Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 06-19-2005, 11:28 PM   #1
cork
Default ceiling options
Looking to enclose the now open ceiling on my newly constructed garage. I was thinking either drywall or tin. Anyone have other suggestions. It needs to support insulation, and i will be covering a 32x42 area.
cork is offline   Reply With Quote
Old 06-19-2005, 11:47 PM   #2
bmwpower
bmwpower's Avatar
Send a message via AIM to bmwpower Send a message via Yahoo to bmwpower
Default
Not sure on the price of "tin", but drywall is probably the way to go overall. Gives you a nice finished look and helps provide rigidity to the ceiling.
bmwpower is offline   Reply With Quote
Old 06-20-2005, 12:06 AM   #3
OH-MAN
Senior Member
Default
Drywall probablly gives a better fire rating and insulation.
OH-MAN is offline   Reply With Quote
Old 06-20-2005, 11:26 AM   #4
SteveL
Senior Member
SteveL's Avatar
Default
You need to check local building codes for your area. Mine required 5/8" fire rated drywall on all garage ceilings and any wall that was up against the house. They also required a fire wall above the ceiling to separate the garage attic from the house!!! In theory, this would help slow a fire down that started in the garage.
We had a house go up in flames in our neighborhood that started in the garage from a gas leak in the car. Person came home and parked the car in the garage and went inside the house and closed the garage door. Within an hour the house was engulfed and he almost did not get out!! Elderly guy and the fire went up in to the attic space first and spread to the house attic and then back down to the living area. A person driving down the street noticed the flames coming out of the roof before the owner knew anything! This house was built before the attic fire wall codes were changed so I can see the benifits of the new codes.
Always better safe than sorry!
SteveL is offline   Reply With Quote
Old 06-20-2005, 12:09 PM   #5
plw
Certified Garage Junkie
Default
I had a friend who did his with surplused metal roofing. He had to use several different colors but he spray painted the whole ceiling gloss white and it really looks sharp. Good light too.
plw is offline   Reply With Quote
Old 06-20-2005, 12:54 PM   #6
Wile1Coyote
Senior Member
Wile1Coyote's Avatar
Default
I agree that the space between the house and garage both in the attic and below it needs to be walled off with 5/8 drywall, however there is no reason your garage ceiling needs to have a fire barrier from the rest of the garage.
For something different and as long as you are not storibng stuff above the garage. Place chicken wire or something similar on top of the joists in the attic space and roll out attic insulation blankets over it. Then for a ceiling use Vinyl Siding Soffit material. Choose a white color and you are all set, no need to paint ever and plenty of reflectivity for the light. Stagger the length of the pieces so you don't end up with one big seam OR use J channel to hide the edges with a uniform seam.
Wile1Coyote is offline   Reply With Quote
Old 06-20-2005, 01:45 PM   #7
bmwpower
bmwpower's Avatar
Default
Another reason for drywall would be soundproofing. Keep your neighbors a little more happy.
Old 06-20-2005, 02:10 PM   #8
cork
Default
Thanks for the replies so far, i like the soffit idea. This is a detached garage and there are no code requirements in my area for a detached garage. I like drywall but i hate to finish the seams.
Old 06-20-2005, 09:54 PM   #9
bdaz442
Default
I'm going with the tin. cost a little more but my joist are on 5 foot centers. i would have to strip the joist to use dry wall. i can use ten foot pieces of tin and not have to strip or finish. i will post pics a soon as I get done.
bdaz442 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ceiling decision time SprintCC General Garage Discussion 5 08-13-2008 08:38 PM
Drop Ceiling in Metal Building? poci1957 General Garage Discussion 7 01-23-2008 12:16 AM
Any tips on securing 8' fixtures to the ceiling alpo General Garage Discussion 9 03-25-2006 07:25 AM
Moving ceiling outlet rockford33 General Garage Discussion 21 03-14-2006 02:27 PM
options for concrete block walls?? slapshot General Garage Discussion 23 08-09-2005 03:01 PM
