zmotorsports
Continuing on.
Before final welding of the steering crossmember I drilled a .062" hole near the end. This is critical when welding tubing as the pressures build up internally in the tubing from the heat generated during the welding process and if the pressure is not allowed to be relieved it will blow out right as the weld is being completed and make everything look like ****. When joining tubes I generally drill these holes under the area where the next tube will join so they are always vented back to atmosphere. However, in this instance where the holes around the rest of the chassis have been covered already I drilled a couple of small holes near the end of each tube. I then weld the joint close to where the hole is drilled and stopped. I let the heat and pressures dissipate while I do something else and then come back and weld the last quarter or half inch and close up the hole as I finish the weld. The tube is just large enough that the pressures won't build up fast enough for the last quarter inch or so of weld and I'm able to finish it out smoothly without blowing the molten puddle out.
One more mockup the steering to check for interferences. I measured the length between the tie rod holes in the straight position and then at the turned position for reference.
Next I thought I'd fabricate some mounting tabs for the lights. I found these from a motorcycle parts supplier to simulate the large King Bee headlights typically found on a 32' roadster. These will not be powered of course and are being installed purely for aesthetics. Tabs cut out of cardboard and transferred to some .095" plate.
After mounting holes were drilled and reamed they were bolted together for metal finishing. The heavy grind marks from the 60-grit disc going perpendicular to the mounting tabs.
Shapes are symmetrical.
Then the mounting tabs were turned parallel with the 120-grit sanding belt for the smooth finish.
After separating the tabs and the one in the foreground has been chamfered compared to the one in the background with the hard edges remaining.
Tabs welded into position at the front of the chassis. This step was chosen to be done before the center crossmember to take advantage of the vent holes previously drilled to allow the pressures to escape.
Overview of the front end before final welding of the crossmember.
More to come...
More to come...
