"The truth about epoxies" Part 1
Floorguy
Austin, Texas
I have done hundreds of floors and have seen lots of question on here about that subject. I wrote a 4 pager that covers the basics. Sorry for the long length but there is lots of stuff to consider to do the job right and once.
I am not posting this to try and get business as most of you are out of my area anyway. I post this to try and solve at least a little of the mystery, and hope someone finds it useful.
I have read numerous posts on this and other forums about epoxies that fail and see questions all the time about which product is best. I will try to give everyone some basic information that will allow you to make good decisions about your epoxy choices. I will not use brand names so as not to look like I am trying to sell product or services on this site. I have done literally hundreds of floors with 0 failures since starting my own business 4 years ago.
I can’t cover all floor types in this short (ha ha) primer. There are basically three different types of common floor processes. The first being a tinted solid color, gray, tan, red, or blue. There is also the random flake style floor where chips or flakes are broadcast into the wet epoxy for a random flake look. There is also the full coverage flake floor where all the color comes from the flake and is broadcast to rejection, then scraped before applying the topcoat(s).
Preparation
Like any other painting or coating job, preparation is the foundation to getting a job that looks good and performs well long term. The objective is to insure that there is no moisture coming from the concrete, the concrete is free of contaminates, and the surface is ready to accept a coating.
To test for moisture, tape a large garbage bag to the floor on all sides and leave it for a few days. When you pull it up, if there is moisture present then you have a problem and you need to use a primer that is designed to be used in high moisture areas. These are more expensive but a must if you want your work to look good and last. There are calcium chloride test available to test for moisture but the plastic will basically do the job. Both of these tests are a snapshot in time, so if you have the time to test during the rainy season things could look different.
If you do not see moisture one can proceed with preparation. The objective here is to rid the surface of any contaminates and get the surface to feel like medium grit sandpaper. Kitty liter is good at getting large amounts of oil to the surface. I also use brake cleaning fluid to do a final clean of an area.
There are numerous ways to prep the surface and I will touch on each briefly. Acid etching is probably the most popular for the DIYer because it is cheap and readily available. That does not mean it is the best method for prep. The objective here is to mix muratic acid 1 to 4 with water, cover the surface evenly and wait about 15 minutes for the
Bubbling to stop. Using a power washer to clean it off will help insure it’s removal and also do a little removal of loose material at the same time. Mix some baking sodaand water and sprinkle over the surface to neutralize the acid left on the floor. This is very important or there will be potential for floor failure. If you are using a package product that includes a cleaner make sure the surface is clean when completed.
Grinding is the next best method for prepping your concrete. One could do it by hand with a belt sander or orbital sander if your knees can take it, or they rent standup sanders at HD or Sunbelt. Again, the objective is to remove any contaminants and rough up the surface to medium grit sandpaper.
If cracks are found and you want to repair them a diamond blade on an angle grinder can be used to widen the crack so material can be used to fill the crack. Trying to get a thick filler into a tiny crack is next to impossible to do. Once the filler is dried grind it level with the floor and you are done. My suggestion is to fill cracks and grind just before you are ready to apply the coating as you don’t want the filler to have set for more than 6 hours as it could reject the epoxy coating.
The best method to prep a floor is shot blasting as it leaves a great profile on the concrete for accepting a coating. These can also be rented from HD or Sunbelt in larger metro areas. There are also companies that do that for a living but most will not want to work in small areas like a 2 car residential garage as their equipment is designed for much larger areas.
The shot blaster will also uncover cracks in most concrete as it will remove the “cream” from the top of the concrete. Again, widen with a grinder, fill and grind level once dry.
On most homes here Texas there is a raised area that has been covered with cement product for looks purposes. Hit it with the handle end of an old screwdriver and listen to insure that it is solid. You will hear a hollow sound if it is not adhered well. Remove any cement before coating if it is loose. Grinding a bevel on any removed are will make it look acceptable. Better to get it off now then have it break off later and leave an ugly spot.
F
Floorguy
Austin, Texas
"The truth about epoxies" Part 2
Here is part 2
Epoxies
There is a plethora of manufacturers out there today. Most of the stuff one can find in the big box stores is watered down material. Many of the internet materials are also of a lesser caliber. Here are a few things to look for when buying your epoxy. Does the product require an induction time? Meaning, is it supposed to sit for ½ hour after mixed before using. This is NOT a good thing. What is the pot life of the material? The longer the pot life, in genera, the lower quality of material it is. Manufacturers stretch pot life so the DIY crowd can get the material spread before it starts to cook. The material I use has a 20 minute pot life. If you are going to do this yourself gather a team of buddies and use the shortest pot life material you can find. Using a material that is 100% solids is the best way to go because when you put down a 5 mil coat, when it cures you have a 5 mil coat on the floor. If you use a 50% solid material, that 5 mil coat you put down is now a 2.5 mil coat when cured. Putting down multiple coats is very desirable to insure a great looking long lasting floor. Make sure that you observe recoat times when applying the second or third coat. Epoxies once cured (usually 24 hours) will not allow another coat to adhere to itself without sanding the previous coat.
Humidity and temperature affect epoxies in pot life and cure time. Try to install your floor during a time when you know there is low humidity (no rain in forecast) and when the temp will be around the 70 degree range for a few days.
How much to buy/use.
Follow the suggestions of the manufacturer. You do not want to be short of material. As an example only, I will share how much material I would use on a typical 3 car garage of 750 sq. ft. I have generated a spread sheet that I have entered data into for years. It gives the average used over time. I always insure I have more material than it says just to be safe. Prep method can change material requirements drastically. If shot blasted, the concrete has numerous peaks and valleys and will require more material on the first coat. These numbers are for a shot blasted floor doing a primer, base coat of clear epoxy, flake, clear top coat of epoxy and then a urethane coat for wear protection, UV protection, and chemical resistance.
100% solid primer (clear) 3.24 Gallons
100% solid epoxy (clear) 7.09 Gallons
Urethane 2.09 Gallons
Flake Broadcast 200lbs.
Reclaim 120lbs. (80 lbs. Left on floor to topcoat)
Application
Again, follow the manufacturers suggestions on mix times and induction times if so instructed. The key to most epoxies is to premix the resin and hardener for 2 minutes. Use different mixing paddles for each so cross contamination is eliminated. In a separate bucket measure out the resin first and then add the hardener to the resin and mix for 2 minutes. Make sure that the top of the mixing paddle is below the level of the material. This will reduce the possibility to induce air bubbles into the mixture, which will transfer to the floor. Follow manufacturers suggestions for recoat times if multiple coats are to be applied.
Tape off all areas that you do not want to get coated. I use blue tape for plasterboard areas and standard tan masking tape for concrete areas (it sticks better). If you have golf spikes it is best to remove tape before the product cures as it can get stuck to things when the epoxy dries. Remove after cut in, before rolling if you feel confident you won’t hit the areas while rolling. Duct tape also works well for areas where you want to stop the floor. Doorways and such.
Mix the materials as above and start at the farthest end of the garage and work your way out cutting in edges or small verticals with a 2 or 3” wide disposable brush. Having multiple people on hand is definitely a plus. Once the front wall and 1/3 of the sides are done, have the others continue cutting in while you roll or squeegee out the bulk of the floor pan. Work your way out the garage doors and you are done.
I highly suggest using a urethane topcoat as that will protect your floor and give you a long and durable finish. Epoxies are great builders and stick well to properly prepared concrete. Urethanes are a better topcoat but do not stick as well to the concrete.
These are basic guidelines for choosing and using epoxies. Unfortunately there is not enough time or space to cover all variables in this process.
Done properly, using the right prep and materials, epoxy floors will outlast most other floors in the garage. A good floor should easily last 10 – 15 years showing little signs of wear in a typical garage. Those getting more use and less care will obviously show those wear signs.
I would be a happy to answer questions as time allows.
There are certainly other material choices for the garage floor but for my money, there is nothing that I have seen that beats a quality epoxy floor.
I guess I have to admit that I am a little biased as I do this for a living, but I have truly looked at, and tested other floor coverings and have not been impressed with any of them long term. If you have something that you think is better, I would be happy to look at it and give you my opinion once tested. I want to provide my clients the best options possible and at this time that is a quality epoxy floor.
I realize this is a DIY site and share this information in order to help you make a good decision in your flooring choice. Some things will be easy for the DIYer and others will not be so easy to obtain.
Knowledge is power and I hope I imparted a little of my experience and it will help you out.
This document is intended for general advice and is not meant to supersede any instruction by the manufacturers.
OldCarGuy
This post has excellent and conclusive information about epoxy garage floor coating. It answers many questions concerning most aspects of preparation and applying epoxy.
May I suggest that it be made a sticky…
RickP330
Middle Island, NY
Don,
I would like to use a method like this, but I’m afraid my floor finish isn’t the best quality. To best describe it – it’s a cross between a trowel finish and broom finish. Flatness wise it’s really good but it’s rough as any concrete finish I’ve seen. There are no pebbles or rocks in it, just rough finish. I can knock down the high spots with a belt sander – if I do – do you think it’s still worth it?
Rick
bpez317
I'm curious as to what brand product you use. I've been looking at Durall.
Thanks
Bob
F
Floorguy
Austin, Texas
RickP330 said:
Don,
Rick
Rough is what you want to apply a coating. Just make sure there is no loose material (dust, sand etc.) In you case it might make sense to do a acid etch as the concrete is already rough and does not need shotblasted to accomplish that. You will just use lots of material to get it to fill all the little valleys.
Beegs
NH
Great info!
Just a sidenote: grinding concrete will load your lungs up with bad stuff, make sure to wear a proper mask.
F
Floorguy
Austin, Texas
Beegs said:
Great info!
Excellent point. ALWAYS wear a proper mask, eye protection, and heavy clothing.
Baer
SE Pa
Excellent primer -- answers a lot of questions in one coherent piece. Thank you Floorguy! :thumbup:
BlackLead
Biloxi, MS
Floorguy said:
Mix some ammonia and sprinkle over the surface to neutralize the acid left on the floor.
Could you give a little more clarification to this? The only ammonia I can think of is usually in some sort of household cleaner. I've heard of baking soda, bicarbonate of soda, soda ash and lime as acid neutralizers, but not ammonia. Is there a ratio of mixture you use?
What type of fillers are you referring to here? I'm not very familiar with these, so I'd like to know what to avoid. I've seen the "vinyl patching compound" at the stores; is this the stuff that's problematic? Any suggestions if it's already in place?
Thanks for a well-written and very informative post! :thumbup:
F
Floorguy
Austin, Texas
tubeman said:
what type of preparation is needed to top the epoxy with a polyurethane UV barrier?
It is best done at time of application. Most epoxies seal themselves within 24 hours and not much is going to stick. I would contact the manufacturer of the epoxy that is on your floor and see if they have a compatible urethane. Most likely the prep would be to lightly sand the surface Can be done with one of those standup floor polishes with a sanding pad and clean off any dust or oil. Then apply the urethane. Using one manufactuers product is always suggested for compatability.
F
Floorguy
Austin, Texas
I use a 2 part product called rapid gel. I get it from the local construction supply company. I tested it with my products for compatability before using it on any floors. It is one of those 2 tube units with resin in one tube and hardener in the other. They mix through a spiral tube and come out mixed. Easy to handle and works well for me.
I forget the manufacturers name but I will look next time I am in my trailer.
F
Floorguy
Austin, Texas
Here is a link to a website I find useul. It does not use amonia but has other suggestions for rinsing.
http://www.epoxyproducts.com/acid.html
F
Floorguy
Austin, Texas
South Austin. I used to make it to the Albertsons in Oak Hill but have not been lately for the Saturday night gatherings. What part are you in? Is that a 70 you got?
F
Floorguy
Austin, Texas
I do not use acid so I am not the best guy to help on this one. There is a web site that is pretty good and should cover this for you. www.epoxy,com.
Lots of data there but i think they have a search function and that should help
F
Floorguy
Austin, Texas
I have heard that Durall is a good product but I have no experience with it. I use Valspar Industrial products, not the kind you find in big box stores.
bmwpower
Don,
Can I just use amonia in liquid form from the supermarket? I am kind of curious about the process, I etched my last floor with Muriatic acid and just rinsed it off. Seemed to work well.
Rick
Water should be sufficient. Just use a lot of it and/or test the pH of the floor with some litmus paper.
Cursed
What would be reasonable to pay someone for the proper products and installation of an epoxy floor? I have a two car garage, at max I think 550 sqft. I want a professional appearance and long lasting floor.
Adam
RickP330
Middle Island, NY
Hello Don,
Again, I wanted to publicly thank you for helping me with my floor. I followed pretty closely to what you recommended here and it was great advice. The details down to the material quantity that would be required were right on the money. I couldn’t have done it without you, Thanks Dude!
Folks, believe me when I tell you this stuff here is accurate and good advice. I don’t know Don, except from this forum, but he knows what he is talking about.
Rick
Dave88LX
York, PA
Valspar...the same company that has the line of paint at Lowe's?
I've got 1344 sqft to cover. I was thinking of RaceDeck but at $2.90/sqft it's going to cost me over $4000!
I'm going to compare the cost of buying the material and DIY vs. having someone come out, shot blast the floor, and do it for me.
Floorguy, would you mind shooting me a PM on what I could expect to pay? Concrete is in great shape.
It just seems like a huge area (28 x 48) to do myself. Thank you!
z28toz06
Connecticut
My floor is 24x32. I want to do a floor epoxy coat as eventually I would like to do racedeck or some kind of floating tile system. the epoxy would protect the floor underneath from any spills that worked their way through the tiles.
anyone else done this?
F
Floorguy
Austin, Texas
I have not heard of anyone planning on doing this but I know folks who messed up the epoxy and put the tiles down to cover it up:)
I would think a sealer of some sort underneath would be cheaper than doing epoxy and tile. Why not just do a quality epoxy and let it be at that.
Hope this helps.
z28toz06
Connecticut
Hope this helps.
mostly because it will be a year or so before I spring for the tiles, so i figured in the mean time, or just in case it never happens it looks good and can stay clean
Oddjob
MD
First I want to thank you, floorguy, for such a comprehensive writeup. I'm about to undertake my garage (505 sqft) and have never done anything like this before. That being said, the floor isn't as spectacular as some of the before pictures I've seen on this site. It's by no means in terrible condition, but it's going to need some work to get ready to coat. I think my biggest problem is spalling. There are a few areas in the garage where this exists. Also, there's a pretty decent crack around the exterior of the floor. I'd like to fill the spalling and cracks, but have no idea what to use that would not resist the epoxy. Can you suggest something?
SteveL
St. Louis, MO
Floorguy....I have a small area, maybe 24" x 36" near the large overhead door of an oversized 3 car garage that collects water and has been coated before with Benjamin Moore epoxy. I plan on grinding or sanding the old coating as I added on to the garage and have about 300 sq ft of new concrete and want to coat the whole thing at once. Question is, what should I use to level the low area out or am I better to try to grind or sand it out. It's a real pain as every rain or snow or even after washing a car, I end up with water that needs to be squeegied(sp?) out
And secondly, where the new and old slabs meet, there is a hairline crack and some small spalled spots where concrete nails use to hold some studs to the floor. What would be best for these???
Thanks for the help!!!!
