Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 03-24-2011, 04:22 PM   #1
mikeatrpi
Senior Member
Default Need Ideas for a stuck CV Axle - special removal tool?
I can't get the CV Axle out of the driver's side on my 95 mazda 626. I changed it out to a "Fenco" aftermarket one a few weeks ago, but forgot to do the seal... of course its leaking gear oil now. What I expected to be an easy job has turned into a nightmare. I cannot get this axle out of the trans-axle.
I can't get it out with a prybar. I tried to rent a slide hammer and the puller thing from Autozone but the clearance is too tight. As a last resort, I tried a pickle fork as a wedge. So far I have been unsuccessful. Short of taking the other side out and pushing through, what other ideas are there? Does anybody make a special tool that might wrap around the axle like a collar?
mikeatrpi is offline   Reply With Quote
Old 03-24-2011, 04:33 PM   #2
Mr.Nutcase
Senior Member
Mr.Nutcase's Avatar
Default Re: Need Ideas for a stuck CV Axle - special removal tool?
Use a prybar, get the car as safe as you can on jackstands.
__________________
cheap tools give me headpain and headaches...... he he
Mr.Nutcase is offline   Reply With Quote
Old 03-24-2011, 04:43 PM   #3
tw33k2514
Senior Member
tw33k2514's Avatar
Try a pry bar on each side. This will allow you to apply even pressure, and it should come out. When you only use a single pry bar the axle can sometimes bind up, and not come out. If that does not work You could try removing the other axle, and putting a pipe that is smaller in diameter that the axle stub in, and hitting it with a hammer.
They do also make a tool called the axle popper that works just like the two pry bars.
__________________
Quote:
Originally Posted by Merkava_4 View Post
I'm on a one man crusade to rid the world of holes in screwdriver handles and ratchet handles!!
tw33k2514 is offline   Reply With Quote
Old 03-24-2011, 04:48 PM   #4
Stevedore
Senior Member
Stevedore's Avatar
I did those many years ago on a Plymouth Voyager I had, and recall that popping them out was a bit of a problem. If I recall, there's a snap ring that pops into an internal groove where the axle goes in. I used a block of wood on the backside of the joint & whacked it a few times until it came out. Seemed strange, but at the time, that's what someone told me to do, & it worked.
Stevedore is offline   Reply With Quote
Old 03-24-2011, 04:51 PM   #5
scott37300
Senior Member
I have an OTC puller that has worked good for me. But I use an extension on it.
scott37300 is offline   Reply With Quote
Old 03-24-2011, 05:08 PM   #6
wheats71
Senior Member
find a friend to put some pressure on the pry bar then give the axle a good shot with whatever you need to use to hit it having pressure on it will stop any bouncing etc against the snap ring
wheats71 is offline   Reply With Quote
Old 03-24-2011, 05:13 PM   #7
caper
Senior Member
caper's Avatar
Send a message via MSN to caper
I have a tool from Mac tools that goes in the transaxle from the opposite side to pop the stubborn axle out.It was originally bought for doing Ford Tempo's and Escorts.The Drivers Side axle on those was sunk into the trans case making it almost impossible to get a prybar on them.Basically just a steel bar with a slot cut out to get around the differential pin.A piece of pipe won't work unless you notch it to clear the pin.
__________________
Quote:
Originally Posted by mrholeshot View Post
Takes about two minutes once you have the shaft in hand.
caper is offline   Reply With Quote
Old 03-24-2011, 05:18 PM   #8
zoso
Senior Member
zoso's Avatar
I'm not sure how similar the 626s are compared to millenias, but here is one solution I found on youtube awhile back that might help
http://www.youtube.com/watch?v=W_0nrnPOLcs
zoso is offline   Reply With Quote
Old 03-24-2011, 05:40 PM   #9
mikeatrpi
Senior Member
I'm amazed by how quickly this forum comes together with ideas! Thank you!
Yes, mine is an aftermarket reman unit, and apparently some of those have larger clips than the OEM ones. It was difficult to push in, but this is impossible to pull out!
I tried a puller like pictured above, but I couldn't get the clearance needed to even fit the crows-foot part.
I really, really hope I don't have to pull the other side and push the axle through!
Old 03-24-2011, 05:49 PM   #10
scott37300
Senior Member
snap on sells these, I've never seen them in person and don't know how they work but they look different than anything I have ever used.
Old 03-24-2011, 05:56 PM   #11
Lotek
Senior Member
Lotek's Avatar
Wedge your smaller prybar between the case and the axle at the front, tap it in lightly with a hammer to get it to stick in there, thenget your bigger prybar and pry at the rear, put a little pressure on it and pop the end of the prybar with a hammer, the idea is to collapse thre snapring into the groove, you have to walk the axle out slightly a little at a time.
Don't go medieval on it, I have seen gorillas crack the case.
__________________
Tim
Another example of when God turns to Darwin and says "I thought you were going to fix this s@#t".
"You keep using that word. I do not think it means what you think it means. "
"I have a hammer! I can put things together! I can knock things apart! I can alter my environment at will and make an incredible din all the while! Ah, it's great to be male!" -Calvin
Lotek is offline   Reply With Quote
Old 03-24-2011, 07:07 PM   #12
dan1120
Senior Member
dan1120's Avatar
Whatever you do, make sure the snap ring is still on the axle after you get it out. You dont want it floating around in your transaxle...
dan1120 is offline   Reply With Quote
Old 03-24-2011, 08:05 PM   #13
idoitproject
Senior Member
idoitproject's Avatar
Quote:
What's the part number?
idoitproject is offline   Reply With Quote
Old 03-24-2011, 08:37 PM   #14
swami2806
swami2806's Avatar
I know you said you swapped it out a few weeks ago, but make sure you didn't forget a step. Only giving this suggestion because when I did my wife's subaru there is a roll pin that has to be removed before the axle will come out. If I went back to it weeks later, I wouldn't look at the shop manual because I just did it a few weeks ago, and a minor step like that is something I'd forget as soon as I put away my hammer and pin punches.
swami2806 is offline   Reply With Quote
Old 03-24-2011, 08:40 PM   #15
caper
Senior Member
caper's Avatar
Same as the Mac one I've had forever.
__________________
Old 03-24-2011, 08:54 PM   #16
scott37300
Senior Member
Quote:
How exactly do they work? They look small, are they bigger than they look and do they work like a pickle fork?
Old 03-24-2011, 08:55 PM   #17
scott37300
Senior Member
Quote:
HST100-1 and HST100-2
Old 03-24-2011, 09:04 PM   #18
yogitech
Senior Member
yogitech's Avatar
You may have to use a brass punch and hammer. Tap on the end cap, should pop out. Good luck!
yogitech is offline   Reply With Quote
Old 03-24-2011, 09:32 PM   #19
Stephenw
Senior Member
Stephenw's Avatar
I have the tool shown above.
With this tool, one axle is removed and the tool is inserted in it's place. The forked portion clears the pinion shaft so you can hammer on the other axle and pop the snap ring out from the inside.
I always just use a prybar.
A prying action is not what you want, but rather a quick snap with the bar to compress the snap ring.
Stephenw is offline   Reply With Quote
Old 03-24-2011, 09:36 PM   #20
scott37300
Senior Member
Thanks for the explanation!!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
