Mr. Wonderful
My dad always jokes that if I ever move, the foundation on my garage is going to move up an inch or two. I'm sure I would have heard about it here if that were true lol.Mr. W, that shelf is going to wind up in China.![]()
You might want to check the vise parts swap thread.Any one have a dynamic jaw for a Reed 104R? I know it’s a long shot but gotta ask.
Rock Island handle and screw look huge on that prentiss!Just picked up this prentiss 50 for $20 today. The guy had a Reed 104r with the dynamic jaw snapped off but the jaw serrations looked brand new. I may go back and get it cause he said he was going to scrap it! The prentiss went in to the purple power for a couple day bath.
...I found/created a graphic that matched the ones I saw for new Wilton Tradesman vises. After polishing some thin aluminum plate to a near mirror finish, I created a waterslide decal on clear media. I coated this with 4 layers of clear gloss acrylic and applied it to the polished aluminum. This made a decent facsimile of the Wilton tag, For protection I coated it with some 2K clear coat...
Whats up with those jaws? It loooks like the just checkered the casting. Are they cast in? I would have been all over it for $20. Good find.
That’s what I figured I’ve wasted $20 on dumber stuff than this!Whats up with those jaws? It loooks like the just checkered the casting. Are they cast in? I would have been all over it for $20. Good find.
I stand corrected, I guess it was the angle of photo and the fact that the screw was not seated into dynamic jaw. It should say oil the screw on the front. I also see it has the prentiss crack.
I’ll get her fixed up nice. It’ll become a nice outdoor vise.I would've loved to have seen the live production when that Reed was snapped.---Better yet, be there filming it.---With the right weld or braze, you can still get a lot of use out of it.---Beaters like that are like real real ugly girls.---If they leave you, you won't mind.---If the vise breaks again, it won't sting so bad.
PRENTISS BULLDOG VISE RESTORATION: EPILOG
Here's the finished restoration. The last thing that I made was a base adaptor, out of wood, to allow the vise to be mounted on any bench without notching the bench top, for the gusset under the vise. This vise is good for another 94+ years. It currently has a new home.
Was it worth it? Monetarily, NO. The labor & machine hours invested is far more that the fair resale price. However, the satisfaction of saving this vise from the scrap yard is priceless..
I hope that this was an informative thread and some of the methods I used help with restoration challenges that you guys & gals may come across while restoring your vises.
I will have to look a little closer, mine has a spot drill hole for a live center I’m guessing from the lathe
Gas BBQ grills work great for preheating!Hi Va. I have owned it for several years. And will not use it at all until it is repaired as you described.
I am a bit concerned that as much metal as is shown on Patrickm82's vise, that I can pre-heat it adequately for a good weld.
I'm a bit dismayed that as late a vise as this Reed is, that the iron quality was not better.
PierceA
Here is a close up of the 2 pieces. Went back into a purple power bath because it seemed to be breaking down the jb weld or epoxy the po put on there.Hi Va. I have owned it for several years. And will not use it at all until it is repaired as you described.
PierceA
Herecey.I’ve seen so many USA made vices snap in the way shown above, is it a fault in the style, I dont recall seeing any UK made vices snap like that, it might be the towers on the typical USA made vice are taller, or inferior iron
Good old American ingenuity, sometimes has it's shortcomings. We come up with creative ways to use them of which they were never intended.I’ve seen so many USA made vices snap in the way shown above, is it a fault in the style, I dont recall seeing any UK made vices snap like that, it might be the towers on the typical USA made vice are taller, or inferior iron
I feel your pain. I’m working on a prentiss 75 that apparently was at the center of Manhattan experiment detonation. The static tower was completely blown out. I attempted to repair it this afternoon. It’s cooling in a big dirt pile after several nomacast rods. I welded the dynamic on my starrett 323-1/2 as well. It can be made useable again. Good luck!
Naw, I am fairly certain… in order most likely; this is resultant of the previous user/abuser, or may be an accidentally dropping/mishandling, or lastly, manufacture defect.I’ve seen so many USA made vices snap in the way shown above, is it a fault in the style, I dont recall seeing any UK made vices snap like that, it might be the towers on the typical USA made vice are taller, or inferior iron
I’ll start with the obligatory “you suk.” Glad ya got her! Great save, Man. 🫡Found this real nice Prentiss no. 2 swivel jaw at the flea market today. Awesome jaws, only took a few minutes to get the pin out and the swivel jaw freed up. What years did they use the graffiti lettering?
