. The occasional vinegar bath keeps in clog-free and good as new. We've had the Supreme only a year, so no report on longevity for it.
Both have easily removable flow restrictors.
jbs is offline   Reply With Quote
Old 02-23-2011, 06:27 AM   #36
dragginbalz
Senior Member
dragginbalz's Avatar
http://www.takeashower.com/headshome.php
a bit pricey and a bit simple, but I switched one out in our of our bathrooms that wasn't getting decent water pressure, NIGHT AND DAY difference!! I didn't really see how it was possible, but figured it would be worth a shot (money back guarantee and good feedback online)
I would not hesitate to purchase one again.
dragginbalz is offline   Reply With Quote
Old 02-23-2011, 06:59 AM   #37
bob_s2
Senior Member
I've pulled out the restricter plate and had good results on some. Others seem to just be low-flow and there's nothing you can do about it. We had a bad valve one time that was seriously restricting the water flow. Changed it out and everything was much better.
__________________
Owner
www.snowblowerskids.com
ARMORskids: Specifically designed for cracked uneven sidewalks, driveways, and gravel.
Garage Journal Sponsor
bob_s2 is online now   Reply With Quote
Old 02-23-2011, 07:08 AM   #38
ChristopherLutz
Senior Member
thanks to everyone for their suggestions - is the "valve" contained in the on/off mechanism? I have a single handle/lever that controls temp and on/off.
Old 02-23-2011, 11:26 AM   #39
Paco Pena
Senior Member
Paco Pena's Avatar
I use the same type as SgtRauksauff. They work great for relatively low water pressure and restrict flow to 2.5gpm as well. Because of the small size relative to the pressure it gives a good sensation of higher pressure and flow. Plus if you want to get real environmental you can turn off the water while you lather up.
Paco
__________________
You ran over WHAT ?
Paco Pena is offline   Reply With Quote
Old 02-23-2011, 01:28 PM   #40
cparsons
Junior Member
I really like the Niagara 1.50 GPM Low Flow Massage Showerhead. It's not fancy but it works great. I've head four of them and will be getting two more when I get my new house next month. And you just can't beat the $15 price from Amazon.
cparsons is offline   Reply With Quote
Old 02-23-2011, 01:51 PM   #41
ixlr8
Senior Member
I have tried several different shower heads trying to get a good flow. Turns out the valve the PO installed is a low flow valve. I really don't want to pull the wall appart to replace the valving.... but I may just have to.
I hope this isn't part of your problem.
__________________
Jim
Toys;
16 BMW X5 3.5i
15 GMC Sierra 2500
13 Kioti CK40 TLB
02 VW TDI Golf, 288,000 miles, 56 mpg
01 550
00 Toyota Solara
ixlr8 is offline   Reply With Quote
Old 02-23-2011, 03:49 PM   #42
yzair
4 port Speakman with restrictor (water saver) removed I've put hundreds in many custom homes as a General Contractor
customers love them.
yzair is offline   Reply With Quote
Old 10-16-2011, 07:21 PM   #43
uconn9
uconn9's Avatar
This is what you need. Installed one this weekend. WOW!
uconn9 is offline   Reply With Quote
Old 10-16-2011, 10:52 PM   #44
Will67
Senior Member
I replaced the hot water heater a few months ago, and after getting heater back in I had hardly any hot water flow at master bath shower. Took valve assembly apart and found flakes of rust or what looked like rust clogging hot water side of shower valve assembly.
There was also some calcium looking crud on both sides of valve assembly, removed all the crud and man what difference that made on the flow.
Will67 is offline   Reply With Quote
Old 10-17-2011, 12:25 AM   #45
4Tigers
lot of brands mentioned in this thread, which are USA made?
The last big box store I was in only had China made, I won't buy those.
4Tigers is offline   Reply With Quote
Old 10-17-2011, 01:02 AM   #46
mtnkrake
Senior Member
Quote:
I have the ultimate model. I like it alot. I took the flow restrictor out but would run out of hot water too soon. Reamed it out a little and it was just right.
mtnkrake is offline   Reply With Quote
Old 10-17-2011, 08:22 AM   #47
hobie1dog
Senior Member
hobie1dog's Avatar
Just bought the 38.00 Moen Showerhead which is about 10" diameter that Lowes had on display.....this is the 5th showerhead I've tried out, and it's a winner....best $38.00 I've spent in years.
__________________
Marty- W4SEX
Earth: The Insane Asylum of the Universe- nowhere else could things be this screwed up.
I'm talking about the kind of sound you can feel. When it comes to great stereo you can't beat big speakers, I'm talking about big speakers with big woofers.
hobie1dog is offline   Reply With Quote
Old 08-08-2015, 09:48 PM   #48
Gregory Best
Junior Member
The Commando 450:
I love that episode of Seinfeld. It was titled "The Showerhead" and is very funny. I found my own version of the Commando 450 showerhead and so far I'm quite pleased.
Gregory Best is offline   Reply With Quote
Old 08-09-2015, 08:34 AM   #49
Notgrownup
Senior Member
Notgrownup's Avatar
The Delta in2ition is the best I have owned yet. I am sure there are better but as far as rinsing shampoo, my wife says it's the best yet.
__________________
BE WHO YOUR DOG THINKS YOU ARE.
Notgrownup is offline   Reply With Quote
Old 08-09-2015, 08:45 AM   #50
indyokie
Senior Member
My opinion - for an all brass, adjustable head for huge amount of adjustment - pressure or "drench" install a Speakman S-2251.
It is no longer made in the USA, ( -the vast majority of showerheads are not )
I've worked for two manufactures of showerheads, and listened to hundreds of people and plumbers give me feedback. The head that would make the most people happy is the S-2251. Not cheap but it's very well built.
indyokie is offline   Reply With Quote
Old 08-09-2015, 11:11 AM   #51
JimbosGarage
Senior Member
I got mine at the county fair, At a booth. sometimes you find the strangest things there. It works amazing! its a rain head, Works like a fire hose.
JimbosGarage is offline   Reply With Quote
Old 08-09-2015, 04:58 PM   #52
Notgrownup
Senior Member
Notgrownup's Avatar
Damn this thread is old as methuselah...
__________________
Old 08-09-2015, 05:25 PM   #53
Jackfre
Senior Member
Yeah, 5 yr old thread. I like the Kohler Moxie!
Jackfre is offline   Reply With Quote
Old 08-09-2015, 06:15 PM   #54
reader2580
Senior Member
Over a hundred bucks and made in China? I've been known to pay up for good stuff Made in the USA, but not so much if made in China.
reader2580 is online now   Reply With Quote
Old 08-10-2015, 12:21 PM   #55
eastbaysubaru
Senior Member
Quote:
I take it you haven't used one of these showerheads then. I'm all for Made in the USA items but this showerhead is phenomenal.
-Brian
eastbaysubaru is offline   Reply With Quote
Old 08-10-2015, 03:32 PM   #56
barks
Senior Member
Quote:
-Brian
The USA has moved on to developing, designing and promoting products and the machinery used to manufacture the products. Low wage countries now do the manufacturing. The high wage work has remained in the US and is constantly expanding.
barks is offline   Reply With Quote
Old 08-10-2015, 07:11 PM   #57
LS6 Tommy
Senior Member
LS6 Tommy's Avatar
Not my cup of tea, but there's a reason the Speakman's are so widely used commercially and it's not because they're inexpensive. Good shower head.
Tommy
LS6 Tommy is offline   Reply With Quote
Old 08-10-2015, 07:31 PM   #58
reader2580
Senior Member
Quote:
If we have so many high wage jobs why is the media full of protests about low wages? Manufacturing tends to pay a somewhat decent hourly wage.
If I was to pay five to ten times the going price for a shower head then I would least expect it to be Made in the USA for that price. I certainly buy stuff made in China because sometimes I have no real choice.
Old 01-20-2017, 12:32 AM   #59
kitchenbathguides
Junior Member
My personal opinion - I recently used speakman 2251 shower head ,which have seven multifunctional flow for restricted water to anystream direction. If anybody buy with 10% discount then check out at.... http://www.kitchenbathguides.com
kitchenbathguides is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
