Looking for saw horse recommendations . . . I’m done!
IRQVET
Forgotten Coast (FL)
Looking for saw horse recommendations . . . I’m done with the cheap plastic folding saw horses. Looking to upgrade to something more substancial but also DIY freindly as I’m not making a living with this stuff.
Looking at the Dewalt or the more expensive Bora alternative. Need real world advice.
Go!
Black300zx
Elkton, Md
I've got a pair of these dewalts and I like them a lot. Sturdy, height adjustable, collapse easily to store. Insert a couple 2x4x8s into the grooves and you can make a really large work surface. I don't, however, remember paying THAT much for them. Yeesh.
AC-WC
NE, Indiana
Ebco all the way. Super light weight, super strong, easy setup.
NORDFORD
You can screw straight or you can screw around. Screw straight. Stablemate is what you want…
Dakotadadv8
OP I have sets of Kobalt plastic sawhorses from Lowes they are great, insert 2x4s they are even better. Easy to fold when done and light. Put on 1/2 plywood makes great work table and miter saw table.
I have a pair of something like these, and they've met all my DIY needs. Just scored these cheap at a GS, after experience with the ones listed below the link.
Have another similar pair, but height adjustable, and they've been holding up a vacuum press for the past 10+ years, had them for over 20.
Top pair is still bare, lower pair has a 2x6 on top, slightly longer to be able to clamp to the ends.
BTL-A4
Santa Clarita
+ one more on the Toughbuilt (TB-C550 ot C700). I broke some other ones I had and went with these and they've held up well. I have 4 of them. They are $50.
I also really like my Dewalt folding table (Model# DWST11556). It sets up in about 5 seconds, so I actually use it more than I do my older Craftsman one that takes about 2 minutes to set up. The Cman has an electrical plug, which I like. I use both quite often on projects.
nafterclifen
Poconos, PA
If space is a concern, check out the Burro folding sawhorses. They travel well (in the car, truck, etc) so they really come in handy.
LopezBart
Lopez Island, WA
There are lots of plans on the web for wooden and steel saw horses. Kicking the legs out a bit along the direction of the support beam really helps stability when you're pushing things. If you really abuse them, skip the folding ones; even some heavy duty metal folding sawhorses didn't like a 350 lb cedar log...
For those who subscribe to the "there's no kill like overkill" school:
sparky 1971
Central Iowa
I have these as well as a set sold by Menards under the Masterforce name, I think they are the same. Harbor Freight has a copy cat set that is probably just as good. The slots allow for 2X lumber to fit in. A couple of 2X4's and plywood and you have a table supported the entire length.. A couple 2X6's and you have an elevated top for cutting without worrying about cutting into the horses.
RMERR
Northern CA
Funny, I was just shopping/researching these this morning. I've got 6 of the 29" Burro fixed frame, but even stacked they take up too much space. I've looked at them all, but I'm really leaning towards the Rigid brand, wood across the top and aluminum legs. But the deal maker for me is adjustable height (I'm 6'2"), they adjust from 31"-39" H. Whenever I've had to spend much time working over the Burro sawhorses, my back is always a little sore later. That's just too low for me to working at.
dchawk81
I built my own from common lumber, loaded them heavily with Harde Plank and was surprised they carried all the weight .
They are still firm and strong.
If in doubt; build it stout.
I was about to say I've never needed sawhorses but I remember my dad building his when I was a kid. They don't fold so they aren't like these fancy manufactured ones but they're cheap and sturdy.
Lassen Forge
What ever happened to those reinforced sheet metal clamps (spring loaded) that you used lumber (generally 2x4's, tho I had a set for 4x4's) for the legs and the top runner and made your own sawhorses? You can screw/nail them together or leave them so they come back apart and store in no space whatsoever...
antman213
The new sheet metal style like toughbilt are garbage. In short order all the little extras break. Simple is better for items like this
KnurledNut
n/a
Have used the USA Fulton TS-110S for so long, nothing else seems adequate. Compact, extremely strong, bulletproof, no frills.
I cant stand the majority of current offerings. Under-built and overcomplicated.
Unfortunately, these are NLA. Their are similar versions from other companies that are close enough to the original that I would go with them if looking.
https://www.toolboxsupply.com/produ...ding-sawhorse-2000-lb-25-h-x-38-w-steel-black
danski0224
Near Naperville, IL
The folding adjustable ones that fold into themselves like above do not fold once adjusted to a different height.
Ease of adjustment should be considered if setup and breakdown happens. The model above was a pain with the fiddly wing nuts.
Tapco has (or had) a tall adjustable horse that's quite sturdy. These do not appear to be available any longer. The Beechcraft Bronco looks identical, maybe they were the OEM for Tapco.
jrsavoie
North east Illinois
I can't screw, drill or tap straight without a guide anymore.
I have no idea what happened to me.
Max
Georgia
I have the adjustable ones and agree 100% with you. I do use them rarely, but the are a PITA to use.
However, the ones @KnurledNut posted about are not adjustable and should be better to use…
sparky 1971
Central Iowa
They must have changed them. I've had my Toughbilts since 2011. I'm not a framer so they don't get used all that often, but probably about 10X a year. I know of no little extras and AFIK, nothing has broken..yet. I had them on a job and needed horses at home that were decent so I went to Menards to buy another set, that's when I bought the Masterforce which I believe are the same thing other than color, probably the same OEM. Nothing bad has happened with those either and I've had them since I believe 2016. My only problem is the potential finger pinch when folding them up, but that would be operator error in not paying attention.
RonnieC
Orlando, FL
I built a pair of I-beam sawhorses from 2x4’s with plywood gussets. Came out nice.
YouTube guy Next Level Carpentry has a video on them.
cgrutt
I have a few sets of the plastic ones everything from really cheap no frills to a fairly expensive set of dewalts with some adjustments (height, etc). I also have a set of boras that have been set up with a piece of plywood and left outdoors since beginning of summer. Just recently used a pair of metal folding ones like the Stablemate linked above. They all worked fine and do what they're supposed to do. My friend's pair was a PITA to fold back up not sure if legs were bent but couldn't get them back in place when I was done. If I had to pic just one set it would be the Boras without a doubt strongest of the bunch and takes up the least amount of space when folded up. Important to screw a piece of 2x4 on top of the metal ones so you don't cut through them if you go that route. I also have and have used other's B&D workmates not my first preference but they have their place too.
KnurledNut
n/a
The ones I mentioned dont adjust. I even included a picture. :unsure:
dscheidt
they're still around, they still ****. (My sawhorses are this style. I was reading this thread in hope of finding something else.) done right, with angled cuts on the legs, etc, they're sturdy enough for any sort of framing stuff, and they're cheap enough.
andys
Bucks County, PA
I have a pair of plastic folding ones with a plywood top screwed to pair of 2x4s on edge. The whole table is mounted to a pair of HF furniture dollies so it rolls all around the basement.
I also have the sheet metal clamps that use 2x lumber to make any size you want. Currently, there's a pair of these holding about 100 2x4s in my garage. They've been in that spot with varying loads for a few months now and are 100% sturdy.
Like you, this isn't my living so maybe a fresh pair of plastic horses is the answer.
