Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-26-2011, 09:39 PM   #1
Printer Mike
Senior Member
Printer Mike's Avatar
Default DIY elevator...
Anyone ever made one or have any info.? I only need to lift one person about 8 feet. Slow is OK. Quiet would be nice...
Printer Mike is offline   Reply With Quote
Old 03-26-2011, 10:39 PM   #2
Torque1st
Senior Member
Torque1st's Avatar
Default Re: DIY elevator...
There are several systems for home use available. Some are DIY installs if I remember right. Elevators get into all kinds of safety, inspection, and code issues. Many engineers and fabricators could make one but liability comes to mind.
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 03-27-2011, 09:37 AM   #3
larry_g
Senior Member
Cousins used to have an elevator in the barn that was a man cage with a rope up and over a pulley and down to a box of rocks for a counter balance. There was a second rope that was tied to the roof and floor that was used to pull yourself up or down depending on your weight and the amount of rocks in the counterbalance box. There was also a foot brake that pinched the pull rope to control speed if necesssary.
lg
no neat sig line
__________________
My Shop build thread
Great minds talk about ideas, average minds talk about events, small minds talk about people.
Wise people talk because they have something to say. Fools talk because they have to say something.
larry_g is offline   Reply With Quote
Old 03-27-2011, 09:48 AM   #4
bgoodwin
bgoodwin's Avatar
Years ago I worked in a shop that had an elevator made from modifying a garage door opener. It was used as a dumb waiter type thing to raise and lower parts from the storage room upstairs. Worked very well as I remember and had no problem lifting a couple hundred pounds.
__________________
All I can do is explain it to you, I can't understand it for you.
bgoodwin is offline   Reply With Quote
Old 03-27-2011, 10:01 AM   #5
toolman1967
Senior Member
toolman1967's Avatar
I made an elevator to bring boxes up to the attic of the new garage, I'll try to go out and get a couple of pics.
Basically it is two pieces of unistrut bolted to the wall with a set if rolling hangers attached to a platform. The motor is a 110 winch sold as a 220/440 pound pull electric winch for lifting deer and the like. A couple of pulleys to multiply the force and direct the cable and call it done!
Works great and saves the back and cussing!
toolman1967 is offline   Reply With Quote
Old 03-27-2011, 10:36 AM   #6
phy6
Senior Member
phy6's Avatar
If you ever go to apply for a permit for this, never use the word elevator, use the phrase "Reciprocating Conveyor". This avoids lots of unnecessary red tape. Also, some metal shops/etc won't touch your project if you say it's an elevator. I was considering putting one in along with a mezzanine level in my garage, so I did a bit of research. Current plan is to use the 4 post lift I got along with a wood platform to allow access to the upper storage.
phy6 is online now   Reply With Quote
Old 03-27-2011, 10:51 AM   #7
Printer Mike
Senior Member
Yes.. That's what I meant.
Thanks!
Old 03-27-2011, 11:32 AM   #8
Zeke
Senior Member
Zeke's Avatar
Location: Senior Member—in more ways than one in Long Beach CA
I did the winch thing. Works great.
Zeke is offline   Reply With Quote
Old 03-27-2011, 11:46 AM   #9
Jack Olsen
Jack Olsen's Avatar
Can you give us more details on how and where it will be used? Is this to get yourself up to the attic, or is it for a relative with a wheelchair, or what?
Jack Olsen is offline   Reply With Quote
Old 03-27-2011, 12:00 PM   #10
KrisKustomPaint
if its to be used for people, I would build a braking system similar to what is used in regular elevators. Basically the lift cable is hooked to a spring loaded brake, that stays retracted as long as the cable is connected. The weight of the elevator keeps the brakes from stopping the car. if the cable snaps the brakes flip out and lock the car to the guide track. Clear as mud.
KrisKustomPaint is offline   Reply With Quote
Old 03-27-2011, 12:03 PM   #11
35mastr
Senior Member
35mastr's Avatar
How about a single post in ground lift? Just build your platform or box.
__________________
If I could only remember what I have already forgotton.
Mac tools For Sale Here
George
35mastr is offline   Reply With Quote
Old 03-27-2011, 02:36 PM   #12
nehog
Senior Member
nehog's Avatar
If used for people, you better get it done professionally, because if anything goes wrong and someone's hurt, you'll sure wish you had...
For a dumb waiter you need a way to prevent people from falling into the hole/shaft (someone was killed recently when this happened in a restaurant.) along with other safety considerations.
I know a guy who does these for a living and he'd probably advise you to 'forget it', unless you have a serious budget. (and you won't get approval from the state for a home-made people lift.)
__________________
My name is Peter, and I'm never going to grow up.
30 x 60, oops, 30 x 72 (it got larger!) with a Rotary 10K lift.
Volvo S80
Holiday Rambler Ambassador 40 DFD
Mercedes Benz Sprinter RV
Saab Turbo Convertible
VW Cabriolet
nehog is offline   Reply With Quote
Old 03-27-2011, 03:58 PM   #13
toolman1967
Senior Member
Winch works great for me and moving stuff. If I were to think about making a people mover, I would use a screw so if the motor craps on you or you break a cable the platform would not fall.
Old 03-28-2011, 08:25 AM   #14
tkiranch
If it is to be a people mover, look into the lifts for wheelchairs. I have put a few in, as a Rehab Tech, and they were pretty simple. They may run a couple of thou, but as a people mover, they are really good. They can also run off their battery when the power goes out. Or you can just use an old forklift front, mount the lift and hook up a hydrolic pump to an electric motor. You can buy them for the back of a farm tractor at auctions all the time.
tkiranch is offline   Reply With Quote
Old 03-28-2011, 08:28 AM   #15
henrysgarage
Senior Member
henrysgarage's Avatar
One fellow I know used a fork lift ram to build a lift.
__________________
57 wagon 408"BB with 14' Bonair travel trailer,71 Nova 355"SB, 07 2500HD with 26.5 Prowler 5th wheel travel trailer, 09 Impala LT, John Deere lawn tractor, CDN coordinator for ChevyTalk.org,
http://www.picturetrail.com/gallery/...wagon&x=14&y=6
henrysgarage is offline   Reply With Quote
Old 03-28-2011, 10:58 AM   #16
Capt Chrysler
Senior Member
A friend of mine took a mast of a fork lift. Then build it into the wall. Works very well.
Capt. Chrysler
Capt Chrysler is offline   Reply With Quote
Old 03-28-2011, 11:31 AM   #17
toolman1967
Senior Member
This is the pics of mine, Like I posted earlier, this could easily be adapted to use a screw drive instead of the cable that I am using.Garage pic 012.jpg
Old 03-28-2011, 12:22 PM   #18
Jack Olsen
Jack Olsen's Avatar
This might give you some ideas, too. (But you'd need something different for eight feet.)
Old 03-28-2011, 01:31 PM   #19
MoonRise
Senior Member
MoonRise's Avatar
OK, one person and ~8 ft of lift (one story approximately).
But what, where, and why?
In the (personal) shop to get up to the mezzanine? Just get a scissor-lift aka man-lift.
In the house for someone in a walker/wheelchair to get to the second floor? Go and buy one.
Anything industrial/commercial situation? Go and buy one.
The liability and permits and inspections and certifications pretty much prevent you from any DIY on this one.
Sorry.
MoonRise is offline   Reply With Quote
Old 03-28-2011, 01:50 PM   #20
1899
Junior Member
I really like this idea because id like to be able to store supplies above the ceiling in my garage. I think building a shaft out of 2x4 and a simple winch on the car would do it.
1899 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
