Bigblue&Goldie
And that's the look when he's staring at the love of his life......
The paper towel holder is badass! I thought at first you were doing mods to the snowblower!
There is only one right way and that is fed from the back, NOT over the top. My house, my rules.
Or has cats, they will unroll the whole thing if if it's on there properly!Probably puts ketchup on hot dogs, too.
NOOOOO!!!!! NEVER!!!!! Ketchup on hot dogs is just wrong!!!! Whomever thought putting ketchup on hot dogs was a good idea should be taken out back and shot.Probably puts ketchup on hot dogs, too.
Ok Mike, I get that you’re probably NOT going to give my GMC any love, so maybe you’ll give me a bit of advice? With the onset of this miserable season called Winter, my 06 now thinks it needs glow plugs. Any advise on R&R on them? I’ve been told by several guys that have done them before that when you go to remove them, the initial pop will make you have a “aw ****, it just broke off in the head” moment! So do you have any tricks or tips on this job?
TIA!
NOOOOO!!!!! NEVER!!!!! Ketchup on hot dogs is just wrong!!!! Whomever thought putting ketchup on hot dogs was a good idea should be taken out back and shot.I'm sorry but I have to draw the line here. GAAAAHHHH!!!
(I bet you'll never guess where I was born and brought up?)
Well, almost everything.Is it really wrong to like both? And maybe a little relish too? Have to get some veggies in there!Ya got me Scott. Yes, I'm a ketchup guy and NOT a mustard guy.
Sterling, I put lots of stuff on hot dogs. Ketchup, mustard, relish, diced pickled jalapeno peppers, raw or cooked onions, chili and cheese. Usually means I need a spork or spoon to handle the spillage. For fun I sometimes use mustard that has horseradish or hot peppers in it. On a special day wasabi or Russian mustard might also be involved.Is it really wrong to like both? And maybe a little relish too? Have to get some veggies in there!
Mike: In your post #9835, the picture of the towel holder slug mounted on your cabinet, is that you in the photo on the wall with a motorcycle and a girl, assuming your wife, or future wife?
I do like the nice detail of using an AJPE rod Mike! ;-)
Given your background, would UHMW skids last any longer than the factory wear plates?
Any plans to add a chamfer to the bar stock so they aren't as likely to catch on edges and such?
I switched to UHMW skid shoes and noticed that the machine is much easier to move around compared to the steel shoes. I'm sure they won't last as long, but the trade off so far is worth it to me.
Get some hard face welding rod and those will out live you!
Me and my Wing-Ma’am got the glow plugs done today. She held the light while I twisted the wrenches! Can’t believe how easy it was, thanks Mike for the vote of confidence. Local Chevy dealership wanted over $400 to change two glow plugs, my wife and I got it done in less than one hour, and I actually used a torque wrench and did everything to spec. I bet their flat rate jockey wouldn’t have even put down his impact the whole job! Very easy after you drop the inner fender, everything is right there!
I really like this truck and I understand why Mike loves his!
Um that’s not just cool, that connecting rod probably makes that the most expensive paper towel holder Iv ever seen! I want one!Continuing on with the paper towel holder project.
Slug bolted to the angle bracket after the holes were drilled in the cabinet. I like this version better than my original thought of welding the slug to the angle bracket.
Bolted to the cabinet and ready to accept the connecting rod.
Next I had to machine an adapter in which to be pressed into the wrist pin side of the connecting rod as I didn't have a piece of tubing the correct size. I made a larger piece that was approx. .001" larger than the wrist pin bore.
Then took my longer length of aluminum tubing and stepped the end down slightly for a .001" pressed fit into the piece I machined in the step previous.
Before pressing the components together, I chucked it up in the lathe and ran some emery paper and Scotchbrite cloth over the tubing to removed the corrosion.
Now the parts can be pressed together.
Once pressed together I put back in the lathe and faced off the ends so they look like one piece. This also increased the OD by about half a thou larger. Looking back, I think I should have pressed the pieces together and then machined this end down to the .001 interference fit for the wrist pin end. I guess that's why hindsight is 20/20.
To aid in assembly I applied a little pressing lube for the job at hand.
This worked perfectly, even though it was a little tighter fit than I initially intended.
And the finished product.
Thanks for looking and thanks to Justin for the idea.
I tried a couple versions of UHMW skids last year and went back to the steelies.That is still a consideration. I didn't have the size I wanted of UHMW on hand so that may be a future test if this doesn't go a planned.
I know they offer a UHMW version commercially but haven't really heard much feedback.
The first set was just a slab of UHMW machined into the shape of the skids. They moved around too much, you couldn't tighten them enough. I found after a couple sessions one had moved and I'd catch the scraper and I'd have to adjust it.
The second set was the Toro ones and they were better made but they wore faster than the steel and still needed more adjustment than I cared for.
For your expanse of concrete the above idea of some hardface likely would work the best.
I've gotta go with Clint...
Awesome towel holder...
Ya well..,nobodies perfectHello, my name is Mike and I like ketchup on hot dogs.
.Yes, the wife loves mustard.![]()
It's nice that you people manage to find one other.I’m a ketchup on a hotdog kinda guy also.
