Toolbox Widget
I got an email inquiring about advertising the other day from the makers of something called the Toolbox widget. Ever appreciative of the support, I decided to feature their product today. I haven’t gotten my hands on a set of these things yet, but they actually look pretty damned smart.
Essentially, they are modular organizers for your wrenches. A magnet holds them tight to your box drawers and clips hold them together as a unit or you can use them individually as your needs vary. There’s even a little label holder for those of you with OCD.
In any case, they come in sets of 14 for about $20. Not too bad…
More details here.
See Comments on the forum.
casmurbax
Wilton, NY
I think someone posted about that product recently, it looks interesting.
they were mentioned here:
I picked up a couple of sets of the Toolbox widget https://toolboxwidget.com
Work very well. Magnets are strong, but not too strong and they are modular - can add enough spaces for the wrenches you have.
I bookmarked them for possible purchase down the road from the earlier thread. Now that they advertise here I will look into them more.
Mechtech
Look interesting but I'll wait until the size labels are available to make a decision on purchasing.
Matt M PA
SE PA
I agree....surprised they are being marketed without. I'm also thinking that if the labels are another added cost...I'm out.
They look great...but they're certainly not cheap...
stsmytherie
VT
I was eyeing these the other day, perhaps due to that post by fos373. Definitely something I could see using. Couple more positive reviews by GJers my tip me over the edge.
moparfreak
Milwaukee, WI
These are a neat little plug'n'play solution, but I got a similar idea from other GJers that accomplishes the same thing already that is way cheaper....all it takes is a single roll of 12g solid core insulated wire and a broom handle or dowel, and it could probably organize 200 wrenches if you have 'em. I'll spend my $20 on beer. :beer:
y4mKKRlACzjnIMg_V8lVi4N2ggESYratVIt0-TsubpxcuRH6PJe6wkJfq_fhXvr1BBKDi-rmfUG7n-k3woHLRigGZwdpgERT8hjSh4dPCB-GJNcyF1hTunOPy7CJEl-pJbMIuPQLXLUBWlXW19oK13LcNOEBLInXS4FEKPzYKGCN5rLPx24oOqVcWjJhUGGdima12CVNd7Pdvuxb00vLEleEA
SuperCat
Sacramento, CA
I saw these on Amazon recently and I like the modular style of construction, because I seem to still be buying more wrenches. However, they don't conserve space in the toolbox, the wrenches are spaced too far apart for my tastes. The best wrench holder I have seen for the price and for saving space is the homemade wire springs made from 12 gauge wire like moparfreak post #10.
I would like to see reviews based on using this wrench rack, so I am looking forward to seeing what GJ has to say about these. :thumbup:
https://www.amazon.com/dp/B07H6FJY9D/?tag=atomicindus08-20
bimmer1980
York, PA
Neat product.... I would think that if they had a small size and large size (gap spacing) that could interlock would also save some space for smaller wrenches.
Having the gap size for large wrenches makes sense, but takes up more space for smaller wrenches that don't need it....
I will admit, I like the idea of the coiled wire... I might have to try that. I have a fair bit of scraps of wire left over from my garage wiring project...
Stuart in MN
Minneapolis
Wanting to conserve space is a valid concern, but on the other hand having them spaced further apart will make them easier to grab out of the drawer and put back in.
Arkansas COB
Arkansas
What is this home made organizer you refer to ? Cant see your pic if that's it. Did a search for wrench organizers but after 11 pages I got frustrated.
Thanks
COB
rlitman
Long Island
I use one of these for my combination wrenches, and while every wrench is spooning with its neighbors, I don't have any issues picking one out with gloved hands:
I'd love something that could store my line wrenches and ratcheting sets as compactly.
While a magnetic modular wrench organizer sounds like a good idea, aside from the spacing, the other issue I'd have is with the magnets. How well do they work over a drawer liner?
RPH
Michigan Thumb
Ordered two sets to try out. Been trying to get things organized and this may be the easiest way to accomplish the wrenches. Like the magnetic part.
yaidunno
WI
Neat, but i'll stick with my Ernst Wrench Rails. 40 spots for 12.99 vs 14 spots for 19.99 on the widget. I do like the modular design, and the ability to add more to the stack. A bit too many un needed features that add to the cost, IMO. Props to them for bringing it to market though. I'm sure it will suit the needs of some folks very well.
moparfreak
Milwaukee, WI
Thanks
COB
COB,
I just tried the picture as an attachment, maybe that will work.
Firebrick43
West central Indiana
Well I played with mine this morning and they are simply ok and less so for the price.
They feel flimsy out of the box but when you place them on metal the stiffen up and a quite solid.
Here is a 7mm thru 20mm 90's CM raised panel set.
View media item 87597
The larger raised panels don't fit right and are not as secure as I was hoping. I was really looking for a solution to my taco wagon at work that I roll around the plant on concrete and wood block. These don't have enough magnetism to the tools. The widgets have enough not to move.
Here you see a 24mm CM RP in the second to last spot and an early 80's snapon oex 1 1/16 in the last spot. Snap on fits well, CM not so much and larger ones would not allow this shallow lista drawer to close. View media item 87598
Also one of the magnets came out on the first time in the box. They are superglued in and I believe they should be epoxied or maybe even a good industrial hot melt. Not a super big deal but hey.
View media item 87600
My opinion is they would be decent for a box that doesn't move a lot over rough terrain and I wouldn't use them with RP wrenches. I really wish to that they were wider as well. Even a 1/2" would be better but twice as wide would be awesome. Of course you could put two set together but 38$ for a wrench rack is getting outrageous.
I personally dislike Ernst rails and their issues. I guess I will have to makes something custom with some uhmw, magnets, and the unisaw. I was so hoping for and off the shelf solution.
Audicon
Will not be in my purchase list anytime soon as most of my current tooling remains in my toolbag or the cases they come in.
It seems like a nice product, but after looking at the website, there was a photo that seemed like it should be a crime. Who would do this:
gsea
They are also working on some units for pliers and screwdrivers. I emailed the owner and he said he will have a small booth at SEMA. Plan to check them out and see if they could be the new winners for me.
My favorite to date the Ernst Rails, but these are appealing because I've changed toolboxes and added to wrench sets over the years. With these i can adjust accordingly, whereas with the Ernst, once you cut them, they're cut. Also, the slots aren't uniformly sized, so you have to but who racks for each set (can't use the remnants from one rack since they will be all large or all small slots).
Bobioz1
Northern il. (For now)
I bought 1 set and they hold 5 extra long Mountain ratcheting box wrench’s and 5 short Cornwell ratcheting box wrench’s perfectly. Super happy with them. Wouldn’t recommend them for R.P. Wrench’s but wouldn’t recommend R.P. Wrench’s in the first place.
Jackpod
Tonopah Arizona
Got mine today, and first impressions are good. my combo wrenches are a collection of several different sets and manufactures over the last 50 years. They seem accommodating to wrenches of different brands. The best thing about them is being able to have several of the same size
stsmytherie
VT
To echo Firebrick43's comments above, I also picked up a set out of curiosity.
Pros: it's a clever idea, particularly being able to add or remove slots as needed.
Cons: very cheap materials and poor finish. I had 2 magnets fall off just taking them out of the box, and many of the magnets are fitted inconsistently proud or cockeyed in the bottoms. Lots of casting flash.
So I won't be buying more of these
Dumber than lumber
I like your idea A LOT! I will spend $20 on beer -
I might also try to make something like your wrench manage-nizer out of shirt hangers, or welding wire bent around one of the following: a square tube, or a piece of wood or angle steel.
Regnar
I would try it out first before you go hog wild. I personally didnt enjoy the wire method because getting the wrenches in and out and seeing what size the wrench is was a pain is the *** for me. I eventually got to the point that I would just throw the wrenches in the box and worry about it later.
I think the Toolbox Widget is a great ideal but process is slightly flawed. He could easily sell a 30 wrench stick for 20 dollars and allow users to cut to length. Either way I liked it so much that I tried my hand at making my own today. Tomorrow I outfit the rest of the tool box.
HaroRider
New York
How well do these hold smaller wrenches? Like 6 or 7mm? I really like that they are customizable.
BlindViper
York, PA
I would think a paint marker or silver sharpie on of the flats would work great.
gerryw
toronto area
Looks great , but + $38 usd for shipping to Canada( one item) , i think i will wait.... until the knock-offs appear on ebay with free shipping lol,
Gerry
Update; i contacted the company and they forwarded a Canadian seller’s info to me, but unfortunately its still over what i would pay for these( $30cad plus shipping ) good luck to the company on a cool product.
irisservice
NYC,New York USA
Regnar looks great...how Much? :)
