Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-24-2011, 08:06 AM   #1
mad57
Senior Member
mad57's Avatar
Default .023 Flux Core Gasless Solid Welding Wire where can i find it
.023 Flux Core Gasless Solid Welding Wire any body know who still sells this wire? I cant find it any where current on the web for sale, ive found older posts but nothing for sale recent thks.
__________________
Work to live not live to work.
Iam also vice president of my car club: Wickedridesnj.com check it out!!!!
mad57 is offline   Reply With Quote
Old 03-24-2011, 08:13 AM   #2
demographic
Senior Member
Location: The Duchy of Grand Fenwick, otherwise known as Great Britain.
Default Re: .023 Flux Core Gasless Solid Welding Wire where can i find it
Am I missing something here, surely flux cored wire isn't solid cos its got the flux running down the centre of it?
demographic is offline   Reply With Quote
Old 03-24-2011, 08:17 AM   #3
z28snksknr
Senior Member
z28snksknr's Avatar
I've never seen gasless flux-core wire that's <0.030". The fact that it's center is filled with flux (flux cored) puts a minimum on the OD of the wire.
__________________
Quote:
Originally Posted by qmt2 View Post
Can I come over and lay naked in your screwdriver drawers?
My garage renovation: http://www.garagejournal.com/forum/s...ad.php?t=43030
My '54 Ford Resto:
http://www.garagejournal.com/forum/s...ad.php?t=62416
z28snksknr is offline   Reply With Quote
Old 03-24-2011, 08:20 AM   #4
Zrexxer
Senior Member
Zrexxer's Avatar
Hobart used to make a .02X flux cored wire at one time IIRC, but they don't anymore. You're not going to find any self-shielded wires smaller than .030 commonly available. And frankly, I fail to see a use for fluxcored wire that small to begin with.
__________________
I find some people work harder trying to justify doing things wrong than it would have just taken to do them right to begin with...
Zrexxer is offline   Reply With Quote
Old 03-24-2011, 10:46 AM   #5
MoonRise
Senior Member
MoonRise's Avatar
As said, 0.030 is the smallest commonly available FCAW wire. And even that is only in certain 'recipes'.
More variants/recipes are available in 0.035 FCAW wire.
And "solid" wire is NOT a "cored" wire.
What'cha trying to do anyway?
MoonRise is offline   Reply With Quote
Old 03-24-2011, 11:07 AM   #6
Falcon67
Senior Member
Falcon67's Avatar
I've only seen flux core in .030 and up. You really want .023 to use with gas and an adjustable machine, otherwise it just vaporizes.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 03-24-2011, 11:26 AM   #7
mad57
Senior Member
mad57's Avatar
Quote:
My bad i was thinking one thing and typing another
__________________
Old 03-24-2011, 11:31 AM   #8
mad57
Senior Member
mad57's Avatar
My local welding co said it did exist, but they dont carry it any more i figured i ask here theres gotta be some still floating around, my mig is an old school cheapie century no option to run gas to it and im doing some sheet metal repair on the wayfarer and thought maybe id score some for this , when I have a buddy over to help hold i just use the tig, but some things just require 1 hand i usually just point and shoot with the mig to tack in and then go over with tig or light stick. thanks anyway guys.
__________________
Old 03-24-2011, 12:07 PM   #9
z28snksknr
Senior Member
z28snksknr's Avatar
I've used a Ccentury MIG with 0.030" flux core for sheet metal. You need to be quick on the trigger and have some copper backing the tack to pull the heat out, but it works. Check my '54 resto thread in my sig line to see the results - all the welds are done on a 110V Century 80G welder using 0.030" flux core.
__________________
My '54 Ford Resto:
Old 03-24-2011, 02:31 PM   #10
MoonRise
Senior Member
MoonRise's Avatar
IMHO, just go and spring for a MIG machine and then use some 0.023/0.025 solid wire with C25. Even a 'little' 120V unit has more than enough ooomph to run 0.023/0.025 wire and C25 on sheet metal. Maybe not the duty-cycle to run it constantly (production setting or body shop), but with sheet metal it is as much of a 'dance' to keep the heat (and thus warping/distortion) down as it is to put the heat in to weld the sheetmetal together.
IMHO.
Old 03-24-2011, 03:04 PM   #11
Falcon67
Senior Member
Falcon67's Avatar
My ex Century 80 was a cutting torch with .030 flux core on sheet metal, even on low. On high, tacking 18 gauge was like welding with a .22 rifle. Another reason why I now own a Handler 140.
__________________
Chris - Merkel, TX
Old 03-24-2011, 07:52 PM   #12
mad57
Senior Member
mad57's Avatar
well i just bought the .030 today and had at it on my door, not bad couple of burn holes but i just tacked it every few inches and than went to other side not bad will look good when im done thks guys.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
