No, this is not normal.Just got a new bench grinder and one of the wheels wobbles.
Is this normal? Should I send it back?
Thanks
Then if the shafts OK, remount the wheels and dress them in.First thing I would do is pull both wheels and run it for a moment to make sure it's not the shaft.
I'll add that if there are washers and/or spacers used to clamp the wheel on the shaft, make sure they are true. I thought I had a bad wheel once and it turns out the big washer I was using was bent enough to cause a wobble. I ordered some machined spacers and it straightened everything out.Then if the shafts OK, remount the wheels and dress them in.
