Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 03-14-2011, 12:02 AM   #1
drive em
Default '63-'64 Galaxie Lower Control Arm Repair:
While helping a buddy rebuild the front suspension on his '63 Galaxie, we discovered that the lower control arm bushings were completely destroyed and loose in the control arm. We figured that some new bushings would fix everything. We then discovered that the rear bushings on the lower control arms had completely worn out the bosses where they pressed into. A couple of junkyard lower control arms would fix the problem, but the only control arms we knew about were 100 miles away. Repairing the control arms we had was a better solution.
Here is one of the bushings:
The lower control arms faired no better:
I ground away the lip that formed the boss that the bushing would press into:
A new boss was made from a piece of 2 1/8" O.D. x 1/4" wall tubing. the I.D. was bored out to 1.910", which was .010" smaller that the O.D. of the bushing:
Here is the finished boss:
The boss was centered on the hole and tacked to the control arm:
While I used a TIG welder to weld the boss onto the control arm, a MIG welder would also work well:
A hydraulic press will not work to to press the bushings into the control arms. I used a piece of 3/4" Acme thread, and some pieces of heavy wall tubing to install the bushings:
One of the pieces of tubing pushes on the shell of the bushing to press the bushing into the control arm:
Here is the bushing installed:
drive em is offline   Reply With Quote
Old 03-14-2011, 12:06 AM   #2
gorilla
Senior Member
Default Re: '63-'64 Galaxie Lower Control Arm Repair:
Nice work!
gorilla is online now   Reply With Quote
Old 03-14-2011, 07:48 AM   #3
NASTYZEN
Senior Member
NASTYZEN's Avatar
Better than new.
__________________
"Engineering is the art of modelling materials we do not wholly understand, into shapes we cannot precisely analyse so as to withstand forces we cannot properly assess, in such a way that the public has no reason to suspect the extent of our ignorance."
- Dr AR Dykes
You can get your Dimple Dies here: http://www.r-fabriplus.com/
NASTYZEN is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
