Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-31-2011, 09:16 PM   #1
rmuell01
rmuell01's Avatar
Default combine hot and cold water taps into a single hose
I have hot and cold taps in my garage that I would like to run a single hose to mix the temp. I've tried the easy way, by putting in a 3-1 hose splice. that failed pretty bad as the water sprayed everywhere. In fact, I never use these faucets because they've always sprayed water. (house is only 10 years old, which I had built)
any ideas? I'd appreciate it.
Rob
rmuell01 is offline   Reply With Quote
Old 03-31-2011, 09:28 PM   #2
index
Default Re: combine hot and cold water taps into a single hose
to clarify, you just want to have luke-warm water all the time out of a single faucet?
you could try a TMV (Thermostatic Mixing Valve)
http://en.wikipedia.org/wiki/Thermostatic_mixing_valve
index is offline   Reply With Quote
Old 03-31-2011, 09:32 PM   #3
Frank The Plumber
Senior Member
Frank The Plumber's Avatar
If you could post a pic that would help a lot and a brief description of what you may want and how you might find it acceptable to look.
__________________
Visit My angelfish room at
http://www.facebook.com/pages/Indian...64072983609849
Frank The Plumber is offline   Reply With Quote
Old 03-31-2011, 09:49 PM   #4
mrb
Senior Member
mrb's Avatar
my suggestion is to fix whatever is causing them to spray water everywhere. where is the water spraying from? you are using washers in the hose fittings right?
if budget is no object, chicago faucet has some nice offerings
mrb is offline   Reply With Quote
Old 03-31-2011, 09:52 PM   #5
josall
Is this what you are needing. What kind of tap is it? where is the water spraying from?
http://www.acehardware.com/product/i...631244.2632011
josall is offline   Reply With Quote
Old 03-31-2011, 10:01 PM   #6
Norcal
Senior Member
Don't leave the water on when not in use/ unneeded, it can play havov w/ water temps. (Not to mention risk of a burst hose).
Norcal is online now   Reply With Quote
Old 03-31-2011, 10:01 PM   #7
Torque1st
Senior Member
Torque1st's Avatar
I just use the Y-hose pictured above for my slop sink. -No problems...
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 03-31-2011, 10:30 PM   #8
rmuell01
rmuell01's Avatar
This site has the fastest responses known to man. I'll get pics tomorrow.
Rob
Old 03-31-2011, 10:44 PM   #9
Wackerjr
Senior Member
my garage has something like this.... only the taps are on the sides and the hose out the center but you get the idea....
Wackerjr is offline   Reply With Quote
Old 03-31-2011, 10:46 PM   #10
Vicegrip
Senior Member
Vicegrip's Avatar
Thats a good looking setup^
Just be careful not get cross flow when using a y hose setup.. the hot water might be slightly higher or lower pressure then the cold and water will flow from one to the other. flush a toilet and get a slug of hot going into the cold side. Hot shower and after a while the hot side can get flooded with cold. If water is flowing out of the hose then cross flow is not a concern leaving both hot and cold valves open and connected with no flow through the hose can open up potential issues.
__________________
A wise man knows his ignorance. A fool thinks he knows everything.
Vicegrip is offline   Reply With Quote
Old 03-31-2011, 10:52 PM   #11
mhm993
Senior Member
mhm993's Avatar
that's a sweet hose bib, and a great solution. Is it non-freeze style?
__________________
Marc
PCA national instructor
SCCA crew
Satanic Mechanic
mhm993 is offline   Reply With Quote
Old 03-31-2011, 11:28 PM   #12
willysrule
Senior Member
willysrule's Avatar
I still have this little sketch from the one at my friends shop...1/2" copper, sweat fittings, and use the ball valves to regulate temperature...
willysrule is offline   Reply With Quote
Old 03-31-2011, 11:36 PM   #13
Torque1st
Senior Member
Torque1st's Avatar
That cross flow situation can occur with most any faucet or shower in the house that mix hot/cold internally. It does not seem to be a problem normally.
__________________
The FairTax
Old 04-01-2011, 01:27 AM   #14
TurnipTruck
Senior Member
I have long pondered installing a tempered spigot for washing cars. Rather than buying a dedicated freeze-prone mixing valve, I was going to have a frost-free spigot downstream of a toilet mixing valve. It's got the built-in checkvalves, and it's designed for this application. I just don't know if it will flow enough and haven't gotten around to testing one.
TurnipTruck is offline   Reply With Quote
Old 04-01-2011, 01:29 AM   #15
MattSteele
Junior Member
What's the worst that could happen with crossflow? why is it so bad?
MattSteele is offline   Reply With Quote
Old 04-01-2011, 05:02 AM   #16
kartracer23
Senior Member
kartracer23's Avatar
Last summer I had a Moen hot / cold valve installed next to my driveway for washing cars. Just ran pex to it from the lines in the basement. Works just like a shower value - all hot, all cold, or anything in between. It was like $60. It's also frost free.
Ran the cold from a softened line, too so it's 100% soft water - much better for washing cars here in limestone land. And it's really nice to have hot water outside to wash stuff with (cars, lawn furniture, etc.). Hot water really helps loosen dirt.
kartracer23 is offline   Reply With Quote
Old 04-01-2011, 10:25 AM   #17
Lippyp
Senior Member
Lippyp's Avatar
By law here any external tap (faucet) has to have an anti-syphon valve either built into the tap fitting or installed inline with it to prevent wtaer syphoning back if you say leave the hose in a bucket and the pressure drops. Just install one in each line to prevent wtare flowing backwards between hot and cold.
Lippyp is offline   Reply With Quote
Old 04-01-2011, 11:22 AM   #18
ZeroSignal
Senior Member
ZeroSignal's Avatar
Google a search for Thermostatic Hot and cold mixing valves...
ZeroSignal is offline   Reply With Quote
Old 04-01-2011, 11:30 AM   #19
nutjob
Senior Member
Here's what you need. Made in the USA
https://www.buyeagle.biz/page.asp?id...52&prodid=6128
Here is the mfg:
http://www.woodfordmfg.com/woodford/WFDIndex.html
Kevin
nutjob is offline   Reply With Quote
Old 04-01-2011, 11:59 AM   #20
rmuell01
rmuell01's Avatar
I've added a photo in the first post. full speed ahead.
Rob
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
