Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 04-08-2011, 09:10 AM   #1
StatGSR
Junior Member
StatGSR's Avatar
Default OSB for walls and ceiling - What thickness?
Hey guys,
looking to start insulating the walls and ceiling of my 28x36x12 garage and then covering the with OSB. I just can't decide what thickness i should use on the walls or ceiling.
Any recommendations? Any reason i should use more then 7/16th?
by the way, I'm only looking for a functional workspace with my garage, it will never be a pretty shop.
Thanks!
__________________
My Garage -> http://www.garagejournal.com/forum/s...ad.php?t=97778
My Toys - 94 Integra GSR, 97 Legacy Brighton (EG33 swap in progress), 03 Silverado 2500HD Duramax
StatGSR is offline   Reply With Quote
Old 04-08-2011, 09:20 AM   #2
Hud
Default Re: OSB for walls and ceiling - What thickness?
Used 7/16th on walls and ceiling of mine and it looks good.
Hud is offline   Reply With Quote
Old 04-08-2011, 09:24 AM   #3
pattenp
Senior Member
pattenp's Avatar
+1, use 7/16. Thinner stuff too wavy, thicker stuff is too heavy to work with.
pattenp is online now   Reply With Quote
Old 04-08-2011, 09:24 AM   #4
Milton Shaw
Senior Member
If you do any welding you might want to consider that OSB is very easily ignited from sparks. Most codes require drywall on ceiling instead of OSB for that reason. On walls I have seen some of the members cover OSb with metal because of that. Check some other posts and you will see this.
Milton Shaw is offline   Reply With Quote
Old 04-08-2011, 09:41 AM   #5
Gary S
Senior Member
I used 7/16" on my roof and outer walls. Later when I finished the inside, 1/2" was on sale cheaper than the thinner 7/16", so I ended up with the 1/2" on the inside.
Gary S is offline   Reply With Quote
Old 04-08-2011, 10:39 AM   #6
digdug18
Senior Member
digdug18's Avatar
Location: Williamsport, Pa(school), Ottsville, PA(Home)
I second drywall. Or get a really good insurance policy.
digdug18 is offline   Reply With Quote
Old 04-08-2011, 11:45 AM   #7
58Yeoman
Senior Member
58Yeoman's Avatar
I used 7/16 for walls and ceiling, as I got it all free. Mine, too, is a shop, not a man-cave. It can be a pain to paint, though.
58Yeoman is offline   Reply With Quote
Old 04-08-2011, 11:50 AM   #8
milner351
Senior Member
if you plan on doing a lot of welding / grinding - or - you're not a fan of painting or working with heavy sheets - look into corrugated white steel panels - seconds and over runs can be had from wholesalers at prices that make you think twice about all the extra work of drywall or painted osb.
If you go with osb - buy enough corrugated to do your metal working corner for safety's sake.
milner351 is offline   Reply With Quote
Old 04-08-2011, 12:29 PM   #9
StatGSR
Junior Member
StatGSR's Avatar
Thanks for the input guys. I'll go with 7/16". was going to pre-paint with Kilz primer before hanging just to lighten up the space
I won't be doing a lot of welding or grinding so I'm not too worried about fire, but will obviously take precautions when I am. I think there is some large sheets of corrugated steel left over from my poll barn that i can set up when needed.
Thought about the metal for the walls but discarded the idea as i will have a 4ft deep shelf running around half of my garage at about 8ft up. (similar to the one that exists now if you take a look at the thread in my signature) and i think putting that back up with steel on the walls would be a major pain.
Thanks guys!
__________________
Old 04-09-2011, 11:00 AM   #10
Berserker
I too did 7/16 on walls. Getting ready for ceiling today. Was thinking 1/2. I have heard don't want to 3/8 to wavy. Curious about 71/6 if its cheaper.
Berserker is offline   Reply With Quote
Old 04-09-2011, 02:02 PM   #11
zeebad1
Senior Member
zeebad1's Avatar
I used 1/2" on mine. Within a few cents of 7/16" at the time.
Painted it with KILZ & Sherwin Williams ProMar 200. Sprayed on with an airless sprayer, and back-rolled for consistency.
I do cut, grind. and weld, and haven't burned it down yet.
zeebad1 is offline   Reply With Quote
Old 04-09-2011, 02:14 PM   #12
Berserker
Will you tell us if you do?
Old 04-09-2011, 03:39 PM   #13
ddawg16
Senior Member
ddawg16's Avatar
Do any of the walls share a wall with the house? If so, it has to be drywall.
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 04-09-2011, 04:44 PM   #14
Berserker
It is supposed to be code. Not a bad code. Not sure if I am going to worry about it or no. Though if the rest of the garage is roaring its going to jump into the attic pretty quick. Its probably the ceiling you need to worry about.
I just picked up 13 sheets of 1/2 plywood today. Going to put a light stain on it and poly.
Old 04-09-2011, 09:21 PM   #15
NUTTSGT
NUTTSGT's Avatar
I have 7/16" on my walls and ceiling too. I'd wait to put it up to paint it. You wont have a buch of "wet" sheets laying around. You can chaulk the seams (if you have any gaps) and paint over them.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
