Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-24-2011, 09:02 PM   #1
dtt454
Senior Member
dtt454's Avatar
Default how to remove stuck spark plug from aluminum head?
so, let me share my story. its a quad 4, please spare us all and lets not discuss how good/bad the engine is to start with.
anyways it was getting coolant in the engine oil, its been this way for a while, as far as i know it never hydrolocked. anyways i got the head off (the head is aluminum) i was trying to take the spark plugs out, 3 come out fine, the 4th one is stuck.. and i mean stuck good. i was trying to use a breaker bar and i stopped because, sometimes you get that feeling if you pull any harder something is going to break, ill fly backwards and land in a pile of engine parts. so i stop and think since its off anyways wouldnt it be nice to figure out a way to get it out without destroying the threads..
so for now i got the head sitting out there upside down with penetrating oil soaking it, but if anyone has any other suggestions im open to ideas.
the spark plug does not look damaged so i have reason to believe its just stuck from age/corrosion/ maybe having coolant in there, but not from mechanical damage.
my only other idea was to put the head in the oven and heat it a bit, then try to use something to cool the spark plug quickly while leaving the head warm. but before i smell up my house by sticking the head in the oven i thought id see if anyone has any other suggestions.
dtt454 is offline   Reply With Quote
Old 03-24-2011, 09:06 PM   #2
tdkkart
Senior Member
tdkkart's Avatar
Default Re: how to remove stuck spark plug from aluminum head?
BBQ grill
tdkkart is offline   Reply With Quote
Old 03-24-2011, 09:07 PM   #3
dtt454
Senior Member
dtt454's Avatar
and please dont tell me "should have used anti seize" i know this, it will get it in the future im just concerned right now about getting it out.
Old 03-24-2011, 09:08 PM   #4
dtt454
Senior Member
dtt454's Avatar
actually i never thought of the grill, i have a smoker that would work even better
Old 03-24-2011, 09:11 PM   #5
wornoutoldman
Senior Member
wornoutoldman's Avatar
After 24 hrs you may want to flip it over and soak the other side. Have an impact gun? I'd use the shortest extension possible on a 1/2 drive extension and give it a couple of short bursts. Good Luck! Let us know how it turns out.
__________________
Donor Heart Recipient 3.28.10
Eat less. Walk more. 2016
Wanna keep track of all your vehicles maintenance? Click here!
wornoutoldman is online now   Reply With Quote
Old 03-24-2011, 09:15 PM   #6
Garage5.9
Senior Member
Garage5.9's Avatar
Im surprised the cermaic part didn't brake off yet. seen that a few times and its a real PITA to remove with out taking off the head.
Garage5.9 is offline   Reply With Quote
Old 03-24-2011, 09:38 PM   #7
boogerboy72
Senior Member
1/2 inch gun, if that dosnt work, 3/4 inch, and so on. if it tears up it tears up.
boogerboy72 is offline   Reply With Quote
Old 03-24-2011, 09:46 PM   #8
Lincolncruiser95
Senior Member
Lincolncruiser95's Avatar
Try heating just the head...apply a socket to work as a heat sink of sorts and go at the head with a heat gun or propane torch set low. If that doesn't work, heat both together then get yourself some canned air. Turn the can upside-down and spray the plug from top and bottom. May take a couple cycles, but that should help break the weld created by metal to metal contact of differing materials. I've done this to many a bolt on old cars. The freezing cold propellant does wonders ;-)
Lincolncruiser95 is offline   Reply With Quote
Old 03-24-2011, 10:13 PM   #9
Senior Member
theoldwizard1's Avatar
When you get it out, if the thread need to be repaired, use a Timesert instead of a Helicoil.
theoldwizard1 is offline   Reply With Quote
Old 03-24-2011, 10:29 PM   #10
Brianw
Junior Member
Take the head to a machine shop. It might cost you $10-$20 for them to get it out but they will probably do a good job. I have worked at a machine shop for many years and have seen and fixed all kinds of stuff like this. Besides, it probably needs to be checked for cracks and then if ok milled and lapped to a smooth finish. The quad 4 cyl head requires a very smooth finish for the gasket to seal properly. You have the head off already, so why not do it right?
Brianw is offline   Reply With Quote
Old 03-24-2011, 11:52 PM   #11
srmofo
Senior Member
The good news is the head is already off, so a trip to the machine shop to fix it wont turn that job into a PITA. Other than that all the other suggestions sound good
srmofo is offline   Reply With Quote
Old 03-25-2011, 12:05 AM   #12
slopecarver
Senior Member
I was actually gonna suggest the canned air. try tightening the plug too, then remove as normal
slopecarver is offline   Reply With Quote
Old 03-25-2011, 12:18 AM   #13
stevefasano
Senior Member
removed due to
stevefasano is offline   Reply With Quote
Old 03-25-2011, 02:24 AM   #14
metalhead212121
Senior Member
Quote:
Originally Posted by stevefasano View Post
Put the head in a freezer like 2 days...then when you pull it out,heat the head with the torch for a minute or less and fast get the plug out..I did it twice and it works...third time the plug came with the aluminum threads...don't let the plug get warm..
Good luck
thats a pretty good idea... never thought of that.
metalhead212121 is offline   Reply With Quote
Old 03-25-2011, 06:31 AM   #15
REAL HOT SCHITT
Senior Member
Location: EARTH QUAKE SHAKE PROOF...NORTH OTAGO,WAITAKI DISTRICT, NEW ZEALAND
Spray kero in affected area then undo plug by gion back and forward untill undone, then tap out with vacume cleaner sucking crap out (if head still installed on motor) and insert stainless thead insert to suit....the local diesel injector pump service shop shold have rite inserts.
REAL HOT SCHITT is offline   Reply With Quote
Old 03-25-2011, 07:04 AM   #16
MoToys
Senior Member
MoToys's Avatar
Matco and lisle both make tools for this as it is a common issue with ford v8s
MoToys is offline   Reply With Quote
Old 03-25-2011, 07:26 AM   #17
z28snksknr
Senior Member
z28snksknr's Avatar
Give the plug a few solid raps with a hammer from both sides. That may jostle it free to where a breaker bar will budge it.
__________________
Quote:
Originally Posted by qmt2 View Post
Can I come over and lay naked in your screwdriver drawers?
My garage renovation: http://www.garagejournal.com/forum/s...ad.php?t=43030
My '54 Ford Resto:
http://www.garagejournal.com/forum/s...ad.php?t=62416
z28snksknr is offline   Reply With Quote
Old 03-25-2011, 09:22 AM   #18
nunan0219
Junior Member
just bring it to a machine shop since you have the head off. they'll get it out faster than you can more than likely, and if the threads are messed up they'll repair it correctly. 20$ investment would be worth the aggrivation IMO
nunan0219 is offline   Reply With Quote
Old 03-25-2011, 09:22 AM   #19
nehog
Senior Member
nehog's Avatar
X2 on the impact wrench. I find they get things out with less breakage than a breaker bar does. The short impacts allow the things to go back to a static position which lessens the long term torque on the item in question.
As mentioned, no extension or a minimal extension is best. Anything in line with the item will reduce the impact torque substantially.
__________________
My name is Peter, and I'm never going to grow up.
30 x 60, oops, 30 x 72 (it got larger!) with a Rotary 10K lift.
AM General H1 NA Wagon (95 For Sale)
AM General H1 Turbo Wagon (99)
Volvo S80
Mercedes Benz Sprinter RV
Saab Turbo Convertible
VW Cabriolet
nehog is offline   Reply With Quote
Old 03-25-2011, 09:34 AM   #20
1320stang
Senior Member
1320stang's Avatar
Tighten before loosening.
__________________
_________________________________________________
Larry Hampton
1963 Fairlane 2 door post
1965 Mustang Coupe
1973 F-100 longbed
2002 Pontiac Grand Prix
2003 Explorer SportTrac
2005 Honda Accord
2008 Mercury Mountaineer
2015 F-150 Screw 5.0 2wd
Quote:
Originally Posted by raccoon View Post
PS: I'm a girl..
1320stang is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
