Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 03-02-2011, 07:07 PM   #1
wheats71
Senior Member
Default fix for dewalt 18 volt batteries
does anybody know how to ressurect 18 volt batteries that wont hold a charge or are very weak i have 4 of them that have gone south over the winter and even a pair at $126.00 is expensive.
i have found a bunch of fixes on the internet but i really dont want to send money for an unknowen fix
has anybody had any luck with these fixes or should the money be spent on batteries ?
any help would be appreciated
thanks
wheats71 is offline   Reply With Quote
Old 03-02-2011, 07:44 PM   #2
shanker
Senior Member
shanker's Avatar
Default Re: fix for dewalt 18 volt batteries
the local interstate battery rebuilds them here for 45 each and makes them more powerful &last longer than new
shanker is offline   Reply With Quote
Old 03-02-2011, 07:59 PM   #3
scott37300
Senior Member
I buy sub-c cells by the 100 and rebuild my batteries. Here is were I get mine. It comes out to 25 bucks for an 18 volt battery. You just solder the tabs together. Pretty easy to do.
Some of those "jump starting" methods work but they don't last long, not worth it from what I have read.
Forgot the link! http://cgi.ebay.com/100-NiCd-Sub-C-2...item5ad060ca21
scott37300 is offline   Reply With Quote
Old 03-02-2011, 08:00 PM   #4
OldHarley
Junior Member
OldHarley's Avatar
Probably the best way is to have them rebuilt by a rebuilder as suggested. It will take 15 of the 1.2 volt rechargables to do it, but Voltman or others can do it for about $50. if you send them your battery.
There are a lot of what I would call scams out there, including buying a DVD that tells how to 'rejuvenate' these old batteries. Usually that consists of inducing a larger charge into the batteries to fry the whiskers that these cells build up causing them to not take a charge. Most folks that have done this (I myself have not since I was forewarned) say it is only a temporary band aid fix.
As I look into my crystal ball, I predict that once these hybrid automobile batteries begin to go bad like your DeWalt units, you will find some real hybrid car deals, since those batteries will make the DeWalt look like chump change by comparison.
OldHarley is offline   Reply With Quote
Old 03-02-2011, 08:02 PM   #5
cglasgow
Senior Member
cglasgow's Avatar
There's this, but I'm not sure I'm man enough to try it....
http://www.instructables.com/id/Revi...with-a-Welder/
cglasgow is offline   Reply With Quote
Old 03-02-2011, 08:06 PM   #6
srupp
Junior Member
go to HF pick up a cheap 18v drill take the battery put in your battery pack
srupp is offline   Reply With Quote
Old 03-02-2011, 08:27 PM   #7
rwhite692
Senior Member
rwhite692's Avatar
Quote:
There is already a cottage industry of small shops that fix battery packs for hybrids. Local sales rep we deal with here (drives a lot) has an 06 Civic with 175K on it, and got two cells replaced in his for $125. That was 30K miles ago. He gets a steady 42MPG and drives it like a maniac.
__________________
My 24x36 detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=16310
rwhite692 is offline   Reply With Quote
Old 03-02-2011, 08:42 PM   #8
Red Green
Senior Member
Red Green's Avatar
I made a cord so I wasn't near the battery. It worked for a month or two then the batteries went south again.
__________________
"If the women don't find you handsome, they should at least find you handy."
"Unlike love respect can't be bought" H. Simpson
Red Green is offline   Reply With Quote
Old 03-02-2011, 09:08 PM   #9
cglasgow
Senior Member
cglasgow's Avatar
Quote:
I do like the disclaimers on that page:
"If you get killed by a poisonous explosion it means you did something wrong.
Electrocution is a real possibility also.
Ask your parents how to not electrocute yourself with a welder."
Old 03-03-2011, 05:55 AM   #10
wheats71
Senior Member
yeah the welder thing doesnt seem like its worth the 50 or 60 dollars
i know that usually if it sounds to good to be true it usually is
i haxe seen the ads for the interstate rebuilders but at 51.00$ as opposed to $62 for new ones ....
thanks for all the input
Old 03-03-2011, 07:20 AM   #11
emeraldcoupe
Senior Member
emeraldcoupe's Avatar
sent you a pm.
emeraldcoupe is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
