Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 04-05-2011, 06:58 AM   #1
bw77
Senior Member
bw77's Avatar
Default Rotate tires without balance?
I have always believed that tires should be rotated and balanced every 5K miles or so.
But I find that when I go to Sears auto for that service (which is included in the price of the set of tires I bought there), sometimes someone tries to convince me that I just need the tires rotated without a balance, unless I can feel the out of balance when driving.
I have to stand my ground and insist on the balance.
Other times, it's no questions asked. Depends on who I speak with.
I suppose they are just trying to increase profits a little by saving time on the balance.
Thoughts?
bw77 is offline   Reply With Quote
Old 04-05-2011, 07:17 AM   #2
J Persons
Senior Member
Default Re: Rotate tires without balance?
Most times, tires are balanced off the vehicle so it doesn't make much difference as to where the tire is located. I've also had tires balanced on the vehicle and had poor results, especially at the rear axle. As tires wear, they can change the balance slightly and may have to be rebalanced.
J Persons is offline   Reply With Quote
Old 04-05-2011, 07:40 AM   #3
May Pop
Senior Member
Rotate no rebalance. Unless you pay for rebalance. Unless you are extra perticular just a waste of money.
May Pop is offline   Reply With Quote
Old 04-05-2011, 07:40 AM   #4
MrSnicks
Senior Member
MrSnicks's Avatar
I always get my wheels rebalanced when I have them rotated.
Patrick
MrSnicks is offline   Reply With Quote
Old 04-05-2011, 07:43 AM   #5
scottytohottyman
Junior Member
scottytohottyman's Avatar
Balancing is not necasary when rotating tires. However if a tire in the rear is out of balance you will not always feel it, that is untill it is rotated to the front. Then you have to go back to the shop & have them balanced. So it can be a time saver for both you & the shop to just balance the tires while the wheels are already off the vehicle. I own a tire store and once in a while we will have a car come back that has developed a vibration after the rotate. Then we end up balancing the tires and taking twice as much time for us & the customer. Long story short, you are not out of line by requesting balance and rotation.
scottytohottyman is offline   Reply With Quote
Old 04-05-2011, 07:44 AM   #6
Fedwrench
Alliance Member
Fedwrench's Avatar
I'm sure the working techs appreciate you wanting to balance the tires with each rotation. Unless you're experiencing some shimmy or vibration, or lost a weight there's no need to but, that's just me.
__________________
It's not the tools in the toolbox, it's the mechanic who knows how to use them that matters.
KEEP CALM AND RETURN FIRE!!
Fedwrench is offline   Reply With Quote
Old 04-05-2011, 07:44 AM   #7
LocoCoco
Senior Member
LocoCoco's Avatar
Huh?
You get your wheels balanced every 5000 km? What's the point? Once they're balanced, they're balanced.
Tire shop must love ya though!
LC.
__________________
26' x 26' and shrinking...
LocoCoco is offline   Reply With Quote
Old 04-05-2011, 07:55 AM   #8
DrunkSmurf
Senior Member
DrunkSmurf's Avatar
I always just rotate mine at home and never bother having them balanced unless there's an obvious need to.
If it isn't broke, don't try fixing it.
I do agree with scottytohottyman on the point that sometimes a tire that seemed fine on the rear can give you some issues once put on the front.
It's only happened to me once that I can think of though.
DrunkSmurf is offline   Reply With Quote
Old 04-05-2011, 07:56 AM   #9
neonnblack
Senior Member
neonnblack's Avatar
I have mine balanced every 3k or so, Im a very aggressive driver. My balances and rotations are free, whenever i want them from Discount Tire.
neonnblack is offline   Reply With Quote
Old 04-05-2011, 08:21 AM   #10
nutjob
Senior Member
Purchased the set of tires on the Durango from Costco. Free rotate and balance for life of the tire.
I stop in about every 10k. I see new weights and they are in different postions.
I would not pay for this service, since I can do the rotate myself and only get a balance if I felt a vibration.
By the way, Costco has done the best tire service I have ever seen. They wire brush the hub to remove rust, they use a torque wrench on the lug nuts and they really seem to care.
Kevin
nutjob is offline   Reply With Quote
Old 04-05-2011, 08:41 AM   #11
GirlnAgarage
Senior Member
GirlnAgarage's Avatar
Discount Tire Co customer here too.
I have my tires rotated and balanced every 5k. By the end of the tire life I should have all the shimmies and vibes worked out.
__________________
Previous garage; all pics removed
My Garage: Reorganization, it's like a renovation
GirlnAgarage is offline   Reply With Quote
Old 04-05-2011, 08:46 AM   #12
Lotek
Senior Member
Lotek's Avatar
If the O/P was paying for the balance each time, I would have it checked at 15k, but since the balance and rotate was included in the price of the tires, I'm with the O/P, insist on the service that was promised when the tires were purchased
To those who think balancing is a one time thing, tires do wear unevenly, weights fall off or get knocked out of position, tread separation happens, if the tire is on the balancing machine, damage and defects are easier to see, so if the shop recommends a balance, don't assume they are trying to rip you off.
__________________
Tim
Another example of when God turns to Darwin and says "I thought you were going to fix this s@#t".
"You keep using that word. I do not think it means what you think it means. "
"I have a hammer! I can put things together! I can knock things apart! I can alter my environment at will and make an incredible din all the while! Ah, it's great to be male!" -Calvin
Lotek is offline   Reply With Quote
Old 04-05-2011, 08:52 AM   #13
tw33k2514
Senior Member
tw33k2514's Avatar
Kinda pointless, but if it's free, why the hell not.
__________________
Quote:
Originally Posted by Merkava_4 View Post
I'm on a one man crusade to rid the world of holes in screwdriver handles and ratchet handles!!
tw33k2514 is offline   Reply With Quote
Old 04-05-2011, 09:05 AM   #14
J Persons
Senior Member
Default Discount Tire
Won't ever buy from them again. Several years ago I special ordered a set of Dunlop D40M2 tires and paid for them in advance, was told they would be in within two weeks. Took the car down to have them installed, and they had switched tires the to their own brand, which were considerably cheaper than the Dunlops. When I complained and told them to reinstall my original tires they charged me a mounting fee. I did eventually get the tires I ordered and paid for, but not before loudly complaining. A letter to their corporate office was answered with "Sorry 'bout that". I use "The Tire Rack" now for all my tires.
Old 04-05-2011, 09:13 AM   #15
GirlnAgarage
Senior Member
Default Re: Discount Tire
Quote:
Sounds like a poorly run shop. Having used Discount since the late 90s and all over the state at that, I've definitely found a difference in stores. While they all adhere to the same rules, some shops have a better vibe.
I have two shops within 3-4mls of me. I've intentionally used both to try to do the same things with my wheels and tires. The shop I originally went to after moving into the area doesn't get my business anymore.
It's a shame they treated you wrong.
__________________
Old 04-05-2011, 09:43 AM   #16
porphyre
Thoughts?
My thought is you're in the 50+ bracket and had a lot of formative experience in the 60's and 70's.
I just had this conversation with my father. We were talking about how tires used to only last 30-40k miles and blow-outs were common. I was mentioning that my lifetime drive clock was around 500k miles at that point and I'd never had a blow-out.
Anyway, he said they used to always balance tires on the car and they'd balance after a rotate too. It seems that, back in the day, manufacturing tolerances weren't very tight. If you balanced the tire on the car, you were (in effect) balancing the entire rotating assembly - brakes, hubs, etc. It gave a smoother ride because, while a tire balanced off the car could be fine, the rotor or hub, etc, could be off.
On modern cars, tolerances are good enough that on-car balancing is not needed.
So, point being. Balance after every rotate? No need. Balance after 15-20k miles and/or you're feeling a vibe (uneven tire wear, lost wheel weight, etc)? Yes.
But yeah, if it's one of those "free lifetime rotate, balances".... no reason not to do it.
porphyre is offline   Reply With Quote
Old 04-05-2011, 02:24 PM   #17
bw77
Senior Member
bw77's Avatar
Quote:
Yup, for the past 10 years.
Thanks to everyone for your ideas.
Old 04-05-2011, 02:32 PM   #18
Rickstir
Senior Member
Rickstir's Avatar
Location: Close by the Elk Fork of the Salt River, in MO
Rotate and balance every other oil change on my new Subaru. Course I go off road a lot. Back when I had money to burn I had a Ram 1500 Quad 4 X 4. Lots more off roading on it. Got those tires rotated and balanced every 5 to 7 thousand. Always got excellent tire life.
__________________
Labor: $10.00 per hour; $15.00 per hour if you watch, $35.00 per hour if you help.
Rickstir is offline   Reply With Quote
Old 04-05-2011, 03:52 PM   #19
metal1313
Senior Member
metal1313's Avatar
i have mine balanced pretty often, more often than most, but thats only becuase my mech. lets me change my fluids and rotate my tires in his shop while i help him work on his, or his helpers projects. i gotta find him a tire mounting machine tho, since his is an oldd coats machine and wont mount tires to 17's or larger wheels
metal1313 is offline   Reply With Quote
Old 04-05-2011, 03:58 PM   #20
NUTTSGT
NUTTSGT's Avatar
I rotate mine every other oil change, 8K miles. I have never had a tire rebalanced after it was put on, I guess I never thought of it.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
