Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 03-27-2011, 02:46 PM   #1
Morpheus77
Junior Member
Default Craftsman air compressor not building pressure.
Hello folks. I have a 1.75 HP, 125 psi 7 gallon craftsman air compressor that is not running right. It will not get past 50 psi, and it will not turn off. It gets really hot, and after a few min, it'll start smelling funny. Almost like something is burning. The fan runs fine, I've drained the water out of it. The cylinder head gets really hot, and the oil level is normal. What should I do? Thanks in advance.
T.
Morpheus77 is offline   Reply With Quote
Old 03-27-2011, 03:16 PM   #2
fordbroncodave
Senior Member
fordbroncodave's Avatar
Default Re: Craftsman air compressor not building pressure.
it needs new piston rings or reeds in the pump head. if it doesn't compress air and build it, its leaking back into the pump unless there is a significant exterior leak of the compressor tank or fittings.
if its the oil less design throw it away and get a new one
__________________
with a putt putt here, a putt putt there, hear a putt theres a putt, everywheres a putt putt... a john deere farms this land E I E I OH
my needs list:
http://garagejournal.com/forum/showt...fordbroncodave
fordbroncodave is offline   Reply With Quote
Old 03-27-2011, 03:17 PM   #3
YellowLakeWelding
Senior Member
YellowLakeWelding's Avatar
Bad regulator possibly or bad check valve? Take out the check valve and see if you can move the valve. There's either a bypass in the head valve also or the regulator is just faulty.
YellowLakeWelding is offline   Reply With Quote
Old 03-27-2011, 03:17 PM   #4
99_xc600
Senior Member
99_xc600's Avatar
Sound'e like either the ring's are shot or one of the valves are broken.
If you put you hand over the muffler, can you feel suction or do you feel air coming back out?
If you feel air coming out, chances are one of the valves is broken and is allowing the air to be pushed back out of the intake.
99_xc600 is offline   Reply With Quote
Old 03-27-2011, 03:19 PM   #5
YellowLakeWelding
Senior Member
Quote:
I agree...
How old is this compressor? Many hours on it? Could very well be the rings like fordbroncodave said.
Old 03-27-2011, 03:23 PM   #6
mrchuck
Head Gasket is blown. I had this exact one, only pumped a little, gave it to a friend and he took off the head and made a new gasket out of some material, installed it and it works perfectly for him. This was 3 years ago, and it's still working fine for him.
mrchuck is offline   Reply With Quote
Old 03-27-2011, 04:47 PM   #7
Morpheus77
Junior Member
Wow! Thanks for the quick responses. Looks like I have several things to check out then. Not sure how old the unit is, bought it from my best friend after he upgraded to a bigger one. Next time I talk to him, I'll ask. I went back out and looked for a muffler, I don't see one, sorry. However, it's sucking through the intake pretty good, no air coming out of the intake.
T.
Old 03-27-2011, 07:17 PM   #8
fordbroncodave
Senior Member
when it gets to 50psi, unplug it and listen for any leaks.
i am still willing to bet it needs reeds in the pump head or rings.
i had a cman professional 6.5hp 60 gallon oil less compressor and it needed new piston kits every 2 months (it intentionally self destructed and should have been recalled)
__________________
my needs list:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
